asos2000 Posted August 12, 2008 Posted August 12, 2008 I created a attribute has many attributes inside one of them changed in Z value when I BEDIT the block all objects have Z in zero but the inserted attributes has several Z values how can I redefine the attribute Z value to zero Quote
NBC Posted August 12, 2008 Posted August 12, 2008 redefine your block as normal. then use ATTSYNC on your blocks. Please bear in mind that when using ATTSYNC on attributes, it will reset the position of all attributes within the selected block(s) to their default position. Quote
