I am currently using Autocad Lt 2008 at work and whenever I go to use the hatch command (as in typing in "hatch") I recieve a fatal error that crashes my autocad :glare:
If I purge + audit before typing "hatch" then it works fine.
Anyone else have this problem or have any solutions?
Thanks
Are you fine Hatch command from toolbar ?
When I audit, its a 50/50 chance it seems for errors or not. But if I don't do the purge/audit, theres 100% for hatch to crash Autocad Lt 2008.
I couldnt say for sure about the toolbar command for hatch, I never click it, quicker for me to just type it, never registers that I should click it instead of typing.
Anything else I can add that will help?
Have you tried typing just the letters "bh"?
