Lisp: blinks the layer of the selected entity
Hallo,
I found this on cadforum cz
It works fine on acad2010, but not in acad2008.
Is it impossible, or what do I have to change ?
(defun C:BLINK ( / ent lay sslay)
(defun ssblik (ss val / ssl i entn)
 (setq i 0  ssl (sslength ss))
 (repeat ssl
    (setq entn (ssname ss i))
    (redraw entn val)
    (setq i (1+ i))
(setvar "cmdecho" 0)
(if (and
    (setq ent (entsel "\n select : "))
    (setq ent (car ent))
    (setq lay (cdr (assoc 8 (entget ent))))
    (setq sslay (ssget "_X" (list (cons 8 lay))))
 (repeat 12
    (ssblik sslay 3)
    (command "._delay" "200")
    (ssblik sslay 4)
;(regenall)?
It is a good tool to find all things on the selected layer.
Greets from - garlic-
This should work:
(defun c:blink (/ *error* blinker i ent ss OldCm ObjLst )
 (defun *error* (msg)
   (if oldCm (setvar "CMDECHO" oldCm))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (defun blinker (lst code / x lst)
   (while (setq x (car lst))
     (redraw x code)
     (setq lst (cdr lst))))
 (if (and (setq i -1 ent (car (entsel "\nSelect Object: ")))
          (setq ss  (ssget "_X" (list (assoc 8 (entget ent))))))
     (setq OldCm (getvar "CMDECHO"))
     (setvar "CMDECHO" 0)
     (while (setq ent (ssname ss (setq i (1+ i))))
       (setq ObjLst (cons ent ObjLst)))
     (repeat 12
       (blinker ObjLst 3)
       (command "_.delay" 200)
       (blinker ObjLst 4)
       (command "_.delay" 200))
     (setvar "CMDECHO" OldCm)))
 (princ))
Another two to try:
(defun c:hlight  (/ lLst lay i ss ent)
 ;; Lee Mac  ~  08.01.10
 (vl-load-com)
 (setq *acad* (cond (*acad*) ((vlax-get-acad-object)))
       *doc*  (cond (*doc* ) ((vla-get-ActiveDocument *acad*))))
 (vlax-map-collection (vla-get-layers *doc*)
   (function (lambda (x) (setq lLst (cons (strcase (vla-get-name x)) lLst)))))
 (while
     (setq lay (strcase
                 (getstring t
                   (strcat "\nSpecify Layer to highlight <" (getvar "CLAYER") "> : "))))
     (cond (  (eq "" lay) (not (setq lay (getvar "CLAYER"))))
           (  (not (vl-position lay lLst)) (princ "\n** Layer not Found **")))))
 (if (setq i -1 ss (ssget "_X" (list (cons 8 lay))))
     (redraw ent 3)))
 (princ))
(defun c:hlight2  (/ lay ObjLst NulLst grdat iEnt)
 (princ "\nMove Cursor Over Objects....")
 (while (eq 5 (car (setq grdat (grread t 4 2))))
   (if (setq iEnt (car (nentselp (cadr grdat))))
       (setq lay    (cdr (assoc 8 (entget iEnt)))
             ObjLst (mapcar (function cadr)
                            (ssnamex (ssget "_X" (list (cons 8 lay))))))
       (mapcar (function (lambda (x) (redraw x 3))) ObjLst)
       (if (setq nss (ssget "_X" (list (cons -4 "<NOT") (cons 8 lay)
                                       (cons -4 "NOT>"))))
           (setq NulLst (mapcar (function cadr) (ssnamex nss)))
           (mapcar (function (lambda (x) (redraw x 2))) NulLst))))
       (and ObjLst (mapcar (function (lambda (x) (redraw x 4))) ObjLst))
       (and NulLst (mapcar (function (lambda (x) (redraw x 1))) NulLst)))))
 (princ))
I've seen this Blink lisp before but not working in '09 also the blink version by lee is not ok in '09. but in '10 both are ok.
That's odd, both versions of Blink.lsp worked for me in '09.
Do the other two work Wiz? What error do you receive in '09 - I assume its something to do with the Delay command. :wink:
oops, i deleted my post, i hope you got my message that adjusting delay doesn't do also, the other two were fine, let's wait for the test on '08 version.
i forgot i got '08 also here, both doesn't blink also.
Guys, blink did not work here in AC8. hlight & hlight2 work fine in AC8 here. hlight2 is neat for me.
HTH
"blink" and "hlight2" works fine here in acad2008 and 2010 :D
That`s it! Thanks a lot:)
Man, I wrote something like this about 10 years ago. I used to work for a company that did a lot of 2d which created a bunch of different layers of differing colors. in order to find the correct part in all of those layers I wrote this routine to help.
It is old but it does still work. User defined .ini. (change the .ini.lsp to .ini)
LAYER_HL.dcl
LAYER_HL.ini.lsp
LAYER_HL.lsp
Cool!!!!!!!!!
:cry:mhhhhhhhh, here it does not work in 2008 and 2010, Tim:
Program Error: BAD ARGUMENT TYPE: STREAMP NIL
Did I something wrong?
-garlic-
Did you rename the .ini.lsp file to a .ini ?
Did you change the hard-coded path in the LISP to where you put the .ini file?
Man, I wrote something like this about 10 years ago. ..
Thanks Tim, Wonder if i will still be lisping 10 years from now.....'-)
Funny I haven't used that prog in probably 6-8 years. I just looked at the code....WOW :? I would write it completely different today. I saw the dat was 2001, the original (non dcl version) was written in 1997, and only blinked one color (green).
Ah the good old days.
-garlic-
You have to open the lisp and change the path to match your path (Sorry)
Tim: I got it ! Thanks a lot - it`s very good in acad 2008 and 2010 !
- garlic-
Thought I'd improve it a touch, click to isolate layer :)
(defun c:hl2 (/ ss->list re-draw CODE ENT GR LAY LLST NSS NULLST OBJLST)
 (vl-load-com)
   (vla-get-layers
   (function
     (lambda (x)
       (setq llst (cons x llst)))))
 (defun ss->list (ss / i ent lst)
   (setq i -1)
     (setq lst (cons ent lst))) lst)
 (defun re-draw (lst code)
   (mapcar (function (lambda (x) (redraw x code))) lst))
 (while (and (= 5 (car (setq gr (grread 't 4 2)))) (listp (cadr gr)))
   (if (setq ent (car (nentselp (cadr gr))))
             ObjLst (ss->list (ssget "_X" (list (cons 8 lay)))))
       (re-draw ObjLst 3)
                                       (cons -4 "NOT>"))))
           (setq NulLst (ss->list nss))
           (re-draw NulLst 2))))
       (and ObjLst (re-draw ObjLst 4))
       (and NulLst (re-draw NulLst 1)))))
 (if (listp (cadr gr))
       (setq lay (strcase (cdr (assoc 8 (entget ent)))))
       (mapcar
         (function
           (lambda (layer)
             (vla-put-layeron layer
               (if (eq lay (strcase (vla-get-name layer)))
                 :vlax-true :vlax-false)))) llst))))
 (princ))
