AQucsaiJr Posted December 17, 2009 Posted December 17, 2009 So here is the deal, I have a list of bogus layers that exist in a bunch of drawings that need to be merged into the correct layer. I tried writing a script for this but not all the drawings have the bogus layers so the script gets stuck every time it reaches a layer that is not in the drawing. It is not a time saver to have to resume the script after every pause. Anyone know of a lisp or other type of program that can do this? I have attached the script I wrote up if maybe I can make some changes to it to have it work. PurgeAll.scr Quote
AQucsaiJr Posted December 17, 2009 Author Posted December 17, 2009 The script I wrote calls out the built in layer merge command. My problem is there are so many drawings that need this fix that I wanted to make this a batch file, however the script I wrote gets stuck to often and is not a time saver. Quote
alanjt Posted December 17, 2009 Posted December 17, 2009 You could try something like this: (defun MergeLayers (#OldLayers #NewLayers / #Layers) (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (mapcar '(lambda (o n) (and (tblsearch "layer" o) (or (tblsearch "layer" n) (vla-add #Layers n)) (vl-cmdf "_.-laymrg" "_n" o "" "_n" n "_y") ) ;_ and ) ;_ lambda #OldLayers #NewLayers ) ;_ mapcar ) ;_ defun Example: (MergeLayers '("A" "B" "C" "D") '("1" "2" "3" "4")) Quote
Lee Mac Posted December 17, 2009 Posted December 17, 2009 A touch quicker: (defun MergeLayers (#OldLayers #NewLayers) (setq #Layers (cond (#Layers) ((vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))))) (mapcar (function (lambda (o n) (and (tblsearch "layer" o) (or (tblsearch "layer" n) (vla-add #Layers n)) (vl-cmdf "_.-laymrg" "_n" o "" "_n" n "_y")))) #OldLayers #NewLayers)) Quote
alanjt Posted December 17, 2009 Posted December 17, 2009 Is there any benefit to (function over '( ? I thought about making the vla-get-layers global, but it seemed pointless since it would only be run once per drawing. A touch quicker: (defun MergeLayers (#OldLayers #NewLayers) (setq #Layers (cond (#Layers) ((vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))))) (mapcar (function (lambda (o n) (and (tblsearch "layer" o) (or (tblsearch "layer" n) (vla-add #Layers n)) (vl-cmdf "_.-laymrg" "_n" o "" "_n" n "_y")))) #OldLayers #NewLayers)) Quote
alanjt Posted December 17, 2009 Posted December 17, 2009 Just because I was curious: Command: (benchmark '( (tl) (ta) )) Elapsed milliseconds / relative speed for 32768 iteration(s): (TL).....1578 / 1.01 <fastest> (TA).....1593 / 1 <slowest> Command: (benchmark '( (tl) (ta) )) Elapsed milliseconds / relative speed for 32768 iteration(s): (TL).....1594 / 1 <fastest> (TA).....1594 / 1 <slowest> Command: (benchmark '( (tl) (ta) )) Elapsed milliseconds / relative speed for 32768 iteration(s): (TL).....1593 / 1 <fastest> (TA).....1594 / 1 <slowest> (defun tl () (setq #Layers (cond (#Layers) ((vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))))) (defun ta () (or #Layers (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))))) Quote
wizman Posted December 17, 2009 Posted December 17, 2009 try to benchmark it alan. i think vovka on theswamp is the one who pointed that it makes it faster. Quote
alanjt Posted December 17, 2009 Posted December 17, 2009 try to benchmark it alan. i think vovka on theswamp is the one who pointedthat it makes it faster. Command: (benchmark '( (test1) (test2) )) Elapsed milliseconds / relative speed for 4096 iteration(s): (TEST1).....1625 / 1 <fastest> (TEST2).....1625 / 1 <slowest> Command: (benchmark '( (test1) (test2) )) Elapsed milliseconds / relative speed for 4096 iteration(s): (TEST1).....1625 / 1 <fastest> (TEST2).....1625 / 1 <slowest> Command: (benchmark '( (test1) (test2) )) Elapsed milliseconds / relative speed for 4096 iteration(s): (TEST1).....1609 / 1.02 <fastest> (TEST2).....1640 / 1 <slowest> Command: (benchmark '( (test1) (test2) )) Elapsed milliseconds / relative speed for 4096 iteration(s): (TEST1).....1609 / 1.01 <fastest> (TEST2).....1625 / 1 <slowest> (defun test1 (/) (repeat 10 (mapcar '(lambda (a b) (strcat a " " b)) '("A" "B" "C") '("1" "2" "3")))) (defun test2 (/) (repeat 10 (mapcar (function (lambda (a b) (strcat a " " b))) '("A" "B" "C") '("1" "2" "3")))) I need to run it on something a little more complex. Quote
Lee Mac Posted December 17, 2009 Posted December 17, 2009 Alan, The global #Layers will be much quicker when running the function through a mapcar statement Your (defun tl () (setq #Layers (cond (#Layers) ((vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))))) (defun ta () (or #Layers (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))))) Is not a valid comparison, as both have #Layers global. Quote
Lee Mac Posted December 17, 2009 Posted December 17, 2009 Elapsed milliseconds / relative speed for 65536 iteration(s): (TL).....1872 / 3.23 <fastest> (TA).....6053 / 1.00 <slowest> (defun ta (/ #Layers) (setq #Layers (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))) (defun tl ( ) (setq #Layers (cond (#Layers) ((vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))))) Quote
wizman Posted December 17, 2009 Posted December 17, 2009 I thought about making the vla-get-layers global, but it seemed pointless since it would only be run once per drawing. My apology lee but i have to agree with alan on this. Quote
alanjt Posted December 17, 2009 Posted December 17, 2009 Alan, The global #Layers will be much quicker when running the function through a mapcar statement Your (defun tl () (setq #Layers (cond (#Layers) ((vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))))) (defun ta () (or #Layers (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))))) Is not a valid comparison, as both have #Layers global. That test was out of curiosity of use of (cond vs. (or. I stated in my reason for not making it global. This would only be executed once per drawing, making the purpose of making it global pointless. The mapcar statement will only be executed after vla-get-layers is defined. Quote
Lee Mac Posted December 17, 2009 Posted December 17, 2009 My apology lee but i have to agree with alan on this. Upon looking more closely, I see that the #Layers is not accessed in the mapcar statment... not quite sure what I was going on about.. My apologies AJ - you are quite right. Quote
alanjt Posted December 17, 2009 Posted December 17, 2009 Upon looking more closely, I see that the #Layers is not accessed in the mapcar statment... not quite sure what I was going on about.. My apologies AJ - you are quite right. LoL No problem. Quote
AQucsaiJr Posted December 18, 2009 Author Posted December 18, 2009 You could try something like this: (defun MergeLayers (#OldLayers #NewLayers / #Layers) (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (mapcar '(lambda (o n) (and (tblsearch "layer" o) (or (tblsearch "layer" n) (vla-add #Layers n)) (vl-cmdf "_.-laymrg" "_n" o "" "_n" n "_y") ) ;_ and ) ;_ lambda #OldLayers #NewLayers ) ;_ mapcar ) ;_ defun Example: (MergeLayers '("A" "B" "C" "D") '("1" "2" "3" "4")) I have been given a code in this form before however it was a while back and I am not sure how to initiate this code. Would it be something like this? (DEFUN C:MRGLAYR () (MergeLayers '("A" "B" "C" "D") '("1" "2" "3" "4")) (PRINC) ) (defun MergeLayers (#OldLayers #NewLayers / #Layers) (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (mapcar '(lambda (o n) (and (tblsearch "layer" o) (or (tblsearch "layer" n) (vla-add #Layers n)) (vl-cmdf "_.-laymrg" "_n" o "" "_n" n "_y") ) ;_ and ) ;_ lambda #OldLayers #NewLayers ) ;_ mapcar ) ;_ defun Quote
Lee Mac Posted December 18, 2009 Posted December 18, 2009 Either that, or, if running a script, you can just put this: (MergeLayers '("A" "B" "C" "D") '("1" "2" "3" "4")) In your script, or, just at the command line. Quote
AQucsaiJr Posted December 18, 2009 Author Posted December 18, 2009 Either that, or, if running a script, you can just put this: (MergeLayers '("A" "B" "C" "D") '("1" "2" "3" "4")) In your script, or, just at the command line. I can put this line in a script and it will run this lisp program? I didn't know that. So if I wrote the script like this: (MergeLayers '("A" "B" "C" "D") '("1" "2" "3" "4")) Zoom E QSAVE it would merge A-1, B-2, C-3, D-4, the Zoom to extents and save? Quote
AQucsaiJr Posted December 18, 2009 Author Posted December 18, 2009 Very nice... Ill give that a go... Thanks Quote
alanjt Posted December 18, 2009 Posted December 18, 2009 Very nice... Ill give that a go... Thanks Glad you got what you needed. Not that it's the best method, but you could even put everything into a .scr file and load it. (defun MergeLayers (#OldLayers #NewLayers / #Layers) (setq #Layers (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (mapcar '(lambda (o n) (and (tblsearch "layer" o) (or (tblsearch "layer" n) (vla-add #Layers n)) (vl-cmdf "_.-laymrg" "_n" o "" "_n" n "_y") ) ;_ and ) ;_ lambda #OldLayers #NewLayers ) ;_ mapcar ) (MergeLayers '("A" "B" "C" "D") '("1" "2" "3" "4")) Quote
