flowerrobot Posted December 20, 2009 Posted December 20, 2009 Thought some one could make use of this Will rename all blocks or just a single block, from selecting the target , Good for those random blocks or bad memory ;| Rename Blocks Created by FlowerRobot Created on 20/12/09 Rev 1.1 Will rename a single block or all blocks Rev history Rev 1.0 (unkown) Created Rev 1.1 20/12/09 Command defined simpler Varibles localised and tidy up |; (defun c:rre (/ Ent_BlkData Str_BkNme Str_NwBlkNme Bol_All Pt_BkPt Xscle Yscle Zscle Rotation OldOs Lst_EntInfo SS_1Block ;Subs *error* GetBlockEnts ) (defun *error* (Str_ErrorMsg /) (if ErrorDump (princ Str_ErrorMsg)) (vl-cmdf "_.undo" "_end") (vl-cmdf "_.undo" "1") (princ "An error accured exiting") (setvar "cmdecho" 1) (princ) ) (vl-load-com) (setvar "cmdecho" 0) (vl-cmdf "_.undo" "_begin") (defun GetBlockEnts (Str_BkNme / Ent_Blk lst_Item Ent_Nxt) (setq Ent_Blk (cdr (assoc -2 (tblsearch "block" Str_BkNme))) lst_Item (list (cdr (assoc -1(entget Ent_Blk)))) Ent_Nxt (entnext Ent_Blk)) (while Ent_Nxt (setq lst_Item (append (list(cdr (assoc -1(entget Ent_Nxt))))lst_Item) Ent_Nxt (entnext Ent_Nxt)) ) lst_Item ) (princ "\nSelect Block") (if(and (setq SS_1Block (ssget ":S" '((0 . "INSERT")))) (< 0 (strlen (setq Str_NwBlkNme (getstring "\nWhat is new name: ")))) ) (progn (setq Ent_BlkData (ssname SS_1Block 0) Lst_EntInfo (entget Ent_BlkData) Str_BkNme (cdr (assoc 2 Lst_EntInfo)) ) (initget 0 "YES NO") (cond ((tblsearch "block" Str_NwBlkNme) (princ (strcat "A Block \"" Str_NwBlkNme "\" already exists"))) ((if (= "NO" (getkword "\nRename all? : [YES/NO] <YES>")) nil t) (vl-cmdf "_Rename" "Block" Str_BkNme Str_NwBlkNme)) (t (entmake (list (cons 0 "BLOCK")(cons 2 Str_NwBlkNme)(cons 70 2)(cons 10 (list 0 0 0)))) (foreach Ent_Item (GetBlockEnts Str_BkNme) (entmake (entget Ent_Item)) ) (entmake (list (cons 0 "ENDBLK"))) (setq Pt_BkPt (cdr (assoc 10 Lst_EntInfo)) Xscle (cdr (assoc 41 Lst_EntInfo)) Yscle (cdr (assoc 42 Lst_EntInfo)) Rotation (cdr (assoc 50 Lst_EntInfo)) OldOs (getvar "osmode") ) (entdel Ent_BlkData) (setvar "osmode" 0) (vl-cmdf "_.Insert" Str_NwBlkNme Pt_BkPt Xscle Yscle (/(* 180 Rotation)pi)) (setvar "osmode" OldOs) ) ) ) (princ "Invalid data, Please try again tommorro") ) (vl-cmdf "_.undo" "_end") (setvar "cmdecho" 1) (princ) ) Quote
Lee Mac Posted December 20, 2009 Posted December 20, 2009 Similar thread: http://www.cadtutor.net/forum/showthread.php?t=36729 Quote
flowerrobot Posted December 20, 2009 Author Posted December 20, 2009 Ahh lee, Here i thought i wasted my time again, Least mine will change an inderivual block Wish i had seen the thread earlyer tho, would of approched it differently Quote
Lee Mac Posted December 20, 2009 Posted December 20, 2009 What if the user fails to select a block? I can see lselstp nil coming... :wink: Quote
flowerrobot Posted December 20, 2009 Author Posted December 20, 2009 Then there stupied idoits who deserve the error for not selecting the right thing Excuse my harshness but im one of those who belive in suvival of the fittest... If some one dumbenought to do it, Dont make a law against it we would be better with out them , Quote
Lee Mac Posted December 20, 2009 Posted December 20, 2009 Then there stupied idoits who deserve the error for not selecting the right thing Excuse my harshness but im one of those who belive in suvival of the fittest... If some one dumbenought to do it, Dont make a law against it we would be better with out them , I'm not looking at it with that viewpoint, but from the perspective of proper programming technique. EDIT: Also, watch the parentheses on your COND statement :wink: Quote
flowerrobot Posted December 21, 2009 Author Posted December 21, 2009 I can understand what you saying, But im too lasy/Not enough fee time, to really do it propperly on simple code, Dont get me wrong i do it on propper(larger) programs. yer i get caught by that some time , when you have txt in two places editing them both causes errors , I kno, Shouldnt use two softwares but once has nice fonts/background, the other a debu-ger but you are right, I spent that dreaded 2min and added error control code updated Quote
alanjt Posted December 21, 2009 Posted December 21, 2009 A simple and statement goes a long way. I can understand what you saying, But im too lasy/Not enough fee time, to really do it propperly on simple code, Dont get me wrong i do it on propper(larger) programs. yer i get caught by that some time , when you have txt in two places editing them both causes errors , I kno, Shouldnt use two softwares but once has nice fonts/background, the other a debu-ger but you are right, I spent that dreaded 2min and added error control code updated Quote
Lee Mac Posted December 21, 2009 Posted December 21, 2009 I can understand what you saying, But im too lasy/Not enough fee time, to really do it propperly on simple code, Dont get me wrong i do it on propper(larger) programs. Well, if something is worth doing, its worth doing properly, and if it is such "simple code", then why does it contain so many errors... Quote
flowerrobot Posted December 21, 2009 Author Posted December 21, 2009 Well, if something is worth doing, its worth doing properly, and if it is such "simple code", then why does it contain so many errors... Where does leaving an extra ')' and no error trapping count as so many errors Quote
alanjt Posted December 22, 2009 Posted December 22, 2009 Where does leaving an extra ')' and no error trapping count as so many errors In the land of swirly twirlies and gumdrops. Quote
merlin_m007 Posted December 24, 2009 Posted December 24, 2009 Pls help me with a Auto cad lisp programme which find and replaces attribute values in autocad attributes eg if the VALUES of different attributes are CAXXXXYYYY001,CAXXXXYYYY002,CAXXXXYYYY003 etc then I would like to replace 2nd letter 'C' with letter 'D' thus it becomes CDXXXXYYYY001,CDXXXXYYYY002,CDXXXXYYYY003 etc already got one .exe programme but system security does not allow me to install the programme to my system thats y I badly need a lisp kindly help thanks in advance pls send the code to rajtoms@saudia.com Merlin Menaco Quote
gilsoto13 Posted December 24, 2009 Posted December 24, 2009 Pls help me with a Auto cad lisp programme which find and replaces attribute values in autocad attributes eg if the VALUES of different attributes are CAXXXXYYYY001,CAXXXXYYYY002,CAXXXXYYYY003 etc then I would like to replace 2nd letter 'C' with letter 'D' thus it becomes CDXXXXYYYY001,CDXXXXYYYY002,CDXXXXYYYY003 etc already got one .exe programme but system security does not allow me to install the programme to my system thats y I badly need a lisp kindly help thanks in advance pls send the code to rajtoms@saudia.com Merlin Menaco I think there's no need for a lisp.. Command "Find" can find and replace text on attributes, at leat in autocad 2009 it does. Quote
Astro Posted April 22, 2010 Posted April 22, 2010 Thought some one could make use of this Will rename all blocks or just a single block, from selecting the target , Good for those random blocks or bad memory ;| Rename Blocks Created by FlowerRobot Created on 20/12/09 Rev 1.1 Will rename a single block or all blocks Rev history Rev 1.0 (unkown) Created Rev 1.1 20/12/09 Command defined simpler Varibles localised and tidy up |; (defun c:rre (/ Ent_BlkData Str_BkNme Str_NwBlkNme Bol_All Pt_BkPt Xscle Yscle Zscle Rotation OldOs Lst_EntInfo SS_1Block ;Subs *error* GetBlockEnts ) (defun *error* (Str_ErrorMsg /) (if ErrorDump (princ Str_ErrorMsg)) (vl-cmdf "_.undo" "_end") (vl-cmdf "_.undo" "1") (princ "An error accured exiting") (setvar "cmdecho" 1) (princ) ) (vl-load-com) (setvar "cmdecho" 0) (vl-cmdf "_.undo" "_begin") (defun GetBlockEnts (Str_BkNme / Ent_Blk lst_Item Ent_Nxt) (setq Ent_Blk (cdr (assoc -2 (tblsearch "block" Str_BkNme))) lst_Item (list (cdr (assoc -1(entget Ent_Blk)))) Ent_Nxt (entnext Ent_Blk)) (while Ent_Nxt (setq lst_Item (append (list(cdr (assoc -1(entget Ent_Nxt))))lst_Item) Ent_Nxt (entnext Ent_Nxt)) ) lst_Item ) (princ "\nSelect Block") (if(and (setq SS_1Block (ssget ":S" '((0 . "INSERT")))) (< 0 (strlen (setq Str_NwBlkNme (getstring "\nWhat is new name: ")))) ) (progn (setq Ent_BlkData (ssname SS_1Block 0) Lst_EntInfo (entget Ent_BlkData) Str_BkNme (cdr (assoc 2 Lst_EntInfo)) ) (initget 0 "YES NO") (cond ((tblsearch "block" Str_NwBlkNme) (princ (strcat "A Block \"" Str_NwBlkNme "\" already exists"))) ((if (= "NO" (getkword "\nRename all? : [YES/NO] <YES>")) nil t) (vl-cmdf "_Rename" "Block" Str_BkNme Str_NwBlkNme)) (t (entmake (list (cons 0 "BLOCK")(cons 2 Str_NwBlkNme)(cons 70 2)(cons 10 (list 0 0 0)))) (foreach Ent_Item (GetBlockEnts Str_BkNme) (entmake (entget Ent_Item)) ) (entmake (list (cons 0 "ENDBLK"))) (setq Pt_BkPt (cdr (assoc 10 Lst_EntInfo)) Xscle (cdr (assoc 41 Lst_EntInfo)) Yscle (cdr (assoc 42 Lst_EntInfo)) Rotation (cdr (assoc 50 Lst_EntInfo)) OldOs (getvar "osmode") ) (entdel Ent_BlkData) (setvar "osmode" 0) (vl-cmdf "_.Insert" Str_NwBlkNme Pt_BkPt Xscle Yscle (/(* 180 Rotation)pi)) (setvar "osmode" OldOs) ) ) ) (princ "Invalid data, Please try again tommorro") ) (vl-cmdf "_.undo" "_end") (setvar "cmdecho" 1) (princ) ) Thanks FlowerRobot, this is exactly what i was looking for Quote
Boxer Posted August 6, 2010 Posted August 6, 2010 Thanks for the routine; I found it helpful for what I need. The only thing I have to say is to remember to use quotes around your block name if your new block name has spaces in it. Quote
Lee Mac Posted August 6, 2010 Posted August 6, 2010 Perhaps also useful: http://www.cadtutor.net/forum/showthread.php?48840-CopyBlock-COPIES-THE-SELECTED-BLOCK-WITH-A-NEW-NAME Or, using the same principle: Copy Block.lsp Quote
Lt Dan's legs Posted August 9, 2010 Posted August 9, 2010 What if the user fails to select a block? I can see lselstp nil coming... :wink: Hi Lee! how do you prevent an error when user fail's to select a block? I tried but failed (defun c:BNUM (/ wait ent all) (setq wait t) (while wait (setq ent (entget (car (entsel"\nSelect block to count: ")))) (if (or(/= (cdr (assoc 0 ent)) "INSERT")(= ent nil)) (prompt "\n**Please select a block!**") (setq wait nil)) ) (setq all (ssget "_x" (list (assoc 2 ent)))) (alert (strcat "\nThere's (" (itoa (sslength all)) ") " (cdr (assoc 2 ent)) " block(s) in this drawing.\n\n **Created by Reid B.** ")) (princ) ) Edit: Also wondering, why will this LISP work for some dynamic blocks and not others? Quote
Lee Mac Posted August 9, 2010 Posted August 9, 2010 You need to check that the selection set is valid before using any selection set manipulation functions on it, as such examples as "(sslength nil)" will error. (defun c:bNum ( / e ss ) (while (not (and (setq e (car (entsel "\nSelect Block to Count: "))) (eq "INSERT" (cdr (assoc 0 (setq e (entget e))))) ) ) (princ "\n** Invalid Selection **") ) (if (setq ss (ssget "_X" (list (assoc 0 e) (assoc 2 e)))) (alert (strcat "\nThere " (if (< 1 (setq n (sslength ss))) "are " "is ") (itoa n) " " (cdr (assoc 2 e)) " block" (if (< 1 n) "s" "") " in this drawing." ) ) ) (princ) ) As for DynBlocks, when the visibility state changes, they are transformed into anonymous blocks. Check my 'Upgraded BCount' program. Quote
