Sorry, I have no experience with visual lisp. Why does this benefit me?
If you are referring to my code, I have included the first IF statement to prevent an error if nothing is selected.
I have modified the "tracking point" section.
I have changed the way you filter the two selection sets.
The vla-move is 10x quicker than (command...
Lee
  • Replies 66
  • Lee Mac
    22
  • alanjt
    15
  • bubba74
    15
  • LEsq
    8
Great, thanks Lee. I'm at Revision 1 right now. If all goes well, I will comment the code and look at improving.
Not a problem, just adding my suggestions :)
Your code is much more refined than mine. How long did it take you to write that? ;-)
About 5 mins... its just practice :)
Here's an example I did that will mimic the COPY command (could be easily modified to MOVE). It uses the Express Tool acet-ss-move-drag subroutine to make things a little nicer. Its purpose was to return a selection set of the newly copied objects.
;;; Copy Command and return selectionset
;;; Requires Express Tools' ACET-SS-Drag-Move subroutine
;;; Alan J. Thompson, 11.09.09
(defun AT:Copy (/ #SS #Pnt1 #Pnt2 #Pnts #SSAdd #Copy)
 (cond
   ((and (setq #SS (ssget "_:L"))
         (setq #Pnt1 (getpoint "\nSpecify base point: "))
         (setq #Pnt2 (acet-ss-drag-move #SS #Pnt1 "\nSpecify placement point: " T))
    ) ;_ and
    (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
    (setq #Pnts (mapcar '(lambda (x) (vlax-3d-point (trans x 1 0)))
                        (list #Pnt1 #Pnt2)
                ) ;_ mapcar
    ) ;_ setq
    (setq #SSAdd (ssadd))
    (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*))
      (ssadd (vlax-vla-object->ename (setq #Copy (vla-copy x))) #SSAdd)
      (vla-move #Copy (car #Pnts) (cadr #Pnts))
    ) ;_ vlax-for
    (vl-catch-all-apply 'vla-delete (list #SS))
   ) ;_ cond
 ) ;_ cond
 #SSAdd
) ;_ defun
Lee, I'm surprised you didn't suggest your version of acet-ss-drag-move.
I didn't think it was necessary... The kti_archt_move does the moving, and the second selection set then has a known base pt and displacement vector.
Else, (command "_.move"... pause pause) was sufficient for the remaining selection set.
I just don't like to use "move" ... pause pause. If the user right-clicks on either pause, it will use 0,0,0. At least it does on newer version. I'm not sure when they introduced it.
Command: m MOVE
Select objects: Specify opposite corner: 1 found
Select objects:
Specify base point or [Displacement] <Displacement>:
Specify displacement <0.00, 0.00, 0.00>:
I understand, but this just seemed overkill in this situation... o:)
I completely agree with you. I was only stating that I was surprised you didn't suggest it.
I will say, that if the user has access to acet-ss-drag-move, I suggest it over "move" ... pause pause any day.
I suppose something like this then:
(defun acet-move (ss pt prmpt / v-move dpt)
 (defun v-move (ss p1 p2 / i ent)
   (vl-load-com) (setq i -1)
   (while (setq ent (ssname ss (setq i (1+ i))))
     (vla-move (vlax-ename->vla-object ent)
               (vlax-3D-point p1)
               (vlax-3D-point p2))) ss)
 (and (vl-catch-all-error-p
        (setq dpt
          (vl-catch-all-apply 'acet-ss-drag-move
            (list ss pt prmpt t 0))))
      (setq dpt pt))
 (v-move ss pt dpt))
(defun c:test (/ ss pt)
 (if (and (setq ss (ssget "_:L"))
          (setq pt (getpoint "\nBase Point: ")))
   (acet-move ss pt "\nMove Objects..."))
 (princ))
Many moons ago wrote the below function, could be of a good use, never knows.
;; usage: (blk-drag-move "Specify second point of displacement: " new_obj)
;; block drag move
(defun blk-drag-move  (msg obj / take code5 p3)
 (prompt (strcat "\n"
   (cond (msg)
  ("Move"))
   "\n"))
 (while (and (setq take (grread 't 15)) (/= 3 (car take)))
   (setq code5 (car take)
  p3 (cadr take))
   (if (and p3 (= 5 code5))
     (vla-move
obj
(vla-get-insertionpoint obj)
(vlax-3d-point p3)))))
ps> to bad most of my lisp stuff it is gone....
Luis, you could shrink that to this :)
;; block drag move
 (prompt (strcat "\n" (cond (msg) ("Move")) "\n"))
   (setq code5 (car take) p3 (cadr take))
     (vla-put-insertionpoint obj (vlax-3d-point p3)))))
;; block drag move
Yep... the beauty of lisp... and about 12 years aprox. later...
Good!
Good!
LoL
Come one Lee, you forgot to remove the (if statement. :wink:
    ([color=Red]if[/color] (and p3 (= 5 code5))
haha
   (and (= (car take) 5) (vla-put-insertionpoint obj (vlax-3d-point (cadr take))))))
:D
We are such nerds. LoL
(defun blk-drag-move (msg obj / take)
                 (cond (msg)
                       ("Move")
                 ) ;_ cond
                 "\n"
         ) ;_ strcat
 ) ;_ prompt
 (while (eq 5 (car (setq take (grread 't 15))))
 ) ;_ while
) ;_ defun
haha
:D
Again the beauty of lisp...
I have so far in the project I am working on one of the classes 10,620 lines of code (C#)
LoL
Do you even code in Lisp anymore Luis? I know you are a monster with C (based on what I've seen at theswamp).
LoL
I've seen some of your sigs on theSwamp Luis... saying how "mickey mouse" your LISP is lol :P
But yeah, your C is awesome :shock:
