I have created a template (attached) that has specific fields in the Custom tab of DWGPROPS, which is referenced in the titleblock. I wanted to see if it was possible to have a LISP that asks for the custom field info at the start of a new drawing in the command bar instead of a dialog box.
I have tried changing the CMDDIA variable to 0, but it doesn't help. I really like using the DWGPROPS, but it doesn't navigate like ATTEDIT does (using keyboard navigation), and I am trying to speed that process up.
Also, on a side note, has any leway been made on being able to add a "total number of layouts" field in AutoCAD 2010? (For Page # of #)
DWGPROPS Lisp.dwgFetching info...
Try it
;;; * Library DWGruLispLib Copyright © 2007 DWGru Programmers Group
;;; * _dwgru-Dwgprops-get-all-prop
;;; * 27/12/2007 Version 0001. Vladimir Azarko (VVA)
(defun _dwgru-dwgprops-get-all-prop (Doc / si ret nc key value)
;;; Returns the file's properties, set the command _dwgprops
;;; Returns an associative list, where the key is:
;; - For properties created by the user (tab OTHER)
;;; Property name
;; - For standard properties (tab PAPER)
;;; Key field
;;; NAME - *TITLE*
;;; AUTHOR - *AUTHOR*
;;; TOPIC - *SUBJECT*
;;; KEY WORDS - *KEYWORDS*
;;; NOTES - *COMMENTS*
;;; Hyperlink Base - *HYPERLINK*
;;;!! Key fields are converted to uppercase
;;; Doc - a pointer to the  document, nil - the current
;;; Example
;;; (_dwgru-dwgprops-get-all-prop nil) ;;;(("* AUTHOR * "" VVA ") (" * COMMENTS * "" Memo ") (" * HYPERLINK * "" Base ")
                               ;;;("* KEYWORDS * "" Key ") (" * TITLE * "" named ") (" * SUBJECT * "" R ") (" UNIQKEY "" Key "))
(and
(or Doc
   (setq Doc (vla-get-activeDocument (vlax-get-acad-object)))
(setq si (vla-get-SummaryInfo Doc))
(setq ret (list
    (list "*AUTHOR*" (vla-get-author si))
    (list "*COMMENTS*" (vla-get-comments si))
           (list "*HYPERLINK*" (vla-get-HyperlinkBase si))
    (list "*KEYWORDS*" (vla-get-keywords si))
           (list "*TITLE*" (vla-get-Title si))
    (list "*SUBJECT*" (vla-get-Subject si))
(setq nc (vla-numcustominfo si))
(while (> nc 0)
(vla-GetCustomByIndex si (- nc 1) 'key 'value)
(setq ret (append ret (list(list (strcase key) value))))
(setq nc (1- nc))
(vlax-release-object si)
ret
;;; * _dwgru-Dwgprops-get-custom-prop
(defun _dwgru-dwgprops-get-custom-prop (key Doc / app counter counter2 counter3 doc dwgprops kv)
;;; Returns the value of the property created by the user (command _dwgprops)
;;; Key - a string property name (tab OTHER)
;;; Key field
;;; NAME - *TITLE*
;;; Uses the library
;;; _dwgru-Dwgprops-get-all-prop
;;; _dwgru-Assoc (_dwgru-assoc-multi)
 (cadr (_dwgru-assoc key (_dwgru-dwgprops-get-all-prop Doc)))
;;; * _dwgru-Dwgprops-set-custom-prop
(defun _dwgru-dwgprops-set-custom-prop (key value Doc / si)
;;, Create in the properties of the figure (team _dwgprops bookmark OTHER)
;;; Property with key and value value
;;; If the property was not, it is created, otherwise the changes
;;; Value - a string  - value of property
;;; _dwgru-Dwgprops-get-custom-prop
;;; Returns - nil
;;; Example
;;; (_dwgru-dwgprops-set-custom-prop "dwgru" "dwgru-dwgprops-set-custom-prop" nil)
  (or Doc
  (setq Doc (vla-Get-ActiveDocument (vlax-Get-Acad-Object)))
  (setq si (vla-Get-SummaryInfo Doc))
  (if (_dwgru-dwgprops-get-custom-prop key Doc)
    (vla-SetCustomByKey si key value)
    (vla-AddCustomInfo si key value)
(defun _dwgru-assoc-multi (key lst)
  (if (= (type key) 'str)
    (setq key (strcase key))
    ); _ End of if
  (vl-remove-if-not
    (function
      (lambda (a / b)
        (and (setq b (car a))
             (or (and (= (type b) 'str) (= (strcase b) key)) (equal b key))
             ); _ End of and
        ); _ End of lambda
      ); _ End of function
    lst
    ); _ End of vl-remove-if-not
  ); _ End of defun
(defun _dwgru-assoc (key lst)
  (car (_dwgru-assoc-multi key lst))
  ); _ End of defun
Usage
(defun C:TEST ()
[color="Red"](vl-load-com) ;;; Do not forget to add[/color]
  (setq str (getstring t "\nJob Number:"))
  (_dwgru-dwgprops-set-custom-prop "Job Number" str nil)
  (setq str (getstring "\nCustomet:"))
  (_dwgru-dwgprops-set-custom-prop "Customer" str nil)
  (setq str (getstring t "\nAddres:"))
  (_dwgru-dwgprops-set-custom-prop "Addres" str nil)
Edited by VVA
Ok, I loaded the lisps, but I think I did something wrong, because I get the following error:
Command: appload
DWGruLispLib.lsp successfully loaded.
test.lsp successfully loaded.
Command: ; error: malformed list on input
Command:
Command:
Command: test
Job Number:109-567
; error: no function definition: _DWGRU-ASSOC
Command:
Nevermind. I had missed a section of code.
