I have one drawing with above 1000 ground level. I need to add a common value with that levels . any lisp for that calculation. Please help me. I attached that sample drawing. Please help me.
Eg. 269.222+0.253
269.235 + 0.253
279.325+0.253 Etc......... I got one lisp for that but one problem, if iam using that lisp, i need to select all numbers one by one. so pls help for me adding that value at one time.............
new block.dwgFetching info...
Hi my friends! :)
I'd like to sum numbers with comma.
e.g 320,10+320,11=640,21
Thank in advance
  • 10 months later...
:shock: the code is just great, Thanks a lot.
WJ chen from Muscat, Oman
Thanks Fixo.
Great Code.
WJ Chen
Muscat
Oman:shock::shock:
  • 3 years later...
  • 2 years later...
  On 8/12/2008 at 7:53 PM, fixo said:
Do not agreed with you
The Earth is so small, take a look on map -
just 5-6 thousand of miles or so :)
Here is edited version
This will create the new text entity with
the same properties as the first selected
text has
(defun C:STX (/ cpent elist en ip newtxt pt ss sum sumtxt txt)
(princ "\n\t\t>>>  Select text to get summ >>>")
(if
;;select texts/mtexts on screen :
(setq ss (ssget '((0 . "*TEXT"))))
;; if selected then :
 ;; store the first text entity for using 'em further :
(setq cpent (ssname ss 0))
 ;; set initial sum to zero :
 (setq sum 0.)
 ;; loop trough selected texts/mtexts :
 (while
   ;; get the first text in selection :
   (setq en (ssname ss 0))
   ;; get entity list of them :
   (setq elist (entget en))
   ;; get the textstring by key 1 from entity list :
   (setq txt (cdr (assoc 1 elist)))
   ;; create output string :
   (setq sumtxt
   ;; concatenate strings :
   (strcat
     ;; convert digits to string :
     (rtos
       ;; add to summ the digital value of text :
       (setq sum (+ (atof txt) sum))
       ;; 2 is for metric units (3 for engineering) :
       2
       ;; set precision by current :
       (getvar "dimdec")))
   ;; delete entity from selection set :
   (ssdel en ss)
 ;; display message in the command line:
 (princ (strcat "\nSumm=" sumtxt))
 (setq pt (getpoint "\nSpecify the new text location: "))
 ;; get the insertion point of stored entity :
 (setq ip (cdr (assoc 10 (entget cpent))))
 ;; copy text entity to the new destination point :
 (command "_copy" cpent "" ip pt)
 ;; get the last created entity :
 (setq newtxt (entlast))
 (setq elist (entget newtxt))
 ;; modify entity list with new text string :
 (entmod (subst (cons 1 sumtxt)(assoc 1 elist) elist))
 ;; update changes :
 (entupd newtxt)
(princ "\nStart command with STX...")
hi , good evening or night there , i tried this lisp and it is pretty good , just please if u could help me , that would be so kind from u  ,.... i wanna delete the selected texts after being added
thanks in advance
best regards
~'J'~
Expand
