Hello,
Does anybody have a lisp to draw similar object in the same layer? I mean to select an object, then , using a lisp, to draw a similar oblect, in the same layer, with the same linetype, the same colour... etc... only the dimensions to be different.
What kinds of objects are you talking about? Circles, Lines, Rectangles?
Yes, all 2d objects - liners, circles, rectangles, polylines,arcs... Somebody has a lisp that draw all this, + dimensions and blocks... but will be ok even to draw only a part of this objects.
Lee Mac's MapCom routine IS PERFECT. Can this routine work with dimension and text to?
This lisp is a nice one. If somebody want to modify it to fit the dimension style and text style, will be perfect!
What about inserting the same block? and then start attribute editing, after insertion? Am I dreaming? Is it possible to be a universal command? smiley.gifsmiley.gif
dent.lsp
My variant. Quickly draw another.
;;; The command, "QUIKDRAW", will begin the AutoCAD
;;; command to draw a similar entity that the user is
;;; prompted to select.
;;; Before the command begins, the layer, color, &
;;; linetype properties will be set current, and if applicable,
;;; other options (e.g. style, scale, width, etc.)
;;; will be preset before the AutoCAD command is executed.
;;; Short name command - Q and QR (Quickdraw restore)
;;; If you type QR, after the command the layer, color,
;;; linetype and lineweight properties restore back
;;; Keys ENTER, a spacebar it is possible to repeat drawing with last installations
21.05.2010 - Add True Color
Also posted http://www.theswamp.org/index.php?topic=30983.0
quickdraw.LSP
Edited by VVA
Add latest version
  • Thanks 1
Wow, bit of work in there! Thanks for sharing.
VVA, you are a genius! Thanks!
