looking for the symbol of a P over an L anyone know where i can find it?
Mtext,.. right click, symbol, Property Line
Off subject, but similar. How do you make a specific string sub/superscript?
Superscript- say 4 squared...
using Mtext type 42^
highlight the 2^
hit the stack fraction button on the Text Formatting toolbar
Subscript-
same procedure but use ^2 to subscript the 2
highlight the 2^
Subscript-
Thank you thank you thank you. :love:
How's 'bout a C over the L for center line?
I don't have a clue(?).
Same as P/L. Set to arial font and look in symbols.
Depending on the font file, you can enter the unicode string e.g. \U+2104 for centerline. Works in Mtext and Dtext
from Help
  Quote
%%d
\U+00B0
Degree symbol (°)
%%p
\U+00B1
Tolerance symbol (±)
%%c
\U+2205
Diameter symbol
To insert the following text symbols, click Symbol on the expanded Text Formatting toolbar or enter the appropriate Unicode string:
Text symbols and Unicode strings
Almost equal \U+2248
Angle \U+2220
Boundary line \U+E100
Centerline \U+2104
Delta \U+0394
Electrical phase \U+0278
Flow line \U+E101
Identity \U+2261
Initial length \U+E200
Monument line \U+E102
Not equal \U+2260
Ohm \U+2126
Omega \U+03A9
Plate/property line \U+214A
Subscript 2 \U+2082
Squared \U+00B2
Cubed \U+00B3
These text symbols are available in the following True Type (TTF) and SHX fonts:
  • Simplex
  • RomanS
  • Isocp
  • Isocp2
  • Isocp3
  • Isoct
  • Isoct2
  • Isoct3
  • Isocpeur (TTF only)
  • Isocpeur italic (TTF only)
  • Isocteur (TTF only)
  • Isocteur italic (TTF only)
formatting got a bit squirrelly with the cut/paste
In Help you can find it under Unicode characters - strings
  • 11 years later...
