Can't dimension angled line
It will only give dimensions in horizontal or vertical, I need dimension of length of angled line. Thanks
There is an option for angular lines and it is called aligned. Look on the Annotate tab, Dimensions panel under Linear (left side of panel). Use the arrow to access more choices.
Where can I find this option?
I need it to line up like the 1'-10-7/16"
Mason Dixon, don't use ACAD '09 but, try right click on a blank area of your toolbars.
Look at the ACAD listing, check 'DIMENSIONS' and you'll have the dimension tool bar. Position the tool bar where you want it or just use and close.
The attached image shows the tool bar, the aligned dimension icon is circled in red. As you might note, I keep this toolbar anchored on the right. Only a matter of preference. :wink:
