HI
I wrote a VBA that draw a rectangle bar and divid it and hatch it like dr.dwg , when I run our code this part of program return an error that : Run time error '483':
Object dosen't support this property or method
please anyone write me that why this error ocurrse and how I must repaire it ?
thanks
Here is my code :
Dim layerObj7 As AcadLayer
Set layerObj7 = ThisDrawing.Layers.Add("ELEVATIONS_ID_BAR")
layerObj7.color = acWhite
Dim lineObj7 As AcadLine
Dim startPoint7(0 To 2) As Double
Dim endPoint7(0 To 2) As Double
Dim objEnt1 As AcadHatch
Dim Outer1 As AcadEntity
Dim p(14) As Double
Dim plineObj1 As AcadPolyline
fc = Fix(((maxh - minh + 5) * 10) + (minh - 4))
startPoint7(0) = minx - 5 - 0.25: startPoint7(1) = minh - 4: startPoint7(2) = 0
endPoint7(0) = minx - 5 - 0.25: endPoint7(1) = fc: endPoint7(2) = 0
Set lineObj7 = ThisDrawing.ModelSpace.AddLine(startPoint7, endPoint7)
startPoint7(0) = minx - 5 + 0.25: startPoint7(1) = minh - 4: startPoint7(2) = 0
endPoint7(0) = minx - 5 + 0.25: endPoint7(1) = fc: endPoint7(2) = 0
startPoint7(0) = minx - 5 - 0.25: startPoint7(1) = fc: startPoint7(2) = 0
While ((fc Mod 5) 0)
fc = fc + 1
Wend
v = 1
While (((minh - 4) + (v * 5))
p(0) = minx - 5 - 0.25: p(1) = ((minh - 4) + (v * 5)): p(2) = 0
p(3) = minx - 5 + 0.25: p(4) = ((minh - 4) + (v * 5)): p(5) = 0
p(6) = minx - 5 + 0.25: p(7) = ((minh - 4) + (2 * v * 5)): p(8) = 0
p(9) = minx - 5 - 0.25: p(10) = ((minh - 4) + (2 * v * 5)): p(11) = 0
p(12) = minx - 5 - 0.25: p(13) = ((minh - 4) + (v * 5)): p(14) = 0
Set plineObj1 = ThisDrawing.ModelSpace.AddPolyline(p)
plineObj1.Closed = True
Set objEnt1 = ThisDrawing.ModelSpace.AddHatch(acHatchPatternTypePreDefined, "SOLID", True)
objEnt1.AppendOuterLoop (plineObj1)
objEnt1.Evaluate
objEnt1.Update
v = v + 2
Wend
The AppendOuterLoop method works with an entity array, so try something like this:
Dim Outer1(0) As AcadEntity
Set Outer1(0) = plineObj1
objEnt1.AppendOuterLoop Outer1
I change it but my output drawing don't have desired hatch , please see dy dr2.dwg
and another problem is :
if I want make a styletext that write 90 degree text what must I do ?
Dr2.dwgFetching info...
Change on this code block as SEANT said:
While (((minh - 4) + (v * 5)) < fc)
p(6) = minx - 5 + 0.25: p(7) = ((minh - 4) + (2 * v * 5)): p( = 0
[color=red]Dim outerLoop(0) As AcadEntity
Set outerLoop(0) = plineObj1
objEnt1.AppendOuterLoop (outerLoop)[/color]
objEnt1.Evaluate
objEnt1.Update
v = v + 2
Wend
~'J'~
objEnt1.Evaluate
objEnt1.Update
v = v + 2
Wend
~'J'~
Hi dear fixo
I read this post and I test all these codes , your code and seant code results are the same , I see dr2.dwg and I think that nima1376 want hatches elevation bar so that inner rectangles be filled be one among , (one hatch - one empty - one hatch ... and so on) .
  cadman2009 said:
Hi dear fixo
Aha, now I understand - he need something similar
on dashed lines (filled rectangle follows by empty rectangle etc)
Thanks, cadman
~'J'~
Thanks, cadman
~'J'~
Dear fixo
I change polyline points definition like below and was drawn an elevation bar like a dashed line , please check it and if I just tell ,write me .
very thanks dear master
p(6) = minx - 5 + 0.25: p(7) = ((minh - 4) + ((v + 1) * 5)): p(8) = 0
p(9) = minx - 5 - 0.25: p(10) = ((minh - 4) + ((v + 1) * 5)): p(11) = 0
Set OuterLoop(0) = plineObj1
objEnt1.AppendOuterLoop (OuterLoop)
objEnt1.Evaluate
objEnt1.Update
  cadman2009 said:
Dear fixo
Wow, you have solved it, worked nice for me
And, hey, cadman, no flowers please :)
Happy computing
~'J'~
