Lisp for Automatic Draw Order Command to a specific Layer.
here's for blocks:
(defun c:blklayerorder (/ od_blk od_ent)
   (vl-load-com)
   (foreach od_lay
                   (reverse '("LAYER1" ; topmost
                              "LAYER2"
                              "LAYER3" ; bottom
                   ) ;_ {reverse
       (if
           (tblsearch "LAYER" od_lay)
              (while
                  (setq od_blk (tblnext "block" (null od_blk)))
                     (setq od_ent (tblobjname "block" (cdr (assoc 2 od_blk))))
                     (while (Setq od_ent (entnext od_ent))
                         (if (eq (cdr (assoc 8 (entget od_ent))) (strcase od_lay))
                             (vl-catch-all-apply
                                 (function
                                     (lambda ()
                                         (vla-MoveTotop
                                             (vla-AddObject
                                                 (vla-GetExtensionDictionary
                                                     (vla-item
                                                         (vla-get-blocks
                                                             (vla-get-ActiveDocument
        (vlax-get-acad-object
                                                             ) ;_ {vla-get-ActiveDocument
                                                         ) ;_ {vla-get-ModelSpace
                                                     ) ;_ {vla-GetExtensionDictionary
                                                 "ACAD_SORTENTS"
                                                 "AcDbSortentsTable"
                                             ) ;_ {vla-AddObject
                                             (vlax-make-variant
                                                 (vlax-safearray-fill
                                                     (vlax-make-safearray
                                                         vlax-vbobject
                                                         '(0 . 0)
                                                     ) ;_ {vlax-make-safearray
                                                     (list (vlax-ename->vla-object
                                                               od_ent
                                                           ) ;_ {vlax-ename->vla-object
                                                     ) ;_ {list
                                                 ) ;_ end of vlax-safearray-fill
                                             ) ;_ {vlax-make-variant
                                         ) ;_ {vla-MoveToTop
                                     ) ;_ {lambda
                                 ) ;_ {function
                             ) ;_ {vl-catch-all-apply
                         ) ;_ {if
                     ) ;_ {while
              ) ;_ {while
       ) ;_ {if
   ) ;_ {foreach
   (vla-regen (vla-get-activedocument (vlax-get-acad-object)) 1)
) ;_ {defun..........................................wiz23mar09....8-)
A reactor is a type of LISP that runs without the user having to enter a syntax to the command line.
There are many types of reactors, you can assign them to objects, command calls, etc etc.
Now that Wizman has provided another option, it looks like a reactor is a possibility.
Hi , wizman,thanks for the reply.But I tried , doesn't work.the command just show regenerating model:(.FYI,following are the effect I want . (would be better can make the order automatically,if needs any manual change ,stay the manual change)
Thanks
  wizman said:
here's for blocks:
   (vl-load-com)
   (foreach od_lay
                              "LAYER2"
                              "LAYER3" ; bottom
                   ) ;_ {reverse
       (if
              (while
                             (vl-catch-all-apply
                                 (function
                                     (lambda ()
                                         (vla-MoveTotop
                                             (vla-AddObject
                                                     (vla-item
                                                         (vla-get-blocks
                                                 "ACAD_SORTENTS"
                                                 "AcDbSortentsTable"
                                             ) ;_ {vla-AddObject
                                             (vlax-make-variant
                                                         vlax-vbobject
                                                         '(0 . 0)
                                                               od_ent
                                                     ) ;_ {list
                                         ) ;_ {vla-MoveToTop
                                     ) ;_ {lambda
                                 ) ;_ {function
                         ) ;_ {if
                     ) ;_ {while
              ) ;_ {while
       ) ;_ {if
   ) ;_ {foreach
sample.dwgFetching info...
that routine is for draworder of entities by layer inside blocks From your posted drawing, i think you're looking for draworder between blocks through their nested entities. if they are in different blocks, then they are in different spaces, ill see later if i can figure it out.
Wizman, why is the function vla-MovetoTop not recognised in VLIDE?
  Quote
lee, it is recognized when vl-load-com is iniatiated.
It is still black on my screen, even with vl-load-com initiated :(
  • 1 year later...
this is sweet! how can you add wildcards to the list i.e. *layer* etc? been trying to figure it out all day?
  Lee Mac said:
I suppose this?
(defun c:orderlay  (/ laylist ss)
 (setq laylist '("LAYER1"  ;  <---<< List Layers Here.
                 "LAYER2"
                 "LAYER3"
 (foreach lay laylist
   (if    (and (tblsearch "LAYER" lay)
        (setq ss (ssget "X" (list (cons 8 lay)))))
     (command "_draworder" ss "" "_F")))
 (princ))
A quick modification would be this:
(defun c:OrderLay ( / laylist ss )
                 "LAYER2"
                 "LAYER3"
   (if (setq ss (ssget "_X" (list (cons 8 lay))))
     (command "_.draworder" ss "" "_F")
Ah...so simple - works like a charm cheers Lee
An alternative approach:
LayerstoTop will order layers as specified in the list
Top will move a SelectionSet of objects to the Top.
Bot will move a SelectionSet of objects to the Bottom.
(defun LM:MovetoTop ( ss / ObjLst Sortents )
 (vl-load-com)
 ;; © Lee Mac 2010
 (setq ObjLst (LM:ss->vla ss))
 (if
   (setq Sortents
     (LM:SortentsTable
       (vla-ObjectIDtoObject
         (vla-get-OwnerID (car ObjLst))
   (vla-MovetoTop Sortents (LM:ObjectVariant ObjLst))
(defun LM:MovetoBottom ( ss / ObjLst Sortents )
 (vl-load-com)
 ;; © Lee Mac 2010
 (if
   (setq Sortents
     (LM:SortentsTable
   (vla-MovetoBottom Sortents (LM:ObjectVariant ObjLst))
(defun LM:SortentsTable ( space / dict )
 (cond
     (LM:CatchApply vla-item
       (list
         (setq dict
           (vla-GetExtensionDictionary space)
        "ACAD_SORTENTS"
     (LM:CatchApply vla-AddObject
       (list dict "ACAD_SORTENTS" "AcDbSortentsTable")
(defun LM:ss->vla ( ss )
 ;; © Lee Mac 2010
 (if ss
     (lambda ( i / e l )
       (while (setq e (ssname ss (setq i (1+ i))))
         (setq l (cons (vlax-ename->vla-object e) l))
       l
     -1
(defun LM:CatchApply ( foo args / result )
 ;; © Lee Mac 2010
 (if
   (not
     (vl-catch-all-error-p
       (setq result
         (vl-catch-all-apply (function foo) args)
   result
(defun LM:SafearrayVariant ( datatype data )
 ;; © Lee Mac 2010
 (vlax-make-variant
     (vlax-make-safearray datatype
       (cons 0 (1- (length data)))
     data
(defun LM:ObjectVariant ( lst )
 ;; © Lee Mac 2010
 (LM:SafearrayVariant vlax-vbobject lst)
;; -- Test Functions --
(defun c:top ( / ss )
 (vl-load-com)
 ;; © Lee Mac 2010
 (if (setq ss (ssget "_:L" (list (cons 410 (getvar 'CTAB)))))
   (LM:MovetoTop ss)
(defun c:bot ( / ss )
 (vl-load-com)
 ;; © Lee Mac 2010
   (LM:MovetoBottom ss)
(defun c:LayerstoTop ( / order ss )
 (vl-load-com)
 ;; © Lee Mac 2010
 (setq order
      "Layer1" "Layer2" "Layer3"
 (foreach l (reverse order)
   (if (setq ss (ssget "_X" (list (cons 8 l) (cons 410 (getvar 'CTAB)))))
     (LM:MovetoTop ss)
  • 14 years later...
@Lee Mac
Hello, I am using C3D2023
after upload the lisp with the "appload" comand how do I run the routine?
thanks
The commands are noted in the post immediately above yours.
