savydrake85 Posted August 8, 2008 Share Posted August 8, 2008 Okay. So I want to use a dashed linetype for my extension lines(which i can do), but i can't scale my extension lines so that i can actually see the "dashes." I have noticed that sometimes if my picture is too big(ex. i have lines in my drawing in excess of 1000 units) my dimension extension lines all appear to be solid lines. I have tried everything i can think of to make my extension lines appear dashed when i print, but nothing is working. If anybody can answer this question i will be ecstatic! Quote Link to comment Share on other sites More sharing options...
rustysilo Posted August 8, 2008 Share Posted August 8, 2008 Your drawing scale? Your lt scale? Quote Link to comment Share on other sites More sharing options...
CmdrDuh Posted August 8, 2008 Share Posted August 8, 2008 Im betting its LTScale, what scale is your viewport in paperspace? I use 0.6 * scale factor of viewport, but you sould use any number. I have seen 0.5 * SF and I have seen 1 * SF. Also, are you using Annotative dims and text? MSLTScale set to 1 will correctly scale linetypes based on the viewport scale with annotative objects. PSLTScale also needs to be turned to 1 if you want different scaled viewports to show the same linetype the same way. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted August 8, 2008 Share Posted August 8, 2008 Just out of curiosity, what type of drawing are you producing that has dashed extension lines? New to me... Quote Link to comment Share on other sites More sharing options...
Teeds Posted August 10, 2008 Share Posted August 10, 2008 Just out of curiosity, what type of drawing are you producing that has dashed extension lines? New to me... ditto that because dashed lines always reference hidden objects. I set my LTSCALE at 50% of my DIMSCALE. It is easy for feeble old brains Quote Link to comment Share on other sites More sharing options...
savydrake85 Posted August 14, 2008 Author Share Posted August 14, 2008 thank you all for your feedback... i am in the process of trying to figure it out. Quote Link to comment Share on other sites More sharing options...
savydrake85 Posted September 5, 2008 Author Share Posted September 5, 2008 thank you everyone! i figured it out.... it was my ltscale Quote Link to comment Share on other sites More sharing options...
