Does this exist? I would very much like to rtfm.
I didn't think anyone was using Volo View any more. Why the docs?
LOL, I didn't either but times are hard. I work for a furniture manufacturer and they are currently trying to print out sub-assembly drawings and keep them in a physical binder.
We have several thousand subs and to keep up with this will be a nightmare. I was working on a vb front-end using the voloview, or truview if thats the new one, with the intention of putting a terminal out where the subs are built giving the guys on the floor access to view drawings.
I was just looking for anything before I started to just guess at the functionality of this control.
If there is a better way to do this that'd be great also.
Thanks for the links, I have that part of it, I also have the true view as well.
I have not read much about the trueview, does it integrate into vb as a control as well?
I just started looking into this last week so all options are open. Any Ideas on where to find vba (access) + trueview coding samples? Outside of voloview not being supported what are the advantages of using trueview?
Coding samples? Have you tried the AutoDesk website?
Yeah not much there, I want to use is as an active x control and autoload the drawings based off info queried from a mysql db.
Well you're way over my head (doesn't take much these days). Did the best I could do at the moment. Sorry.
