  viviancarvalho said:
Hey Fixo you have done a big thing for me.
thanks for that. Is it further possible that only one excel file be created for one particular dwg & when some more closed plines are selected, their areas appear in the same excel files. Sorry to trouble you again.
This program does already open or create (if this does not exist)
one Excel file per drawing in the working folder
Sorry I don't understand your task because of my
poor English level
~'J'~
  • Replies 42
  • fixo
    14
  • Butch
    7
  • viviancarvalho
    5
  • xxfaxx
    2
Posted Images
Dear Fixo
What i mean to say is that when an excel file is created for one particular Cad file, the data should be added to the same excel file when the program is run more than once. Another excel file should not be created when working with the same Cad file.
Dear Fixo
Did you tryed the last program?
It will do all what you need: create the new file if this
does not exist or open an existing file
It will be find the last cell if the Excel file was created
and append data after the last row there
If the Excel file is new in this case it will be
write the data starting from the first row
There is just one thing though: the program
can write duplicate records if you will be select
the same room in the different Acad session twice
Hope this make a sense
~'J'~
Its fine
thanks Fixo
Uh,
Cheers :)
~'J'~
  fixo said:
I added a few lines of code
Check it again
~'J'~
Hey Fixo!
Its working fine :-)
Its a bit slower then first few solutions,couse you must pick every polyline, but its ok.
One thing maybe only, can you do that values always get add in the same excel file?
Eg. you activate command pick polylines and exoit command. Excel opens and it shows a column of areas. Then you select a cell that will define a new column start in excel for new values to be copied.
What do you think?
  Butch said:
Hey Fixo!
What do you think?
Grab the code block from post#19
there is what you exactly need (I mean to
write or append data into the same Excel file)
~'J'~
  • 2 years later...
Just wanted to drop by and give thanks. A really helpful thread.
++ Respect to fixo . .
You're very wecome,
Happy coding
~'J'~
  • 1 month later...
  fixo said:
Here is the final version I hope :)
~'J'~
Hello dear fixo, I'm sorry but I can't get it to work. When the routine starts, it asks for the room number and then to select the polyline. After selecting the polyline an error message appears "Close Excells File Only" and a blank Excel Sheet pops up on the screen.. Should I configure the file path or something? What is the problem with this error?
Thanks
  • 3 months later...
Fixo,
I know this thread is old but I just stumbled on it. Your V5 routine is brilliant. However, I have been trying to add 2 extra columns, but to no avail. I'm not efficient enough to decipher your logic and variables. Your help would be appreciated.
From the same selection I require the overall width and overall length (of polyline bounding box). Not actual lengths as the polylines are often of irregular shape.
ie
(setq ss (ssget "+.:S:E" (list (cons 0 "LWPOLYLINE")(cons 70 1))))
(setq en (ssname ss 0) obj (vlax-ename->vla-object en))
(setq LL (vlax-safearray->list minpt) UR (vlax-safearray->list maxpt))
(setq #WDT (- (car UR)(car LL)))(setq #HGT (- (cadr UR)(cadr LL)))
(prompt "\nOverall Width = ")(princ #WDT)
(prompt "\tOverall Height = ")(princ #HGT)(terpri)
eg Result from selected POLYLINES for Excel sheet (4 Columns) These are for panels not rooms so I can simply change your 'label' prefix.
Required Excel Export:
PANEL WIDTH HEIGHT AREA
I have attached a 'real world' example dwg to help clarify. Many thanks in advance, if you or someone else can help.
excel_test.zipFetching info...
  • 3 weeks later...
very nice i'll try that . Fixo, will that apply to polygons(as cobwebs for example) made of lines instead of polylines? I need this one.thanks
  • 1 month later...
tks alot mr fixo
this lisp is very very useful and really excellent but please there are one small problem when we select the the area one by one it was very good but when select all it at one time >>>
excel arrange it ascending or by the first area was draw i dont know >>>>please if you can solve this problem it was very good lisp
tks alot
  • 2 years later...
Hello sir I need this lisp
in only one change take polyline area in rhombos and shape of polyline
  • 3 months later...
Fixo "The Guru"
I thank you for this program so so much. :cry:
  • 2 months later...
Its amazing what you find! I was wondering how hard would it be to add an export of the elevation of polyline with the area? I am having a hard time trying to figure this out! lol. Scratching my head!
  • 2 years later...
i just logged in to thank you fixo
You deserve to be the super member you are .
Thank you very much for your help
