  • Replies 23
  • humaironline
    10
  • stevsmith
    6
  • iskalipsi
    5
  • amit87
    1
nice job, is that in a conceptual visual style? that would look better if you render it.. Is this for a project?
i am week in redering...will help me to apply render it.
ya it is the project of my home building. i will shift to new rooms. I just made all furniture to set it first in the available room sizes.
Well….When you’re ready design your docoment then you have advantage of your existing data by creating 2D sections from the 3D model. By using Section Plane tool, which is available on the Home Tab, in the Section panel. define a section plane using various methods its easy . you have be want to pick points or select from standard orthographic options. And The AutoCAD materials library is easily accessible from the tool palette and it also includes more than 300 materials that simply drag and drop onto your model also.So for 3d array check the AutoCAD materials and proper dimensions also.
Hey! guys, would you like to win iPod Nano? Here is a CAD design contest where you can showcase your talent to the world: www.zwcad.org/dc2010
