Yes I am using LDD and Civil 3D Autocad 2006 product, I tried your code Lee and it works beautifully, you are the bomb, you do not know how much I appreciate it.
  • Replies 66
  • Lee Mac
    23
  • CadProWannabe
    12
  • eldon
    8
  • wizman
    8
Posted Images
Thanks for your kind words, you're welcome :)
  • 5 years later...
This is what the other lisp routine does that I use.
1. activate the command
2. select point block from Node (which is set at 0.00 elevation)
3. extracts the description and elevation and places a line between the two text entities and the end of the line is attached to the node of the point block.
CadPro...:
Would you'd be willing to share the "other" lisp routine you refer to?
Or, would anyone else be able to create one?
I've been attempting to create a routine which will accomplish this goal but have had limited success, and by "limited" I mean none at all.
Still using ACAD2002. :thumbsup:
CadPro last posted in July, 2014. You may have to speak louder for him to hear you.
Lol, I saw that as well. Too bad I can't find a way to email him.
Perhaps I'll get lucky and come up with a Frankenstein program of my own.
  • 7 years later...
On 1/16/2010 at 11:09 PM, Lee Mac said:
Try this one:
(defun c:tpt (/ Make_Text pt BoxNum BoxHgt BoxWid)
 ;; Lee Mac, David Bethel & Wizman  ~  10.01.10 (= 38)
 (setvar 'dimzin 0)
 (defun Make_Text (pt val)
   (setq pt1 (polar pt (atan BoxHgt   (* BoxNum BoxWid))
                       (sqrt (+ (expt (* BoxNum BoxWid) 2)
                                (expt BoxHgt 2)))))
   (entmakex (list (cons 0   "MTEXT")
                   (cons 100 "AcDbEntity")
                   (cons 100 "AcDbMText")
                   (cons 71 3)
                   (list 10 (car pt1) (cadr pt1) (caddr pt))
                   (cons 40 (getvar 'TEXTSIZE))
                   (cons 1  (strcat "{\\fMonospac821 BT|b0|i0|c0|p49;" val "}")))))
 (setq BoxNum (+ 0.412636   (getvar 'LUPREC))
       BoxHgt (* 0.892748   (getvar 'TEXTSIZE))
       BoxWid (* (/ 13 15.) (getvar 'TEXTSIZE)))
 (while (setq pt (getpoint "\nPick Point: "))
   (Make_Text pt (rtos (caddr (trans pt 1 0)))))
 (princ))
hi lee
how to change this code for labeling multiple points automatically.
(defun C:lbpo ( / ss i ename ent ptcord zvalue)
  (setq txth(getreal"\n enter text height"))
  (command "._undo" "_BE")
(setvar "cmdecho" 0)
(setq clyr(getvar"clayer"))
(setq ss (ssget '((0 . "point,INSERT"))))
(setq i 0)
  (repeat (fix (sslength ss))
    (acet-ui-progress-init "processing file:" (sslength ss))
    (acet-ui-progress-safe i)
    (setq ename (ssname ss i))
    (setq ent (entget ename))
    (setq ptcord (cdr (assoc 10 ent)))
    (setq zvalue(caddr ptcord))
    (setq osmd(getvar"osmode"))
    (setvar"osmode"0)
    ;;;;;;;;;;;;;;;;;;;;;;;;ncreat ch at p
	     (entmakex (list '(0 . "TEXT")
                             '(100 . "AcDbEntity")
                             '(67 . 0)
                             '(8 . "Elevation")
                             '(100 . "AcDbText")
                             (cons 10 ptcord)
                             (cons 40 txth)
                             (cons 1 (rtos zvalue 2 2))
                             (cons 50 0)
                             '(41 . 1.0)
                             '(51 . 0.3)
			     '(62 . 3)
                             '(7 . "Standard")
                             '(71 . 0)
                             '(72 . 0)
                             (cons 11 (list 0.0 0.0 zvalue))
                             '(100 . "AcDbText")
                             '(73 . 0)
    (setq i (1+ i))
  (acet-ui-progress-done)
  (setvar"clayer"clyr)
  (setvar"osmode"osmd)
  (command "._undo" "_END")
this is mine for multiple points
