sroberts Posted December 2, 2009 Share Posted December 2, 2009 Hello I need help please I need a routine if possible to label a line with the name of its layer and place the text into drawing not just in the command line thanks for any help Sherry Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 2, 2009 Share Posted December 2, 2009 Modification of my existing routine: ;;;==========================[ MacAlign.lsp ]========================== ;;; Author: Copyright© 2009 Lee McDonnell (Lee Mac) ;;; (Contact @ CADTutor.net, The Swamp.org) ;;; Version: 1.0 June 13, 2009 ;;; 2.0 June 14, 2009 ;;; 3.0 June 16, 2009 ;;; 4.0 June 16, 2009 ;;; 5.0 July 22, 2009 ;;; Purpose: To Align Text to a Curve ;;; Sub_Routines: getpoint_or_text.lsp by Charles Alan Butler (CAB) ;;; ;;; Additional Features: ;;; Use +/- to Alter Text Offset ;;; Use "P" to toggle perpendicularity ;;;==================================================================== ;;; MODIFIED TO SET TEXT AS CURVE LAYER ;; (defun c:MacAlign (/ *error* doc spc tmp tStr ent cObj tObj gr cPt pt cAng lAng tSze ; *Mac$Str* } ; *Mac$tOff* } Global Variables ; *Mac$Per* } ) (vl-load-com) ;; Error Handler (defun *error* (msg) (and tObj (not (vlax-erased-p tObj)) (vla-delete tObj)) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " msg " >>"))) (redraw) (princ)) ;; Check for Locked Current Layer (if (eq 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar "CLAYER")))))) (progn (princ "\n<< Current Layer Locked >>") (exit))) ;; Get Space & Doc (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)) spc (if (zerop (vla-get-activespace doc)) (if (= (vla-get-mspace doc) :vlax-true) ; Vport (vla-get-modelspace doc) (vla-get-paperspace doc)) (vla-get-modelspace doc))) ;; Set First-time Defaults (or *Mac$Str* (setq *Mac$Str* "text")) (or *Mac$Per* (setq *Mac$Per* (/ pi 2.))) (or *Mac$tOff* (setq *Mac$tOff* 1.)) (or tSze (setq tSze (getvar "TEXTSIZE"))) ;; Get Curve to Align (while (progn (setq ent (nentsel "\nSelect Curve: ")) (cond ((and (vl-consp ent) (vl-position (cdr (assoc 0 (entget (car ent)))) '("LINE" "LWPOLYLINE" "POLYLINE" "ARC" "SPLINE" "CIRCLE" "ELLIPSE" "XLINE"))) (setq cObj (vlax-ename->vla-object (car ent))) nil) ; Exit Loop (t (princ "\nMissed, Try Again..."))))) ; Keep in Loop (setq tStr (vla-get-layer cObj)) ;; Create Text Object (vla-put-alignment (if tObj tObj (setq tObj (vla-addText spc tStr (vlax-3D-point '(0 0 0)) tSze))) acAlignmentMiddleCenter) (setq msg (princ "\n<< Type [+] or [-] for offset, and [P]erpendicular >>")) ;; Place Text (while (progn (setq gr (grread t 15 0)) (redraw) (cond ((and (eq 5 (car gr)) (listp (setq cPt (cadr gr)))) (setq pt (vlax-curve-getClosestPointto cObj cPt)) (if (and (< 0 (getvar "OSMODE") 16383) (setq osPt (osnap pt (osLst (getvar "OSMODE"))))) (osMark osPt)) (setq cAng (angle pt cPt) lAng (+ cAng *Mac$Per*)) ;; Correct Angle (cond ((and (> lAng (/ pi 2)) (<= lAng pi)) (setq lAng (- lAng pi))) ((and (> lAng pi) (<= lAng (/ (* 3 pi) 2))) (setq lAng (+ lAng pi)))) (vla-move tObj (vla-get-TextAlignmentPoint tObj) (vlax-3D-point (polar pt cAng (* tSze *Mac$tOff*)))) (vla-put-Rotation tObj lAng) t) ((eq 2 (car gr)) (cond ((vl-position (cadr gr) '(43 61)) (setq *Mac$tOff* (+ (/ 1 10.) *Mac$tOff*))) ((eq (cadr gr) 45) (setq *Mac$tOff* (- *Mac$tOff* (/ 1 10.)))) ((vl-position (cadr gr) '(80 112)) (setq *Mac$Per* (- (/ pi 2.) *Mac$Per*))) ((eq 6 (cadr gr)) (cond ((< 0 (getvar "OSMODE") 16384) (setvar "OSMODE" (+ 16384 (getvar "OSMODE"))) (princ (strcat "\n<Osnap off>" msg))) (t (setvar "OSMODE" (- (getvar "OSMODE") 16384)) (princ (strcat "\n<Osnap on>" msg)))) t) ((vl-position (cadr gr) '(13 32)) nil) (t))) ((eq 3 (car gr)) (if (and (< 0 (getvar "OSMODE") 16383) (setq osPt (osnap pt (osLst (getvar "OSMODE"))))) (progn (osMark osPt) (setq cAng (angle pt cPt) lAng (+ cAng *Mac$Per*)) ;; Correct Angle (cond ((and (> lAng (/ pi 2)) (<= lAng pi)) (setq lAng (- lAng pi))) ((and (> lAng pi) (<= lAng (/ (* 3 pi) 2))) (setq lAng (+ lAng pi)))) (vla-move tObj (vla-get-TextAlignmentPoint tObj) (vlax-3D-point (polar ospt cAng (* tSze *Mac$tOff*)))) (vla-put-Rotation tObj lAng))) nil) ((eq 25 (car gr)) nil) (t)))) (redraw) (princ)) (defun oSlst (os / str cnt) (setq str "" cnt 0) (if (< 0 os 16383) (foreach mod '("_end" "_mid" "_cen" "_nod" "_qua" "_int" "_ins" "_per" "_tan" "_nea" "_non" "_app" "_ext" "_par") (if (not (zerop (logand (expt 2 cnt) os))) (setq str (strcat str mod (chr 44)))) (setq cnt (1+ cnt)))) (vl-string-right-trim (chr 44) str)) (defun osMark (pt / drft osSz osCol ratio bold glst i) (setq drft (vla-get-drafting (vla-get-preferences (vlax-get-acad-object))) osSz (vla-get-AutoSnapMarkerSize drft) oscol (vla-get-AutoSnapMarkerColor drft) ratio (/ (getvar "VIEWSIZE") (cadr (getvar "SCREENSIZE"))) bold (mapcar (function (lambda (x) (* x ratio))) (list (+ osSz 0.5) osSz (- osSz 0.5))) i 0) (repeat 50 (setq glst (cons (polar '(0 0 0) (* i (/ pi 25.)) 1.) glst) i (1+ i))) (foreach x bold (grvecs (append (list oscol) glst (cdr glst) (list (car glst))) (list (list x 0.0 0.0 (car pt)) (list 0.0 x 0.0 (cadr pt)) (list 0.0 0.0 1.0 0.0) (list 0.0 0.0 0.0 1.0))))) (vl-load-com) Quote Link to comment Share on other sites More sharing options...
sroberts Posted December 3, 2009 Author Share Posted December 3, 2009 Lee, thank you so much it works great. I have a question is it possible to setup to select more than one line at a time, so i could label all at once? Thank you again Sherry Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 Lee, thank you so much it works great. I have a question is it possible to setup to select more than one line at a time, so i could label all at once? Thank you again Sherry Thanks Sherry, Multiple selection is not possible with the current placement method, as each text is aligned to each object, and so multiple text cannot be aligned simultaneously (without tons more code). If you wanted the text to be in a set position every time, then multiple selection can be achieved with relatively less code. Lee Quote Link to comment Share on other sites More sharing options...
sroberts Posted December 3, 2009 Author Share Posted December 3, 2009 Thanks Sherry, Multiple selection is not possible with the current placement method, as each text is aligned to each object, and so multiple text cannot be aligned simultaneously (without tons more code). If you wanted the text to be in a set position every time, then multiple selection can be achieved with relatively less code. Lee Hi Lee If you don't mind revising the one for less code so it is in a set position, I would greatly appreciate it. Thank you Sherry Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 Hi LeeIf you don't mind revising the one for less code so it is in a set position, I would greatly appreciate it. Thank you Sherry It would have to be a new program, but I don't mind if I have the time. Where would the fixed position be? The midpoint of the line? Quote Link to comment Share on other sites More sharing options...
sroberts Posted December 3, 2009 Author Share Posted December 3, 2009 It would have to be a new program, but I don't mind if I have the time. Where would the fixed position be? The midpoint of the line? The midpoint would be good. I will use both programs just for different applications. Thank you so much for taking the time to do all this. Sherry Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 Please try this: ;; LayText.lsp by Lee McDonnell, 03.12.2009 ;; Function will display layer information ;; at midpoint of every line selected. (defun c:LayText (/ *error* mk_txt DOC ENT I IPT LANG OFAC P SPC SS TOBJ TSZE UFLAG) (vl-load-com) (setq oFac 0.7) ;; Offset Factor (setq tSze nil) ;; Text Size ~ nil for TEXTSIZE Variable (defun *error* (msg) (and uFlag (vla-EndUndoMark doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) (defun mk_txt (p v) (vla-addText spc v (vlax-3D-point p) tSze)) (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)) spc (if (zerop (vla-get-activespace doc)) (if (= (vla-get-mspace doc) :vlax-true) (vla-get-modelspace doc) (vla-get-paperspace doc)) (vla-get-modelspace doc))) (or tSze (setq tSze (getvar "TEXTSIZE"))) (if (setq i -1 ss (ssget '((0 . "*LINE,ARC,CIRCLE,ELLIPSE")))) (progn (setq uFlag (not (vla-StartUndoMark doc))) (while (setq ent (ssname ss (setq i (1+ i)))) (setq iPt (vlax-curve-getPointatDist ent (/ (- (vlax-curve-getDistatParam ent (vlax-curve-getEndParam ent)) (vlax-curve-getDistatParam ent (vlax-curve-getStartParam ent))) 2.))) (setq lAng (angle '(0 0 0) (vlax-curve-getFirstDeriv ent (vlax-curve-getParamatPoint ent iPt)))) (if (equal lAng (/ pi 2.) 0.001) (setq lAng (/ pi 2.))) (if (equal lAng (/ (* 3 pi) 2.) 0.001) (setq lAng (/ (* 3 pi) 2.))) (cond ( (and (> lAng (/ pi 2)) (<= lAng pi)) (setq lAng (- lAng pi))) ( (and (> lAng pi) (<= lAng (/ (* 3 pi) 2))) (setq lAng (+ lAng pi)))) (setq tObj (mk_txt (setq p (polar iPt (+ lAng (/ pi 2.)) (* oFac tSze))) (vla-get-Layer (vlax-ename->vla-object ent)))) (vla-put-Alignment tObj acAlignmentMiddleCenter) (vla-put-TextAlignmentPoint tObj (vlax-3D-point p)) (vla-put-Rotation tObj lAng)) (setq uFlag (vla-EndUndoMark doc)))) (princ)) Quote Link to comment Share on other sites More sharing options...
sroberts Posted December 3, 2009 Author Share Posted December 3, 2009 Please try this: ;; LayText.lsp by Lee McDonnell, 03.12.2009 ;; Function will display layer information ;; at midpoint of every line selected. (defun c:LayText (/ *error* mk_txt DOC ENT I IPT LANG OFAC P SPC SS TOBJ TSZE UFLAG) (vl-load-com) (setq oFac 0.7) ;; Offset Factor (setq tSze nil) ;; Text Size ~ nil for TEXTSIZE Variable (defun *error* (msg) (and uFlag (vla-EndUndoMark doc)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) (defun mk_txt (p v) (vla-addText spc v (vlax-3D-point p) tSze)) (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)) spc (if (zerop (vla-get-activespace doc)) (if (= (vla-get-mspace doc) :vlax-true) (vla-get-modelspace doc) (vla-get-paperspace doc)) (vla-get-modelspace doc))) (or tSze (setq tSze (getvar "TEXTSIZE"))) (if (setq i -1 ss (ssget '((0 . "*LINE,ARC,CIRCLE,ELLIPSE")))) (progn (setq uFlag (not (vla-StartUndoMark doc))) (while (setq ent (ssname ss (setq i (1+ i)))) (setq iPt (vlax-curve-getPointatDist ent (/ (- (vlax-curve-getDistatParam ent (vlax-curve-getEndParam ent)) (vlax-curve-getDistatParam ent (vlax-curve-getStartParam ent))) 2.))) (setq lAng (angle '(0 0 0) (vlax-curve-getFirstDeriv ent (vlax-curve-getParamatPoint ent iPt)))) (if (equal lAng (/ pi 2.) 0.001) (setq lAng (/ pi 2.))) (if (equal lAng (/ (* 3 pi) 2.) 0.001) (setq lAng (/ (* 3 pi) 2.))) (cond ( (and (> lAng (/ pi 2)) (<= lAng pi)) (setq lAng (- lAng pi))) ( (and (> lAng pi) (<= lAng (/ (* 3 pi) 2))) (setq lAng (+ lAng pi)))) (setq tObj (mk_txt (setq p (polar iPt (+ lAng (/ pi 2.)) (* oFac tSze))) (vla-get-Layer (vlax-ename->vla-object ent)))) (vla-put-Alignment tObj acAlignmentMiddleCenter) (vla-put-TextAlignmentPoint tObj (vlax-3D-point p)) (vla-put-Rotation tObj lAng)) (setq uFlag (vla-EndUndoMark doc)))) (princ)) Lee, I recieved this message when trying to use the lisp ** Error: bad argument type: numberp: nil ** Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 Hmmm... I tested it quick and it worked my end, but I shall take another lookie Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 Just tested it again, I can't seem to get it to fail... At what point does the message occur? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 Could anyone else test the posted code to see if it errors? :wink: Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 3, 2009 Share Posted December 3, 2009 Could anyone else test the posted code to see if it errors? :wink: Other than the text being tiny (Annotative), it works fine for me. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 Other than the text being tiny (Annotative), it works fine for me. I just used TEXTSIZE variable, but gave the option at the top of the code... but glad it doesn't error Quote Link to comment Share on other sites More sharing options...
sroberts Posted December 3, 2009 Author Share Posted December 3, 2009 Just tested it again, I can't seem to get it to fail... At what point does the message occur? Okay back from lunch I retested and it works if i select one line at a time but I can't window those lines or i get this message ** Error: bad argument type: numberp: nil ** and thats okay i can use it that way thanks Sherry Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 3, 2009 Share Posted December 3, 2009 I just used TEXTSIZE variable, but gave the option at the top of the code... but glad it doesn't error Just stating what happened. There's nothing wrong with the code. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 Okay back from lunchI retested and it works if i select one line at a time but I can't window those lines or i get this message ** Error: bad argument type: numberp: nil ** and thats okay i can use it that way thanks Sherry That is really weird... there should be nothing to say you cannot window the lines... I have never come across that before Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 3, 2009 Share Posted December 3, 2009 That is really weird... there should be nothing to say you cannot window the lines... I have never come across that before News to me. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 3, 2009 Share Posted December 3, 2009 PICKAUTO maybe? But it shouldn't cause an error.. Quote Link to comment Share on other sites More sharing options...
sroberts Posted December 3, 2009 Author Share Posted December 3, 2009 PICKAUTO maybe? But it shouldn't cause an error.. Okay I did a reboot and it seems to be working now. sorry i should have thought of that first. thank you for your time and patiences Sherry Quote Link to comment Share on other sites More sharing options...
