Object selection and layer property toolbar problems. PLEASE HELP!
Hello everyone, I am brand new to this site and had a question that I need answered. It is driving me crazy and this is probably such an easy fix.
The main problem im having is when I select an object, the layers toolbar doesn't seem to be responding. Usually when i click on object the layers toolbar will change to show what the layer is for that object. For some odd reason, one day it just stopped working. I dont kow if I changed a setting somewhere or not, all I know is it doesn't change to reflect what layer that object is using. Everything else on the layers toolbar seems to be working just fine.
Is this a setting that might have been changed by accident? Can anyone help me with this? Thanks so much!!
Try setting Pickfirst=1
I knew it was easier than i thought it would be..lol
Thanks so much for that....it worked like a charm!
You might have used any lisp that changes it, and don't have an error trapper
  • 8 years later...
Thanks for the solution! Just encountered this problem yesterday before leaving for the day and now it's solved.
