Lisp for Automatic Draw Order Command to a specific Layer.
Hello,
I was wondering if anybody could help me as I have no knowledge of AutoLisp.
Does anybody have a lisp command that allows me to put my "dims" layer to the back of the drawing when it is inserted ( i have it set up so that when i insert a dimension it is automatically assigned to the "dims" layer. )
This is so I don't always have to use the draw order command to move the "dim" layer to the back.
Also, if someone does have it handy, how do you load it? lol...
Just asking, why would you need to have your dims in a different draworder?
  • 2 weeks later...
Did you have found the solution ???
I need to do the same thing for x-ref.
I have problem with the plotter PDF995. He does'nt merge line. So I have to make a patch
I have to do a draw order before each plotting.
Here is some code that takes the "dims" layer and moves all the objects on it to the back.
;; Moves all objects on the "dims" layer to the back
(defun c:layerback()
;; creates a selection set of all objects on the "dims" layer.
 (setq sel1 (ssget "x" '((8 . "dims"))))
;; Uses the draworder command to move the objects to the back
 (command "draworder" sel1 "" "back")
To use this code open autocad and go to the following menus
Tools -> AutoLISP -> AutoLISP Editor
This will open an editor. Choose the File -> New File menu then paste the code into the window. Save the file by some meaningful name anywhere you want.
Now you can close the editor and go back to AutoCAD. Go to
Tools -> AutoLISP -> Load Application...
and select the file name you just saved. This is all you have to do once you've saved it. You can see from the code that the name of the command is layerback. Just type layerback into the command line and it will move all objects on the "dims" layer to the back.
I chose to keep the code simple so you could understand what's going on and maybe make some adjustments as needed.
Thanks for that Bucingham, Exactly what I have been looking for.
Cheers.
Minnes, I downloaded a pdf writr called Bullzip PDF. I found that it works alot better than 995, You should try it.
Thanks, Stevsmith, but Bullzip Pdf does'nt work. :(
I found Acropolt et UDC. These two converter work well, but there are expensive
So I have to do a patch to solve this problem
Patch =
Each time we select plot
Go in pspace
Choose all xrefs who have a "a" for the fourth letter
Send these xrefs back (draworder)
Go back in mspace
Open plot dialogue box
I dont knok if I have to do a lisp or VBA?
  • 6 months later...
Hi ,
How can I make it works in a block?
tks
Do you mean change the order of the nested entities inside a block?
Hi,
When I use layer back,it only works on the object out of the block.Maybe would be more clear see the attached small smaple.
And it would be better that can make layer draw order automatically,like helpline will be always the bottom one,intenral wall the second one ,structure always the above,etc.
tks
sample.dwg
Ohh, thats a tough one - maybe someone else with a bit more knowledge on this can help :oops:
Hi,
How about just make draworder,like layer 1 above layer 2;layer 2 above layer 3,layer 3 above layer 4,etc.can you help me to make this ?
thanks
Not sure if this would do it?
(defun c:orderlay (/ laylist ss)
 (vl-load-com)
 (vlax-for layer
       (vla-get-layers
         (vla-get-ActiveDocument
       (vlax-get-Acad-Object)))
   (setq laylist (cons (vla-get-name layer) laylist)))
 (foreach lay (reverse laylist)
   (if (setq ss (ssget "X" (list (cons 8 lay))))
     (command "_draworder" ss "" "_B")))
 (princ))
Hi,can I choose layer name by myself,maybe we needn't take all the layer since we have 50 layer.maybe can just set 10 layers first.(you can just write layer 1,layer 2,layer3 ,ect first,later I can replace our layer name)
Thanks
It is difficult to "order" layers imo - in the LISP routine above, I just send each layer to the back consecutively, so that they are "ordered".
I see,then can you also add into send each layer to the front consecutively?thanks
I suppose this?
 (setq laylist '("LAYER1"  ;  <---<< List Layers Here.
                 "LAYER2"
                 "LAYER3"
 (foreach lay laylist
   (if    (and (tblsearch "LAYER" lay)
        (setq ss (ssget "X" (list (cons 8 lay)))))
     (command "_draworder" ss "" "_F")))
 (princ))
Yes!that's one we want,but I guess it's hard to make it works in the block?:unsure:
Well, yes, as I said earlier, draw order is a bit of a funny thing to play around with, I have no idea how to make it work within blocks :(
Sorry
Hi Lee Mac.
Sorry,one more request!Is that possible make the lisp run automatically without use the command,means everytime when I draw a line,the computer will help me to make the draw order,and if I make any manual change about the order,it will stay my manual change.
thanks
Hi Lee Mac.
thanks
You could use a reactor I suppose, but then in my posted function, I have used command calls, which aren't good to use with reactors...
but, if someone can work out how to alter draw-order without resorting to command calls, then, yes, it is possible.
