sftee4 Posted January 9, 2010 Posted January 9, 2010 i done the drawing and found the scale in layout 1 do not fit in a A4 size paper, i have checked the page setup manager, i have zoomed 1xp and i want my scale 1:1,can anyone help me? i have attached the dwg..... tee.dwg Quote
eldon Posted January 9, 2010 Posted January 9, 2010 If you look at the Printable area in the Plot dialogue box, you will see that it says 257.00 x 195.00mm. Your drawing is too large to fit on this area at a scale of 1 to 1 Quote
BearDyugin Posted January 9, 2010 Posted January 9, 2010 If your printer could print without fields - that all would be good. But your printer has fields (dashed line) and they very big (as wrote eldon) - therefore 1:1 is not possible For example, at my printer (as well as at the majority of others) fields small and if slightly to correct design (leader with radiuses) - that is possible will receive 1:1 Quote
