Kari Posted November 18, 2009 Posted November 18, 2009 How do I make a divided surface into window panels? I just want to use the surface pattarn as curtain wall pattenrn when it render. Thanks Quote
qabulin Posted January 3, 2010 Posted January 3, 2010 You say you want to use a pattern, but are you trying to use Revit like AutoCAD? Do you have a sample image? Maybe I can help you with your cheating! ^_^ Otherwise, you should really break out those curtain wall tools and do it up correctly. Quote
qabulin Posted January 3, 2010 Posted January 3, 2010 er.... by the way, did you figure it out here: http://www.cadtutor.net/forum/showthread.php?t=42643 sorry, just noticed your reply to yourself... and it sounded related! Quote
