Do you guys localize ALL your variables in a function? It seems like a pain in the ass, especially for larger functions with a lot of counter variables and such.
Yes, of couse. Except when you specifically need a variable to stay Global - to store settings etc.
Just use the Checking function in the VLIDE to gather up all the variables in one click. :)
  • Replies 66
  • Lee Mac
    22
  • alanjt
    15
  • bubba74
    15
  • LEsq
    8
Ok guys I'll give it a try. Thanks. :)
Always. Good practice is the best practice.
Unlocalised variables can cause some major problems when you are self-referencing variables, for example:
(defun c:test ( )
 (setq i 1)
 (repeat 10 (setq lst (cons (setq i (1+ i)) lst)))
 (print lst)
 (princ))
Run the above twice.
Now localise its variables and run it twice.
You can see the consequences of such things. :)
(defun c:test ( )
 (setq i 1)
 (print lst)
 (princ))
Excellent choice, cons is a great example.
I know... I've been caught out by it many times :oops:
This may be more robust for you :)
(defun c:test (/ v-move i ss selBlock SelnoBlock ent trck )
 (defun v-move (ss p1 p2 / i ent)
   (vl-load-com) (setq i -1)
   (while (setq ent (ssname ss (setq i (1+ i))))
     (vla-move (vlax-ename->vla-object ent)
               (vlax-3D-point p1)
               (vlax-3D-point p2)))
   ss)
 (if (setq i -1 ss (ssget "_:L"))
     (setq SelBlock (ssadd) SelNoblock (ssadd))
       (if (assoc 66 (entget ent))
         (ssadd ent selblock)
         (ssadd ent selnoblock)))
     (if (not (zerop (sslength selnoblock)))
         (setq trck (entmakex '((0 . "POINT") (10 0 0 0))))
         (sssetfirst nil selnoblock)
         (c:kti_archt_move)
         (if (not (zerop (sslength selblock)))
           (v-move selblock '(0 0 0) (cdr (assoc 10 (entget trck)))))
         (entdel trck))
       (command "_.move" selblock "" pause pause))))
 (princ))
{ untested }
Dear Lee,
I need your help so much to learn v-lisp.
1. why you used always the command "_.move" "_:L" instead of "move" and "L". Can you explain clearly the difference?
2. Can you explain about error trapping? and how we can catch if the user press the "esc" key while execution of the program? In this case, how the error trap will help to re-set the default settings such as osnap, etc..
3. How you learn V-lisp or through which source? can you give me some of your tested codes? and give me some link or reference books to learn v-lisp?
4.I have seen some of your codes in which you have used the combination of mapcar,function and lambda. What is the purpose and how it works? I used only the mapcar and lambda..
5.I have to know the effective list handling procedure. So post your codes regarding this issue.
6. Is any way to find and put the local variables?
I will post something later.
Thank you and help me lee.
"_" is language compatibility
"." uses the undefined function
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=2425
http://www.afralisp.net/lispa/lisp6.htm
To be honest, I learnt pretty much all of my Visual LISP through the forums, and also from the Visual LISP Editor Help files.
(setq lst '(1 2 3))
(mapcar '(lambda (x) (nth x lst)) '(0 2))
Is the same, but slower than@
(setq lst '(1 2 3))
(mapcar (function (lambda (x) (nth x lst))) '(0 2))
Its just like doing this:
(setq lst (quote (1 2 3)))
Instead of
(setq lst '(1 2 3))
http://mitpress.mit.edu/sicp/full-text/book/book-Z-H-4.html
http://www.cs.cmu.edu/afs/cs.cmu.edu/project/ai-repository/ai/html/cltl/clm/node1.html
Yes, read the help file on "defun".
Also, look into the Checking feature in the Visual LISP Editor.
