Rename Blocks
flowerrobot
Guest balajibth84
Thought some one could make use of this
Will rename all blocks or just a single block, from selecting the target , Good for those random blocks or bad memory
Rename Blocks
Created by FlowerRobot
Created on 20/12/09
Rev 1.1
Will rename a single block or all blocks
Rev history
Rev 1.0 (unkown)
 Created
Rev 1.1 20/12/09
 Command defined simpler
 Varibles localised and tidy up
(defun c:rre
(/  Ent_BlkData Str_BkNme Str_NwBlkNme Bol_All Pt_BkPt Xscle Yscle Zscle Rotation OldOs Lst_EntInfo SS_1Block
;Subs
 *error*
 GetBlockEnts
(defun *error* (Str_ErrorMsg /)
 (if ErrorDump (princ Str_ErrorMsg))
 (vl-cmdf "_.undo" "_end")
 (vl-cmdf "_.undo" "1")
(princ "An error accured exiting")
 (setvar "cmdecho" 1)
(vl-load-com)
(setvar "cmdecho" 0)
(vl-cmdf "_.undo" "_begin")
(defun GetBlockEnts (Str_BkNme / Ent_Blk lst_Item Ent_Nxt)
 (setq Ent_Blk (cdr (assoc -2 (tblsearch "block" Str_BkNme)))
  lst_Item (list (cdr (assoc -1(entget Ent_Blk))))
  Ent_Nxt (entnext Ent_Blk))
 (while Ent_Nxt
   (setq lst_Item (append   (list(cdr (assoc -1(entget Ent_Nxt))))lst_Item)
   Ent_Nxt (entnext Ent_Nxt))
  lst_Item
(princ "\nSelect Block")
(if(and
  (setq SS_1Block (ssget ":S" '((0 . "INSERT"))))
  (< 0 (strlen (setq Str_NwBlkNme (getstring "\nWhat is new name: "))))
  (setq Ent_BlkData (ssname SS_1Block 0)
   Lst_EntInfo (entget Ent_BlkData)
   Str_BkNme (cdr (assoc 2 Lst_EntInfo))
  (initget  0 "YES NO")
  (cond
   ((tblsearch "block" Str_NwBlkNme)
    (princ (strcat "A Block \""  Str_NwBlkNme "\" already exists")))
   ((if (= "NO" (getkword "\nRename all? : [YES/NO] <YES>")) nil t)
    (vl-cmdf "_Rename" "Block"  Str_BkNme Str_NwBlkNme))
   (t
    (entmake (list (cons 0 "BLOCK")(cons 2 Str_NwBlkNme)(cons 70 2)(cons 10 (list 0 0 0))))
     (foreach Ent_Item (GetBlockEnts Str_BkNme)
      (entmake (entget  Ent_Item))
    (entmake (list (cons 0 "ENDBLK")))
    (setq Pt_BkPt (cdr (assoc 10 Lst_EntInfo))
      Xscle (cdr (assoc 41 Lst_EntInfo))
      Yscle (cdr (assoc 42 Lst_EntInfo))
      Rotation (cdr (assoc 50 Lst_EntInfo))
      OldOs (getvar "osmode")
    (entdel Ent_BlkData)
    (setvar "osmode" 0)
    (vl-cmdf "_.Insert" Str_NwBlkNme Pt_BkPt Xscle Yscle (/(* 180 Rotation)pi))
    (setvar "osmode" OldOs)
 (princ "Invalid data, Please try again tommorro")
For Block Rename its very useful..But i dont want This Yes or No option(Rename all? : [YES/NO] ).So hw to remove that Yes or no option??(Rename all? : [YES/NO] )????????i want to update only selected block name..So here Yes or no option no need..So i want ro remove that option from ths lisp...plz help me
  • Replies 20
  • Lee Mac
    7
  • flowerrobot
    5
  • alanjt
    2
  • Lt Dan's legs
    2
