maksolino Posted November 4, 2009 Share Posted November 4, 2009 hello i am looking for a lisp routine that rename all, or selected blocks in the drawing adding a character in the existing name example 1.select blocks (option all) 2.enter the letter to add Thanks Quote Link to comment Share on other sites More sharing options...
gile Posted November 4, 2009 Share Posted November 4, 2009 Hi, Something like this ? (defun c:test (/ ss n ent name lst) (vl-load-com) (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)) blocks (vla-get-Blocks acdoc) ) (princ "\Select bloc to rename or Enter for all.") (if (or (ssget '((0 . "INSERT"))) (ssget "_X" '((0 . "INSERT")))) (if (setq pref (getstring "\nEnter the prefix to add: ")) (progn (vlax-for b (setq ss (vla-get-ActiveSelectionSet acdoc)) (setq name (vla-get-name b)) (if (not (vl-position name lst)) (setq lst (cons name lst)) ) ) (foreach n lst (vla-put-Name (vla-item blocks n) (strcat pref n)) ) ) ) ) (princ) ) 1 Quote Link to comment Share on other sites More sharing options...
maksolino Posted November 4, 2009 Author Share Posted November 4, 2009 Thanks gile , that's OK but that lisp not resolve my problem becouse my blocks are built whit many others blocks in few level. Please can you expande your lisp to rename also the block inside (i really mean all existing blocks). Have a nice day Quote Link to comment Share on other sites More sharing options...
David Bethel Posted November 4, 2009 Share Posted November 4, 2009 Thanks gile , that's OKbut that lisp not resolve my problem becouse my blocks are built whit many others blocks in few level. Please can you expande your lisp to rename also the block inside (i really mean all existing blocks). Have a nice day Your basic request is pretty easy using RENAME. The problem lies in the renaming of blocks that already exist. Let's say that you already have BLOCKS DOOR1 and DOOR1A and that you want to add the letter A as a suffix. When you go to rename DOOR1 to DOOR1A, do you overwrite the existing block definition?, skip it? or try itinerating all the way through the block table and keep track of it. That could be intense. -David Quote Link to comment Share on other sites More sharing options...
gile Posted November 4, 2009 Share Posted November 4, 2009 This on should work with nested blocks too (defun c:test (/ getNestedNames remove_duplicates ss n ent name lst) (vl-load-com) (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object)))) (or *blocks* (setq *blocks* (vla-get-Blocks *acdoc*))) ;; Returns a list of the nested block names (defun getNestedNames (name / lst) (vlax-for o (vla-Item *blocks* name) (if (= (vla-get-ObjectName o) "AcDbBlockReference") (setq lst (append (list (vla-get-Name o)) (getNestedNames (vla-get-Name o)) lst ) ) ) ) lst ) ;; Removes all duplicates from a list (defun remove_duplicates (lst) (if lst (cons (car lst) (remove_duplicates (vl-remove (car lst) lst))) ) ) ;; Main (if (setq pref (getstring "\nEnter the prefix to add: ")) (progn (vla-StartUndoMark *acdoc*) (princ "\Select bloc to rename (or Enter for all)") (if (ssget '((0 . "INSERT"))) ;; selection (progn (vlax-for b (setq ss (vla-get-ActiveSelectionSet *acdoc*)) (setq name (vla-get-name b)) (if (not (vl-position name lst)) (setq lst (append (list name) (getNestedNames name) lst)) ) ) (vla-delete ss) (foreach n (remove_duplicates lst) (vla-put-Name (vla-item *blocks* n) (strcat pref n)) ) ) ;; all (vlax-for b *blocks* (if (and (= (vla-get-IsLayout b) :vlax-false) (= (vla-get-IsXref b) :vlax-false) (not (wcmatch (setq name (vla-get-Name b)) "*|*")) ) (vla-put-Name b (strcat pref name)) ) ) ) (vla-EndUndoMark *acdoc*) ) ) (princ) ) Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted November 4, 2009 Share Posted November 4, 2009 Giles' s awesome, that code must work... add preffix or suffix to block names may work for selected (no nested) blocks.. http://www.cadtutor.net/forum/showthread.php?t=40933 In case of nested... I guess Giles'code should work fine.. Quote Link to comment Share on other sites More sharing options...
maksolino Posted November 5, 2009 Author Share Posted November 5, 2009 Thanks guys that is exactly what i was looking for Quote Link to comment Share on other sites More sharing options...
David Bethel Posted November 5, 2009 Share Posted November 5, 2009 Or another approach could be: [b][color=BLACK]([/color][/b]defun c:addbs [b][color=FUCHSIA]([/color][/b]/ adds str bn nn ext[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1 [color=#2f4f4f]"Suffix Prefix"[/color][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq adds [b][color=NAVY]([/color][/b]getkword [color=#2f4f4f]"\nAdd String As - Suffix/Prefix: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]or [b][color=MAROON]([/color][/b]not str[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]not [b][color=GREEN]([/color][/b]snvalid str[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq str [b][color=MAROON]([/color][/b]getstring [color=#2f4f4f]"\nBlock Name String To Add: "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]setq tdef [b][color=MAROON]([/color][/b]tblnext [color=#2f4f4f]"BLOCK"[/color] [b][color=GREEN]([/color][/b]not tdef[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq bn [b][color=MAROON]([/color][/b]cdr [b][color=GREEN]([/color][/b]assoc 2 tdef[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq nn [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]= adds [color=#2f4f4f]"Prefix"[/color][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]strcat str bn[b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]strcat bn str[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]cond [b][color=MAROON]([/color][/b][b][color=GREEN]([/color][/b]= [color=#2f4f4f]"*"[/color] [b][color=BLUE]([/color][/b]substr bn 1 1[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b][b][color=GREEN]([/color][/b]not [b][color=BLUE]([/color][/b]tblsearch [color=#2f4f4f]"BLOCK"[/color] nn[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]command [color=#2f4f4f]"_.RENAME"[/color] [color=#2f4f4f]"_Block"[/color] bn nn[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]T [b][color=GREEN]([/color][/b]setq ext [b][color=BLUE]([/color][/b]cons bn ext[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]if ext [b][color=NAVY]([/color][/b]alert [color=#2f4f4f]"All Blocks Could Not Be RENAMEd"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1 ext[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] -David Quote Link to comment Share on other sites More sharing options...
Astro Posted April 21, 2010 Share Posted April 21, 2010 Hi, Something like this ? (defun c:test (/ ss n ent name lst) (vl-load-com) (setq acdoc (vla-get-ActiveDocument (vlax-get-acad-object)) blocks (vla-get-Blocks acdoc) ) (princ "\Select bloc to rename or Enter for all.") (if (or (ssget '((0 . "INSERT"))) (ssget "_X" '((0 . "INSERT")))) (if (setq pref (getstring "\nEnter the prefix to add: ")) (progn (vlax-for b (setq ss (vla-get-ActiveSelectionSet acdoc)) (setq name (vla-get-name b)) (if (not (vl-position name lst)) (setq lst (cons name lst)) ) ) (foreach n lst (vla-put-Name (vla-item blocks n) (strcat pref n)) ) ) ) ) (princ) ) Hi all, this routine is working well, but is it possible to add also dynamic blocks to it? I need to add a prefix to about 1000 blocks... maybe this post can help http://www.cadtutor.net/forum/showthread.php?t=40921 thank you in advance! Just found what i was looking for http://www.cadtutor.net/forum/showthread.php?t=43215 Quote Link to comment Share on other sites More sharing options...
Thiyagu Posted March 2, 2023 Share Posted March 2, 2023 On 11/4/2009 at 9:04 PM, gile said: This on should work with nested blocks too (defun c:test (/ getNestedNames remove_duplicates ss n ent name lst) (vl-load-com) (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument (vlax-get-acad-object)))) (or *blocks* (setq *blocks* (vla-get-Blocks *acdoc*))) ;; Returns a list of the nested block names (defun getNestedNames (name / lst) (vlax-for o (vla-Item *blocks* name) (if (= (vla-get-ObjectName o) "AcDbBlockReference") (setq lst (append (list (vla-get-Name o)) (getNestedNames (vla-get-Name o)) lst ) ) ) ) lst ) ;; Removes all duplicates from a list (defun remove_duplicates (lst) (if lst (cons (car lst) (remove_duplicates (vl-remove (car lst) lst))) ) ) ;; Main (if (setq pref (getstring "\nEnter the prefix to add: ")) (progn (vla-StartUndoMark *acdoc*) (princ "\Select bloc to rename (or Enter for all)") (if (ssget '((0 . "INSERT"))) ;; selection (progn (vlax-for b (setq ss (vla-get-ActiveSelectionSet *acdoc*)) (setq name (vla-get-name b)) (if (not (vl-position name lst)) (setq lst (append (list name) (getNestedNames name) lst)) ) ) (vla-delete ss) (foreach n (remove_duplicates lst) (vla-put-Name (vla-item *blocks* n) (strcat pref n)) ) ) ;; all (vlax-for b *blocks* (if (and (= (vla-get-IsLayout b) :vlax-false) (= (vla-get-IsXref b) :vlax-false) (not (wcmatch (setq name (vla-get-Name b)) "*|*")) ) (vla-put-Name b (strcat pref name)) ) ) ) (vla-EndUndoMark *acdoc*) ) ) (princ) ) I was trying to write variables and codes for the same but doesn't work. But this code helps me a lot. in terms of revision. I had to go forth and back to edit manually one by one. Now it looks pretty easy to handle number of blocks. Thank you very much Gile Quote Link to comment Share on other sites More sharing options...
Thiyagu Posted March 2, 2023 Share Posted March 2, 2023 On 11/4/2009 at 4:16 PM, maksolino said: hello i am looking for a lisp routine that rename all, or selected blocks in the drawing adding a character in the existing name example 1.select blocks (option all) 2.enter the letter to add Thanks Thank you Maksolino for your post. Quote Link to comment Share on other sites More sharing options...
