Hi!
When I copy paste something in AutoCAD with OSNAP on, I can snap the pasted object to whatever location I choose... But how do I choose the point on the pasted object that is snapping?
For example, if I am pasting hexagons, how do I tell AutoCAD to use the top vertex of the pasted hexagon as the snap point for pasting? It seems to be fairly random which point is used as a snap point on the pasted object, but I'm sure it's not supposed to be...
Thanks!
-V
Either use the Copy command and snap to an intersection for the base point or use Copybase and snap to an intersection.
You can also change the GRIPBLOCK variable from 0 to 1 which then allows grips within block objects. This can get rather cumbersome in a heavily populated block.
and you do know you can toggle through OSNAPs with the tab key?
You guys are a treasure trove of useful tips! :)
