neekcotrack Posted July 28, 2008 Posted July 28, 2008 Does anyone know of a lisp that can do this: 1. Type the command 2. Ask for text hieght 3. Ask for point on arc ( Call this P1). 4. Make the angle of the text = Perpendicular to (The line from P1 to the center of arc) 5. Make a box around the text ( make box 1.5 bigger all around text) 6. trim arc inside box 7. delete box 8. End of command. Thanks in advance for your help I hope someone can lead me in the right direction. Quote
Adesu Posted July 28, 2008 Posted July 28, 2008 Do you mean like this and I hpe you should you continous. (defun c:test(/) (setq hei (getdist "\nEnter new text height: ")) (setq p1 (entsel "\nPick any location in arc object")) (setq ent (car p1)) (setq sse (entget ent)) (setq bp (cdr (assoc 10 sse))) (setq pt (cadr p1)) (setq ang (angle pt bp)) 5. Make a box around the text ( make box 1.5 bigger all around text) 6. trim arc inside box 7. delete box 8. End of command. (princ) ) ; defun Does anyone know of a lisp that can do this: 1. Type the command 2. Ask for text hieght 3. Ask for point on arc ( Call this P1). 4. Make the angle of the text = Perpendicular to (The line from P1 to the center of arc) 5. Make a box around the text ( make box 1.5 bigger all around text) 6. trim arc inside box 7. delete box 8. End of command. Thanks in advance for your help I hope someone can lead me in the right direction. Quote
neekcotrack Posted July 30, 2008 Author Posted July 30, 2008 Do you mean like this and I hpe you should you continous. (defun c:test(/) (setq hei (getdist "\nEnter new text height: ")) (setq p1 (entsel "\nPick any location in arc object")) (setq ent (car p1)) (setq sse (entget ent)) (setq bp (cdr (assoc 10 sse))) (setq pt (cadr p1)) (setq ang (angle pt bp)) 5. Make a box around the text ( make box 1.5 bigger all around text) 6. trim arc inside box 7. delete box 8. End of command. (princ) ) ; defun Does anyone know how to aquire steps 5 through 8? Thanks in advance to you for anything. Quote
VovKa Posted July 30, 2008 Posted July 30, 2008 why trim? why not wipout or mtext's backgroung mask? Quote
neekcotrack Posted July 30, 2008 Author Posted July 30, 2008 why trim? why not wipout or mtext's backgroung mask? I don't want to use background mask cause I don't want it to take away from the detail behind, and wipeout I don't know what that it. All I am trying to do is make the arc be trimmed back a little on both sides of the E. Quote
VovKa Posted July 31, 2008 Posted July 31, 2008 (vl-load-com) (defun C:Test (/ ActiveDocObj Ent EntName EntObj InsParam InsPoint Temp TextAngle TextBoxCoords TextBoxWidth TextHeight TextString TextOffset TextWidth ) (setq TextHeight 5.0 TextOffset 1.0 TextString "///" TextWidth 0.4 ) (setq ActiveDocObj (vla-get-activedocument (vlax-get-acad-object))) (vla-EndUndoMark ActiveDocObj) (while (and (setq Ent (entsel))) (setq EntName (car Ent)) (if (and (wcmatch (vla-get-ObjectName (setq EntObj (vlax-ename->vla-object EntName)) ) "AcDbLine,AcDbPolyline,AcDbArc,AcDbCircle" ) (setq InsPoint (vlax-curve-getClosestPointTo EntObj (cadr Ent))) (setq InsParam (vlax-curve-getParamAtPoint EntObj InsPoint)) ) (progn (setq TextAngle ((lambda (d) (if (zerop (cadr d)) (/ pi 2) (atan (apply '/ d)) ) ) (cdr (reverse (vlax-curve-getFirstDeriv EntObj InsParam) ) ) ) ) (setq TextBoxCoords (textbox (setq Temp (list (cons 0 "TEXT") (cons 1 TextString) (cons 40 TextHeight) (cons 10 InsPoint) (cons 11 InsPoint) (cons 41 TextWidth) (cons 50 TextAngle) (cons 72 1) (cons 73 2) ) ) ) ) (setq TextBoxWidth (apply '- (reverse (mapcar 'car TextBoxCoords))) ) (vla-startundomark ActiveDocObj) (progn (entmake Temp) (vl-cmdf "._BREAK" (list EntName (trans (vlax-curve-getPointAtDist EntObj (- (setq Temp (vlax-curve-getDistAtParam EntObj InsParam) ) (/ TextBoxWidth 2.0) TextOffset ) ) 0 1 ) ) (trans (vlax-curve-getPointAtDist EntObj (+ Temp (/ TextBoxWidth 2.0) TextOffset) ) 0 1 ) ) ) (vla-endundomark ActiveDocObj) ) ) ) (princ) ) Quote
neekcotrack Posted July 31, 2008 Author Posted July 31, 2008 Thank you that was perfect. Can I ask one more favor. Is it possible to take the code you have above and make it use /// instead of E. Can it have a .4 Width factor. Plus I don't need the box breaking the arc. Thanks for everything wish I could help you. I guess in time I will get better at this stuff. Quote
VovKa Posted July 31, 2008 Posted July 31, 2008 i just use break instead of trim, and the result is the same, does this matter? i edited my previous post to support width factor Quote
neekcotrack Posted July 31, 2008 Author Posted July 31, 2008 i just use break instead of trim, and the result is the same, does this matter?i edited my previous post to support width factor Nope the one you did was perfect just what I was looking for. Thanks so much you helped me a lot. Just one question if I want to make a lisp that calls up another lisp how would I do that?Would this work? (defun c:test () ((load "test") "" test ""))) Quote
neekcotrack Posted July 31, 2008 Author Posted July 31, 2008 Last thing how would I take out the part so it dont break the arc? Quote
VovKa Posted July 31, 2008 Posted July 31, 2008 this one will not break anything (vl-load-com) (defun C:Test (/ ActiveDocObj Ent EntName EntObj InsParam InsPoint Temp TextAngle TextBoxCoords TextBoxWidth TextHeight TextString TextOffset TextWidth ) (setq TextHeight 5.0 TextOffset 1.0 TextString "///" TextWidth 0.4 ) (setq ActiveDocObj (vla-get-activedocument (vlax-get-acad-object))) (vla-EndUndoMark ActiveDocObj) (while (and (setq Ent (entsel))) (setq EntName (car Ent)) (if (and (wcmatch (vla-get-ObjectName (setq EntObj (vlax-ename->vla-object EntName)) ) "AcDbLine,AcDbPolyline,AcDbArc,AcDbCircle" ) (setq InsPoint (vlax-curve-getClosestPointTo EntObj (cadr Ent))) (setq InsParam (vlax-curve-getParamAtPoint EntObj InsPoint)) ) (progn (setq TextAngle ((lambda (d) (if (zerop (cadr d)) (/ pi 2) (atan (apply '/ d)) ) ) (cdr (reverse (vlax-curve-getFirstDeriv EntObj InsParam) ) ) ) ) (vla-startundomark ActiveDocObj) (entmake (list (cons 0 "TEXT") (cons 1 TextString) (cons 40 TextHeight) (cons 10 InsPoint) (cons 11 InsPoint) (cons 41 TextWidth) (cons 50 TextAngle) (cons 72 1) (cons 73 2) ) ) (vla-endundomark ActiveDocObj) ) ) ) (princ) ) if you want to call it from another lisp, use (c:test) Quote
neekcotrack Posted August 1, 2008 Author Posted August 1, 2008 Thanks Ill try it in the morning! Quote
neekcotrack Posted August 1, 2008 Author Posted August 1, 2008 Is there a way to take your last lisp the one that does not break, and Have it ask how many tic? [3],[4],[5],[6],[7],[8],[9]. For what ever number you pick it puts /// for [3], //// for [4], ///// for [5]..ect... It be putting the /// in the text part. Cause I can you the last thing you sent but I would have to change the text part in for each one and I would have 7 lisp for the tics alone and One master that would call up the lisp depending if its 3,4,5...etc... Thanks in advance for all you help so for and any future help. Quote
VovKa Posted August 1, 2008 Posted August 1, 2008 there you go (vl-load-com) (defun C:Test (/ ActiveDocObj Ent EntName EntObj InsParam InsPoint Temp TextAngle TextHeight TextString TextWidth ) (setq TextHeight 5.0 TextString "" TextWidth 0.4 ) (repeat (progn (initget 7) (getint "\nNumber of tics: ")) (setq TextString (strcat TextString "/")) ) (setq ActiveDocObj (vla-get-activedocument (vlax-get-acad-object))) (vla-EndUndoMark ActiveDocObj) (while (and (setq Ent (entsel))) (setq EntName (car Ent)) (if (and (wcmatch (vla-get-ObjectName (setq EntObj (vlax-ename->vla-object EntName)) ) "AcDbLine,AcDbPolyline,AcDbArc,AcDbCircle" ) (setq InsPoint (vlax-curve-getClosestPointTo EntObj (cadr Ent))) (setq InsParam (vlax-curve-getParamAtPoint EntObj InsPoint)) ) (progn (setq TextAngle ((lambda (d) (if (zerop (cadr d)) (/ pi 2) (atan (apply '/ d)) ) ) (cdr (reverse (vlax-curve-getFirstDeriv EntObj InsParam) ) ) ) ) (vla-startundomark ActiveDocObj) (entmake (list (cons 0 "TEXT") (cons 1 TextString) (cons 40 TextHeight) (cons 10 InsPoint) (cons 11 InsPoint) (cons 41 TextWidth) (cons 50 TextAngle) (cons 72 1) (cons 73 2) ) ) (vla-endundomark ActiveDocObj) ) ) ) (princ) ) Quote
neekcotrack Posted October 22, 2008 Author Posted October 22, 2008 Vovka, I need to tak this lisp one step further. Can I make a text style called tic and make it romans and make the text 10, then put the tics on that layer. Is that possible. Quote
VovKa Posted October 23, 2008 Posted October 23, 2008 (vl-load-com) (defun C:Test (/ ActiveDocObj Ent EntName EntObj InsParam InsPoint Temp TextAngle TextHeight TextString TextWidth TextStyle TextLayer ) (setq TextHeight 10.0 TextString "" TextWidth 0.4 TextStyle "Tics" TextLayer "Wires" ) (if (not (tblsearch "LAYER" TextLayer)) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 TextLayer) (cons 62 11) (cons 70 0) ) ) ) (if (not (tblsearch "STYLE" TextStyle)) (entmake (list (cons 0 "STYLE") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbTextStyleTableRecord") (cons 2 TextStyle) (cons 70 0) (cons 40 TextHeight) (cons 41 1.0) (cons 50 0.0) (cons 71 0) (cons 42 TextHeight) (cons 3 "Write your font name here") ;;; (cons 3 "isocpeur.ttf") (cons 4 "") ) ) ) (repeat (progn (initget 7) (getint "\nNumber of tics: ")) (setq TextString (strcat TextString "/")) ) (setq ActiveDocObj (vla-get-activedocument (vlax-get-acad-object))) (vla-EndUndoMark ActiveDocObj) (while (and (setq Ent (entsel))) (setq EntName (car Ent)) (if (and (wcmatch (vla-get-ObjectName (setq EntObj (vlax-ename->vla-object EntName)) ) "AcDbLine,AcDbPolyline,AcDbArc,AcDbCircle" ) (setq InsPoint (vlax-curve-getClosestPointTo EntObj (cadr Ent))) (setq InsParam (vlax-curve-getParamAtPoint EntObj InsPoint)) ) (progn (setq TextAngle ((lambda (d) (if (zerop (cadr d)) (/ pi 2) (atan (apply '/ d)) ) ) (cdr (reverse (vlax-curve-getFirstDeriv EntObj InsParam) ) ) ) ) (vla-startundomark ActiveDocObj) (entmake (list (cons 0 "TEXT") (cons 7 TextStyle) (cons 8 TextLayer) (cons 1 TextString) (cons 40 TextHeight) (cons 10 InsPoint) (cons 11 InsPoint) (cons 41 TextWidth) (cons 50 TextAngle) (cons 72 1) (cons 73 2) ) ) (vla-endundomark ActiveDocObj) ) ) ) (princ) ) Quote
neekcotrack Posted October 23, 2008 Author Posted October 23, 2008 Is there any way to make the layer Wires and put it on color 11? This is the layer I want the tics on. Thanks, Quote
