Swwep 3D into Sketup
Guest RODDY1
Hi
I am Using AutoCad 2009 and Sketchup Pro 7
I have created a solid spiral in AutoCad using helix
command followed by the sweep command.
But when i import this drawing into Sketchup all
the solids transfer ok apart from the solid spirals
which are not transfered.
Can anyone help
Many Thanks
Alan
alreeet Roddy.... i would just export the helix as a line into sketchup and use the 'follow me command' to turn this into a solid.
Alternatively you can just draw the full helix in sketchup there are many tutorials on line how to do this OR type HELIX in 3D warehouse :D
Exporting 3d models into sketchup directly from autocad doesn't always come in very well.
Cheers
Thanks jbullseye74 & f700es
probably go with bringing in helix from AutoCad
draw a block in sketch and extrude around helix path
if that is possible in sketchup when using the follow me command, i shall investigate
Thanks again
