annotate one point
Hello
I'm looking for a rhino script similar of command
_AnnotateCrvEndPoints
but only for annotate one single position (points or vertex ) in my rhinomodel.
Thanks
- whith the mouse
in the same way like inserting a point whith
command _Point (snap on)
P.s. I'd like to have the possibility to
select the TEXT HEIGHT.
This routine is based on what I could find out about _AnnotateCrvEndPoints. It used Annotation Dots which, unfortunately, don't have any resizing capabilities.
Option Explicit
Sub Dot2Point
' Declare variables
Dim strLocation
Dim strDot
Dim arrPoint
 With Rhino
   Do
     arrPoint = .GetPoint("Select point at which to set dot: ")
     If IsArray (arrPoint) Then
         strLocation = .Pt2Str(arrPoint, 2)
         strDot = .AddTextDot (strLocation, arrPoint)
     Else
       Exit Sub
     End If
   Loop
 End With
End Sub
Dot2Point
Thanks Seant
That's just what I was looking for
  • 2 years later...
Hello
it is possible to modify this script
just for annotate the lenght of the curve
(annotation in the mid point of the curve)
Thanks
