Lee Mac Posted February 16, 2010 Author Posted February 16, 2010 Hi Lee, Thanks for your quick reply. It just exits with no error message. I am not sure if I posted to the correct thread as this thread seems to be regarding the automatic re-alignment lisp routine. Many apologies for any confusion. Thanks, Pete Sorry, which were you referring to? There are three programs mentioned in this thread (confusing, I know)... Quote
Lee Mac Posted February 16, 2010 Author Posted February 16, 2010 I have updated the code for the Dynamic Text Curve Align program to Version 2.9. This resolves the major bug that Asos has kindly spotted, among other code improvements. Your feedback is appreciated, and of course, any other bug reports! The new code can be found here. Lee Quote
InbetweenPete Posted February 16, 2010 Posted February 16, 2010 Hi Lee, The routine I am referring to is 'TxAlign.zip' found on http://www.cadtutor.net/forum/showthread.php?t=42438 if that helps. Again, sorry for any confusion. Many thanks. Pete Quote
Lee Mac Posted February 16, 2010 Author Posted February 16, 2010 Pete, Does the prompt appear for you to select an Alignment Point? Quote
joe51 Posted May 17, 2010 Posted May 17, 2010 Lee Mac thanks for all you do here. Since I joined this forum, I bet I have spent more time studying your code than actually working. Shhh... dont tell the bosso:) Quote
Lee Mac Posted May 17, 2010 Author Posted May 17, 2010 Hehe thanks Joe I'm happy to have been of assistance Quote
asos2000 Posted July 6, 2010 Posted July 6, 2010 A Crazy and foolish idea is it working if the text in a dynamic block, im sure 99.98% the answer is NO but there is still 0.01% for YES and 0.01% for maybe Quote
Lee Mac Posted July 6, 2010 Author Posted July 6, 2010 Dynamic Align Text to Curve Most probably not - the program is designed for standard Text/MText. Quote
Lee Mac Posted July 7, 2010 Author Posted July 7, 2010 Is it able to code such as a lisp? I don't have much experience in Dynamic Blocks, but isn't there some kind of constraint that could apply? Quote
aeroCAD Posted July 8, 2010 Posted July 8, 2010 Hi Lee, awsome projects,....just a question,...i tried using dynamic align text to curve,....when the command prompts the "select text or type", when i select text it doesnt seem to work,....unless this issue has been addressed. thanks Quote
Lee Mac Posted July 8, 2010 Author Posted July 8, 2010 really helpful, thanks ! Thanks ectech Hi Lee, awsome projects,....just a question,...i tried using dynamic align text to curve,....when the command prompts the "select text or type", when i select text it doesnt seem to work,....unless this issue has been addressed. thanks Thanks aeroCAD - I've not had that been reported before however. You should be able to select some text, then select the desired curve to align to. Do you receive an error? Quote
aeroCAD Posted July 8, 2010 Posted July 8, 2010 the command just simply goes back to norm. but there is a .redraw that appears on the command line Quote
