got7603 Posted July 15, 2015 Posted July 15, 2015 When using zwcad 2015 I get the message: Command: PTM ** Dialog File could not be Written ** Any comment? Thanks! Quote
Lee Mac Posted July 15, 2015 Author Posted July 15, 2015 When using zwcad 2015 I get the message: Command: PTM ** Dialog File could not be Written ** Any comment? Thanks! Save the attached DCL file to your support path (do not rename it). Lee LMAC_PtMan_V2.4.dcl Quote
Sideshow-Cad Posted June 10, 2016 Posted June 10, 2016 Hello, Thanks for the tool. Use it alot. Is there anyway when exporting to a csv to add a column for layer in addition to xyz? Thanks, Quote
thegreatkarthik67 Posted June 20, 2017 Posted June 20, 2017 omg..! I have searched a lot of these things individually but found in one..!!! GREAT..!! I have one query related to this, in my case: input type - LW polyline output type - have to place block with attribute - I have csv file block name with attributes is it possible to add above in it? Mr.Lee, thanks very much MK Quote
thegreatkarthik67 Posted June 20, 2017 Posted June 20, 2017 Hi, is it possible to merge option from this two lisp? Point Manager: http://lee-mac.com/ptmanager.html Automatically update attribute: http://lee-mac.com/autolabelattributes.html From this lisp "Point Manager" I can place block on each vertex of LW polyline and the same I want to do along with this lisp "Automatically update attribute". each block has attribute and it has to place 1,2,3... n goes is it possible? Quote
foster5476 Posted June 20, 2017 Posted June 20, 2017 Had a suggestion I wanted to throw out. I use Point Manager to insert blocks to the ends of plines. Sometimes ill have a pline with a lot of vertices and ill go back to delete the blocks on the middle vertices and rotate blocks at certain points. Is it possible to have an option to place only at the start, end or all vertices of the pline? Haven't found a way to insert blocks at more specific vertices. Not sure if this is too difficult to do just thought id throw it out see if one of you wizards knew how to do it. Not a big deal if not very happy with the program already! Thanks Lee really love the program! Quote
pkenewell Posted June 20, 2017 Posted June 20, 2017 Hi Lee, I have another suggestion that might be useful to some. Years back I wrote a program to get a selection of points and export them to a file, with the option to also create a TABLE in the current layout with the XYZ Coordinates. The option to add a TABLE from the point data would probably be a fairly easy add to the program. This is an excerpt from my original program (doesn't run on it's own - just a code snippet) (progn (setq nam (strcat (getvar "DWGPREFIX") (getvar "DWGNAME")) nam (strcat (substr nam 1 (- (strlen nam) 3)) "txt") fil (getfiled "Create Point List File..." nam "txt" 1) ) (if fil (progn (setq resp (nal-getinput "Create An AutoCAD Table in the active Layout?" "No" nil "Yes No")) (if (= resp "Yes") (progn (vla-put-activespace activedoc acPaperSpace) (setq pSpace (vla-get-PaperSpace activedoc)) (if (setq pt1 (getpoint "\nSelect a location for the table: ")) (progn (setq rows (+ 2 (sslength ss)) cols 2 tblobj (vla-addtable pspace (vlax-3D-point pt1) rows cols 1 63.5) ) (vla-settextheight tblobj acDataRow 3.5) (vla-settextheight tblobj acHeaderRow 5.0) (vla-settext tblobj 0 0 "INSPECTION POINT LIST:") (vla-settext tblobj 1 0 "POINT:") (vla-settext tblobj 1 1 "LOCATION:") ) (princ "\nTable Operation Canceled.") ) ) ) (setq ofil (open fil "w") cnt 0) (write-line "INSPECTION POINT LIST:\n" ofil) (repeat (sslength ss) (setq el (entget (ssname ss cnt)) s1 (cdr (assoc 10 el)) x (rtos (car s1)) y (rtos (cadr s1)) z (rtos (caddr s1)) cnt (1+ cnt) ) (write-line (strcat "Point " (itoa cnt)) ofil) (write-line (strcat "X=" x) ofil) (write-line (strcat "Y=" y) ofil) (write-line (strcat "Z=" z "\n") ofil) (if tblobj (progn (setq lin-col2 (strcat "X = " x "[url="file://\\PY"]\\PY[/url] = " y "[url="file://\\PZ"]\\PZ[/url] = " z)) (vla-setcellalignment tblobj (1+ cnt) 0 acMiddleCenter) (vla-settext tblobj (1+ cnt) 0 (strcat "SC" (itoa cnt))) (vla-setcellalignment tblobj (1+ cnt) 1 acMiddleLeft) (vla-settext tblobj (1+ cnt) 1 lin-col2) ) ) ) (close ofil) (startapp "notepad" fil) ) ) ) Quote
Ngai Chen Chong Posted January 3, 2018 Posted January 3, 2018 Hi Lee, what a great program it is. I used your program to extract points/blocks from LW/3D polylines for most of the time. Appreciate if you can show me how to get points/blocks created in the same layer as their respective LW/3D polylines at once, without extracting it layer by layer which might increase the chances for data missing. Thank you. Ngai Quote
sravani Posted April 4, 2019 Posted April 4, 2019 Hi Mr.Lee Mac, i am trying to use your PtManager.lsp file to update my 3Dsolid from excel this giving me line 23,24,165 errors. i am sorry i am still learner in lisp so please help. Thanks PtManagerV2-4(1).lsp Quote
Costinbos77 Posted April 4, 2019 Posted April 4, 2019 (edited) Great program Lee ! I have created something similar to this . But , unfortunately , I still have this problem . Any idea ? Edited April 28, 2019 by Costinbos77 Quote
