OSCGOLF Posted January 21, 2010 Share Posted January 21, 2010 I've come to the conclusuion that all the lines (polylines in my case) needed to be joined, for the entire group to be intentified. When I changed it, it worked. Thanks for your help... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted January 21, 2010 Share Posted January 21, 2010 You're welcome Quote Link to comment Share on other sites More sharing options...
Emily_83 Posted February 8, 2010 Share Posted February 8, 2010 Hello all, i was wondering if someone can show me in Asmi's Tabord2 .lsp how i can modify it too just give me the Points, Easting and Northing, BUT NOT the Radius or it's Column?? any help would be greatly appreciated. Cheers Emily :-) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 8, 2010 Share Posted February 8, 2010 Hmmm... I'm not sure that its a simple fix Could you not just delete the unnecessary columns/rows? Quote Link to comment Share on other sites More sharing options...
Emily_83 Posted February 8, 2010 Share Posted February 8, 2010 yeah i was thinking that it's just we have about 100 drawings to do and was thought that if i could get the code lsp to run how i need it would save time, :-D Lee would you be able to direct me (if there is one) to a post where i can find some information to use fields in a table, that when you move a point, it automatically updates the co-ordiantes in a table. i have been browsing about here but can't seem to find anything :-( i am sure it can be done can't it?? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 8, 2010 Share Posted February 8, 2010 Lee would you be able to direct me (if there is one) to a post where i can find some information to use fields in a table, that when you move a point, it automatically updates the co-ordiantes in a table. i have been browsing about here but can't seem to find anything :-( i am sure it can be done can't it?? Hi Emily, Yes, you can place fields in a table - and there is the "position" property for the point object that can be used. I put fields in a table recently: http://www.cadtutor.net/forum/showthread.php?t=44618 I would be happy to help you with something similar with points. Quote Link to comment Share on other sites More sharing options...
Emily_83 Posted February 8, 2010 Share Posted February 8, 2010 wow, Thanks So much Lee, i will start a new thread in here explaining what i am after, :-) Quote Link to comment Share on other sites More sharing options...
krishnakumaryadav Posted March 11, 2010 Share Posted March 11, 2010 Myself used multipal points of coordinates of road alignment and i want to insert pirticular name of used coordinate simultanously. Please guide me for the above. thanks K.K Yadav Quote Link to comment Share on other sites More sharing options...
simeon021 Posted March 29, 2010 Share Posted March 29, 2010 Does this work with AC2008? i cant get it run. command is ~'J'~ right? Quote Link to comment Share on other sites More sharing options...
asos2000 Posted March 29, 2010 Share Posted March 29, 2010 simeon021 Command is CAP please read this thread How to use routile Quote Link to comment Share on other sites More sharing options...
noyjoreb Posted April 25, 2010 Share Posted April 25, 2010 is it possible to generate also the area? and place it also in the table? ur code was so great... gthnx... Quote Link to comment Share on other sites More sharing options...
muthu123 Posted May 3, 2010 Share Posted May 3, 2010 > daveyboyd X,Y,Z for 3D-Poly: http://www.asmitools.com/Files/Lisps/3cord.html The link is not opening. where can i find that lisp file. Please help me. Quote Link to comment Share on other sites More sharing options...
fixo Posted May 3, 2010 Share Posted May 3, 2010 The link is not opening. where can i find that lisp file. Please help me. Here is it ;; ==================================================================== ;; ;; ;; ;; 3CORD.LSP - Fills the table in co-ordinates of 3DPolyline ;; ;; vertexes. Marks vertexes of 3DPolyline ;; ;; accordingly data in the table by digits or ;; ;; letters. Look section 'ADJUSTMENT' for ;; ;; acquaintance with options. ;; ;; ;; ;; ==================================================================== ;; ;; ;; ;; Command(s) to call: 3CORD ;; ;; ;; ;; Select 3DPolyline and after the table will be generated ;; ;; insert it into the necessary place. After that vertexes of ;; ;; polylines will be marked by figures or letters. ;; ;; ;; ;; ==================================================================== ;; ;; ;; ;; THIS PROGRAM AND PARTS OF IT MAY REPRODUCED BY ANY METHOD ON ANY ;; ;; MEDIUM FOR ANY REASON. YOU CAN USE OR MODIFY THIS PROGRAM OR ;; ;; PARTS OF IT ABSOLUTELY FREE. ;; ;; ;; ;; THIS PROGRAM PROVIDES 'AS IS' WITH ALL FAULTS AND SPECIFICALLY ;; ;; DISCLAIMS ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS ;; ;; FOR A PARTICULAR USE. ;; ;; ;; ;; ==================================================================== ;; ;; ;; ;; V1.3, 14th Aug 2008, Riga, Latvia ;; ;; © Aleksandr Smirnov (ASMI) ;; ;; For AutoCAD 2005 - 2008 (isn't tested in a next versions) ;; ;; ;; ;; [url]http://www.asmitools.com[/url] ;; ;; ;; ;; ==================================================================== ;; (defun c:3cord(/ aCen cAng cCen cPl cRad cReg fDr it lCnt lLst mSp pCen pT1 pT2 ptLst R tHt tLst vlaPl vlaTab vLst cTxt oldCol nPl clFlg actDoc tPt1 tPt2 cAng tiPt oSnp *error* mType mHt oZin cAcu dHead hStr hHt w1 w2) ;;; **************************************************************** ;;; *************************** ADJUSTMENT ************************* ;;; **************************************************************** (setq mType T) ; Markups mode. T - digits, NIL - letters (setq tHt -1.0) ; Table text size. Positive - absolute, ; negative multiplayer to TEXTSIZE variable (setq mHt -1.0) ; Markups text size. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq cAcu 4) ; Precision of coordinates (from 0 to (setq dHead T) ; If T delete table header, if NIL not delete (setq hStr "Bnd # ") ; Standard header (if dHead not equal T) (setq hHt -1.25) ; Header text size. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq w1 -10.0) ; 'Point' column width. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq w2 -15.0) ; 'X', 'Y' and 'Z' colums width. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable ;;; **************************************************************** ;;; ************************* END ADJUSTMENT *********************** ;;; **************************************************************** (if(minusp tHt) (setq tHt(getvar "TEXTSIZE")) ); end if (if(minusp mHt) (setq mHt(*(abs mHt)(getvar "TEXTSIZE"))) ); end if (if(minusp hHt) (setq hHt(*(abs hHt)(getvar "TEXTSIZE"))) ); end if (if(minusp w1) (setq w1(*(abs w1)(getvar "TEXTSIZE"))) ); end if (if(minusp w2) (setq w2(*(abs w2)(getvar "TEXTSIZE"))) ); end if (vl-load-com) (defun Get_Acad_Ver(Gen_Only) (if Gen_Only (substr(getvar "ACADVER") 1 2) (substr(getvar "ACADVER") 1 4) ); end if ); and of Get_Acad_Ver (defun Extract_3DPoly_Vertexes(Ent / cLst oLst) (if(= 'ENAME(type Ent)) (setq Ent(vlax-ename->vla-object Ent)) ); end if (if(= "AcDb3dPolyline"(vla-get-ObjectName Ent)) (progn (setq cLst(vlax-safearray->list (vlax-variant-value (vla-get-Coordinates Ent)))) (while cLst (setq oLst(cons(list (car cLst) (cadr cLst) (nth 2 cLst)) oLst) ); end setq (repeat 3(setq cLst(cdr cLst))) ); end while (reverse oLst) ); end progn ); end if ); end of Extract_3DPoly_Vertexes (defun *error*(msg) (setvar "CMDECHO" 1) (if oSnp(setvar "OSMODE" oSnp)) (if oZin(setvar "DIMZIN" oZin)) (if mSp(vla-EndUndoMark actDoc)) (princ) ); end of *error* (defun Alph_Num(Counter / lLst cRes) (setq lLst '("A" "B" "C" "D" "E" "F" "G" "H" "I" "J" "K" "L" "M" "N" "O" "P" "Q" "R" "S" "T" "U" "V" "W" "X" "Y" "Z")) (if(<= 1.0(setq cRes(/ Counter 26.0))) (strcat(itoa(fix cRes)) (nth(- Counter(* 26(fix cRes)))lLst)) (nth Counter lLst) ); end if ); end of Alph_Num (if(<= 16.1(atof(Get_Acad_Ver nil))) (progn (if (and (setq cPl(entsel "\nSelect 3DPoliline > ")) (setq vlaPl(vlax-ename->vla-object(car cPl))) (= "AcDb3dPolyline"(vla-get-ObjectName vlaPl)) ); end and (progn (princ "\nPlease Wait... \n") (setq ptLst(Extract_3DPoly_Vertexes vlaPl) r 2 lCnt 0 tLst '((1 0 "Point")(1 1 "X")(1 2 "Y")(1 3 "Z")) actDoc(vla-get-ActiveDocument (vlax-get-acad-object)) mSp(vla-get-ModelSpace actDoc) ); end setq (setvar "CMDECHO" 0) (setq oSnp(getvar "OSMODE")) (setq oZin(getvar "DIMZIN")) (setvar "DIMZIN" 0) (vla-StartUndoMark actDoc) (foreach vert ptLst (setq vert(trans vert 0 1) tLst(append tLst (list (list r 0(if mType (itoa(1+ lCnt)) (Alph_Num lCnt))) (list r 1(rtos(car vert)2 cAcu)) (list r 2(rtos(cadr vert)2 cAcu)) (list r 3(rtos(nth 2 vert)2 cAcu)))) ); end setq (setq r(1+ r) lCnt(1+ lCnt)) ); end foreach (setq vlaTab(vla-AddTable mSp (vlax-3D-point '(0 0 0)) (+ 1(/(length tLst)4)) 4 (* 3 tHt)w2)) (foreach i tLst (vl-catch-all-apply 'vla-SetText(cons vlaTab i)) (vla-SetCellTextHeight vlaTab(car i)(cadr i)tHt) (vla-SetCellAlignment vlaTab(car i)(cadr i)acMiddleCenter) ); end foreach (vla-put-VertCellMargin vlaTab (* 0.75 tHt)) (vla-SetColumnWidth vlaTab 0 w1) (if(vlax-property-available-p vlaTab 'RepeatTopLabels) (vla-put-RepeatTopLabels vlaTab :vlax-true) ); end if (if(vlax-property-available-p vlaTab 'BreakSpacing) (vla-put-BreakSpacing vlaTab (* 3 tHt)) ); end if (if dHead (vla-DeleteRows vlaTab 0 1) (progn (vla-SetText vlaTab 0 0 hStr) (vla-SetCellTextHeight vlaTab 0 0 hHt) ); end progn ); end if (vla-put-Height vlaTab(* 1.75(/(length tLst)4))) (princ "\n<<< Place Table >>> ") (command "_.copybase" (trans '(0 0 0)0 1)(entlast) "") (command "_.erase" (entlast) "") (command "_.pasteclip" pause) (setq lCnt 0) (foreach v ptLst (setq tPt1(vlax-curve-GetPointAtParam vlaPl (+ lCnt 0.0000001)) tPt2(vlax-curve-GetPointAtParam vlaPl (- lCnt 0.0000001)) iPt(polar v(+(* pi 0.5)(if(minusp (setq cAng(angle(if tPt1 tPt1 tPt2) (if tPt2 tPt2(polar tPt1(* 0.5 pi)0.0000001))))) cAng(- cAng)))(* 2 mHt)) ); end setq (setvar "OSMODE" 0) (setq cTxt(vla-AddText mSp (if mType(itoa(1+ lCnt))(Alph_Num lCnt)) (vlax-3d-point iPt) mHt) tiPt(vla-get-InsertionPoint cTxt) lCnt(1+ lCnt) ); end setq (vla-put-Alignment cTxt 10) (vla-put-TextAlignmentPoint cTxt tiPt) (setq oldCol(getvar "CECOLOR")) (setvar "CECOLOR" "1") (command "_.circle"(trans v 0 1) (/ mHt 4)) (setvar "CECOLOR" oldCol) ); end foreach (setvar "DIMZIN" oZin) (setvar "OSMODE" oSnp) (setvar "CMDECHO" 1) (vla-EndUndoMark actDoc) ); end progn (princ "\n<!> It isn't 3DPolyline! Quit. <!> ") ); end if ); end progn (princ "\n<!> This program works in AutoCAD 2005+ only! <!> " ) );end if (gc) (princ) ); end of c:3cord (princ "\n[info] http:\\\\[url="http://www.AsmiTools.com"]www.AsmiTools.com[/url] [info]") (princ "\n[info] Type 3CORD to fill table of 3D-Polyline coordinates. [info]") ~'J'~ Quote Link to comment Share on other sites More sharing options...
muthu123 Posted May 3, 2010 Share Posted May 3, 2010 Here is it ;; ==================================================================== ;; ;; ;; ;; 3CORD.LSP - Fills the table in co-ordinates of 3DPolyline ;; ;; vertexes. Marks vertexes of 3DPolyline ;; ;; accordingly data in the table by digits or ;; ;; letters. Look section 'ADJUSTMENT' for ;; ;; acquaintance with options. ;; ;; ;; ;; ==================================================================== ;; ;; ;; ;; Command(s) to call: 3CORD ;; ;; ;; ;; Select 3DPolyline and after the table will be generated ;; ;; insert it into the necessary place. After that vertexes of ;; ;; polylines will be marked by figures or letters. ;; ;; ;; ;; ==================================================================== ;; ;; ;; ;; THIS PROGRAM AND PARTS OF IT MAY REPRODUCED BY ANY METHOD ON ANY ;; ;; MEDIUM FOR ANY REASON. YOU CAN USE OR MODIFY THIS PROGRAM OR ;; ;; PARTS OF IT ABSOLUTELY FREE. ;; ;; ;; ;; THIS PROGRAM PROVIDES 'AS IS' WITH ALL FAULTS AND SPECIFICALLY ;; ;; DISCLAIMS ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS ;; ;; FOR A PARTICULAR USE. ;; ;; ;; ;; ==================================================================== ;; ;; ;; ;; V1.3, 14th Aug 2008, Riga, Latvia ;; ;; © Aleksandr Smirnov (ASMI) ;; ;; For AutoCAD 2005 - 2008 (isn't tested in a next versions) ;; ;; ;; ;; [url]http://www.asmitools.com[/url] ;; ;; ;; ;; ==================================================================== ;; (defun c:3cord(/ aCen cAng cCen cPl cRad cReg fDr it lCnt lLst mSp pCen pT1 pT2 ptLst R tHt tLst vlaPl vlaTab vLst cTxt oldCol nPl clFlg actDoc tPt1 tPt2 cAng tiPt oSnp *error* mType mHt oZin cAcu dHead hStr hHt w1 w2) ;;; **************************************************************** ;;; *************************** ADJUSTMENT ************************* ;;; **************************************************************** (setq mType T) ; Markups mode. T - digits, NIL - letters (setq tHt -1.0) ; Table text size. Positive - absolute, ; negative multiplayer to TEXTSIZE variable (setq mHt -1.0) ; Markups text size. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq cAcu 4) ; Precision of coordinates (from 0 to (setq dHead T) ; If T delete table header, if NIL not delete (setq hStr "Bnd # ") ; Standard header (if dHead not equal T) (setq hHt -1.25) ; Header text size. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq w1 -10.0) ; 'Point' column width. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq w2 -15.0) ; 'X', 'Y' and 'Z' colums width. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable ;;; **************************************************************** ;;; ************************* END ADJUSTMENT *********************** ;;; **************************************************************** (if(minusp tHt) (setq tHt(getvar "TEXTSIZE")) ); end if (if(minusp mHt) (setq mHt(*(abs mHt)(getvar "TEXTSIZE"))) ); end if (if(minusp hHt) (setq hHt(*(abs hHt)(getvar "TEXTSIZE"))) ); end if (if(minusp w1) (setq w1(*(abs w1)(getvar "TEXTSIZE"))) ); end if (if(minusp w2) (setq w2(*(abs w2)(getvar "TEXTSIZE"))) ); end if (vl-load-com) (defun Get_Acad_Ver(Gen_Only) (if Gen_Only (substr(getvar "ACADVER") 1 2) (substr(getvar "ACADVER") 1 4) ); end if ); and of Get_Acad_Ver (defun Extract_3DPoly_Vertexes(Ent / cLst oLst) (if(= 'ENAME(type Ent)) (setq Ent(vlax-ename->vla-object Ent)) ); end if (if(= "AcDb3dPolyline"(vla-get-ObjectName Ent)) (progn (setq cLst(vlax-safearray->list (vlax-variant-value (vla-get-Coordinates Ent)))) (while cLst (setq oLst(cons(list (car cLst) (cadr cLst) (nth 2 cLst)) oLst) ); end setq (repeat 3(setq cLst(cdr cLst))) ); end while (reverse oLst) ); end progn ); end if ); end of Extract_3DPoly_Vertexes (defun *error*(msg) (setvar "CMDECHO" 1) (if oSnp(setvar "OSMODE" oSnp)) (if oZin(setvar "DIMZIN" oZin)) (if mSp(vla-EndUndoMark actDoc)) (princ) ); end of *error* (defun Alph_Num(Counter / lLst cRes) (setq lLst '("A" "B" "C" "D" "E" "F" "G" "H" "I" "J" "K" "L" "M" "N" "O" "P" "Q" "R" "S" "T" "U" "V" "W" "X" "Y" "Z")) (if(<= 1.0(setq cRes(/ Counter 26.0))) (strcat(itoa(fix cRes)) (nth(- Counter(* 26(fix cRes)))lLst)) (nth Counter lLst) ); end if ); end of Alph_Num (if(<= 16.1(atof(Get_Acad_Ver nil))) (progn (if (and (setq cPl(entsel "\nSelect 3DPoliline > ")) (setq vlaPl(vlax-ename->vla-object(car cPl))) (= "AcDb3dPolyline"(vla-get-ObjectName vlaPl)) ); end and (progn (princ "\nPlease Wait... \n") (setq ptLst(Extract_3DPoly_Vertexes vlaPl) r 2 lCnt 0 tLst '((1 0 "Point")(1 1 "X")(1 2 "Y")(1 3 "Z")) actDoc(vla-get-ActiveDocument (vlax-get-acad-object)) mSp(vla-get-ModelSpace actDoc) ); end setq (setvar "CMDECHO" 0) (setq oSnp(getvar "OSMODE")) (setq oZin(getvar "DIMZIN")) (setvar "DIMZIN" 0) (vla-StartUndoMark actDoc) (foreach vert ptLst (setq vert(trans vert 0 1) tLst(append tLst (list (list r 0(if mType (itoa(1+ lCnt)) (Alph_Num lCnt))) (list r 1(rtos(car vert)2 cAcu)) (list r 2(rtos(cadr vert)2 cAcu)) (list r 3(rtos(nth 2 vert)2 cAcu)))) ); end setq (setq r(1+ r) lCnt(1+ lCnt)) ); end foreach (setq vlaTab(vla-AddTable mSp (vlax-3D-point '(0 0 0)) (+ 1(/(length tLst)4)) 4 (* 3 tHt)w2)) (foreach i tLst (vl-catch-all-apply 'vla-SetText(cons vlaTab i)) (vla-SetCellTextHeight vlaTab(car i)(cadr i)tHt) (vla-SetCellAlignment vlaTab(car i)(cadr i)acMiddleCenter) ); end foreach (vla-put-VertCellMargin vlaTab (* 0.75 tHt)) (vla-SetColumnWidth vlaTab 0 w1) (if(vlax-property-available-p vlaTab 'RepeatTopLabels) (vla-put-RepeatTopLabels vlaTab :vlax-true) ); end if (if(vlax-property-available-p vlaTab 'BreakSpacing) (vla-put-BreakSpacing vlaTab (* 3 tHt)) ); end if (if dHead (vla-DeleteRows vlaTab 0 1) (progn (vla-SetText vlaTab 0 0 hStr) (vla-SetCellTextHeight vlaTab 0 0 hHt) ); end progn ); end if (vla-put-Height vlaTab(* 1.75(/(length tLst)4))) (princ "\n<<< Place Table >>> ") (command "_.copybase" (trans '(0 0 0)0 1)(entlast) "") (command "_.erase" (entlast) "") (command "_.pasteclip" pause) (setq lCnt 0) (foreach v ptLst (setq tPt1(vlax-curve-GetPointAtParam vlaPl (+ lCnt 0.0000001)) tPt2(vlax-curve-GetPointAtParam vlaPl (- lCnt 0.0000001)) iPt(polar v(+(* pi 0.5)(if(minusp (setq cAng(angle(if tPt1 tPt1 tPt2) (if tPt2 tPt2(polar tPt1(* 0.5 pi)0.0000001))))) cAng(- cAng)))(* 2 mHt)) ); end setq (setvar "OSMODE" 0) (setq cTxt(vla-AddText mSp (if mType(itoa(1+ lCnt))(Alph_Num lCnt)) (vlax-3d-point iPt) mHt) tiPt(vla-get-InsertionPoint cTxt) lCnt(1+ lCnt) ); end setq (vla-put-Alignment cTxt 10) (vla-put-TextAlignmentPoint cTxt tiPt) (setq oldCol(getvar "CECOLOR")) (setvar "CECOLOR" "1") (command "_.circle"(trans v 0 1) (/ mHt 4)) (setvar "CECOLOR" oldCol) ); end foreach (setvar "DIMZIN" oZin) (setvar "OSMODE" oSnp) (setvar "CMDECHO" 1) (vla-EndUndoMark actDoc) ); end progn (princ "\n<!> It isn't 3DPolyline! Quit. <!> ") ); end if ); end progn (princ "\n<!> This program works in AutoCAD 2005+ only! <!> " ) );end if (gc) (princ) ); end of c:3cord (princ "\n[info] http:\\\\[url="http://www.AsmiTools.com"]www.AsmiTools.com[/url] [info]") (princ "\n[info] Type 3CORD to fill table of 3D-Polyline coordinates. [info]") ~'J'~ Thank you.But i need for 2d polyline.. Quote Link to comment Share on other sites More sharing options...
VVA Posted May 3, 2010 Share Posted May 3, 2010 The link is not opening. where can i find that lisp file. Please help me. But i need for 2d polyline Use TABCORD from TABCORD.lsp. AsmiTools archives here To convert 2d polyline (heavy) to LW (light or compact) use _convert or _convertpoly command Quote Link to comment Share on other sites More sharing options...
asmolen Posted June 2, 2010 Share Posted June 2, 2010 Its very good tooll... but i have a question... which parameters i need to change for changing the corrdinate precision for ex i need 3 units after seperator not 4... and the cecond question i need to type not the radius but the lenght between points... again where i need to change in this code? ;; ==================================================================== ;;;; ;; ;; TABCORD.LSP - Fills the table in co-ordinates of LwPolyline ;; ;; vertexes, and also the centres and radiuses ;; ;; of arc segments. Marks vertexes of LwPolyline ;; ;; accordingly data in the table by digits or ;; ;; letters. Look section 'ADJUSTMENT' for ;; ;; acquaintance with options. ;; ;; ;; ;; ==================================================================== ;; ;; ;; ;; Command(s) to call: TABCORD ;; ;; ;; ;; Select LwPolyline and after the table will be generated ;; ;; insert it into the necessary place. After that vertexes of ;; ;; polylines will be marked by figures or letters. ;; ;; ;; ;; ==================================================================== ;; ;; ;; ;; THIS PROGRAM AND PARTS OF IT MAY REPRODUCED BY ANY METHOD ON ANY ;; ;; MEDIUM FOR ANY REASON. YOU CAN USE OR MODIFY THIS PROGRAM OR ;; ;; PARTS OF IT ABSOLUTELY FREE. ;; ;; ;; ;; THIS PROGRAM PROVIDES 'AS IS' WITH ALL FAULTS AND SPECIFICALLY ;; ;; DISCLAIMS ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS ;; ;; FOR A PARTICULAR USE. ;; ;; ;; ;; ==================================================================== ;; ;; ;; ;; V1.3, 14th Aug 2008, Riga, Latvia ;; ;; © Aleksandr Smirnov (ASMI) ;; ;; For AutoCAD 2005 - 2008 (isn't tested in a next versions) ;; ;; ;; ;; ;; ;; ;; ;; ==================================================================== ;; (defun c:tabcord(/ aCen cAng cCen cPl cRad cReg fDr it lCnt lLst mSp pCen pT1 pT2 ptLst R tHt tLst vlaPl vlaTab vLst cTxt oldCol nPl clFlg actDoc tPt1 tPt2 cAng tiPt oSnp *error* mType mHt oZin cAcu dHead hStr hHt w1 w2 w3 isPer isAre pMul aMul lWrt aVal xVal yVal) ;;; **************************************************************** ;;; *************************** ADJUSTMENT ************************* ;;; **************************************************************** (setq mType nil) ; Markups mode. T - digits, NIL - letters (setq tHt -1.0) ; Table text size. Positive - absolute, ; negative multiplayer to TEXTSIZE variable (setq mHt -2.0) ; Markups text size. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq cAcu 4) ; Precision of coordinates (from 0 to (setq dHead nil) ; If T delete table header, if NIL not delete (setq hStr "Land # ") ; Standard header (if dHead not equal T) (setq hHt -1.25) ; Header text size. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq w1 -10.0) ; 'Point' column width. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq w2 -20.0) ; 'X' and 'Y' colums width. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq w3 -12.0) ; 'Radius' column width. Positive - absolute, ; negative - multiplayer to TEXTSIZE variable (setq isPer T) ; if T adds perimeter row (setq isAre T) ; if T adds area row (setq isGCen T) ; if T adds center of gravity row (setq pMul 0.001) ; perimeter multiplayer (setq aMul 0.000001) ; area multiplayer ;;; **************************************************************** ;;; ************************* END ADJUSTMENT *********************** ;;; **************************************************************** (if(minusp tHt) (setq tHt(getvar "TEXTSIZE")) ); end if (if(minusp mHt) (setq mHt(*(abs mHt)(getvar "TEXTSIZE"))) ); end if (if(minusp hHt) (setq hHt(*(abs hHt)(getvar "TEXTSIZE"))) ); end if (if(minusp w1) (setq w1(*(abs w1)(getvar "TEXTSIZE"))) ); end if (if(minusp w2) (setq w2(*(abs w2)(getvar "TEXTSIZE"))) ); end if (if(minusp w3) (setq w3(*(abs w3)(getvar "TEXTSIZE"))) ); end if (vl-load-com) (defun Get_Acad_Ver(Gen_Only) (if Gen_Only (substr(getvar "ACADVER") 1 2) (substr(getvar "ACADVER") 1 4) ); end if ); and of Get_Acad_Ver (defun Extract_DXF_Values(Ent Code) (mapcar 'cdr (vl-remove-if-not '(lambda(a)(=(car a)Code)) (entget Ent))) ); end of (defun *error*(msg) (setvar "CMDECHO" 1) (if oSnp(setvar "OSMODE" oSnp)) (if oZin(setvar "DIMZIN" oZin)) (if mSp(vla-EndUndoMark actDoc)) (princ) ); end of *error* (defun Alph_Num(Counter / lLst cRes) (setq lLst '("A" "B" "C" "D" "E" "F" "G" "H" "I" "J" "K" "L" "M" "N" "O" "P" "Q" "R" "S" "T" "U" "V" "W" "X" "Y" "Z")) (if( (strcat(itoa(fix cRes)) (nth(- Counter(* 26(fix cRes)))lLst)) (nth Counter lLst) ); end if ); end of Alph_Num (if( (progn (if (and (setq cPl(entsel "\nSelect LwPoliline > ")) (= "LWPOLYLINE"(car(Extract_DXF_Values(car cPl)0))) ); end and (progn (princ "\nPlease Wait... \n") (setq vlaPl(vlax-ename->vla-object(car cPl)) ptLst(mapcar 'append (setq vLst(Extract_DXF_Values(car cPl)10)) (mapcar 'list(Extract_DXF_Values(car cPl)42))) r 2 lCnt 0 tLst '((1 0 "Point")(1 1 "X")(1 2 "Y")(1 3 "Radius")) actDoc(vla-get-ActiveDocument (vlax-get-acad-object)) mSp(vla-get-ModelSpace actDoc) ); end setq (setvar "CMDECHO" 0) (setq oSnp(getvar "OSMODE")) (setq oZin(getvar "DIMZIN")) (setvar "DIMZIN" 0) (vla-StartUndoMark actDoc) (foreach vert ptLst (setq vert(trans vert 0 1) tLst(append tLst (list(list r 0(if mType (itoa(1+ lCnt)) (Alph_Num lCnt))) (list r 1(rtos(car vert)2 cAcu)) (list r 2(rtos(cadr vert)2 cAcu)) (list r 3 "")))) (if(and (/= 0.0(last vert)) (setq pt1(vlax-curve-GetPointAtParam vlaPl lCnt)) (setq pt2(vlax-curve-GetPointAtParam vlaPl(1+ lCnt))) ); end and (setq r(1+ r) cRad(abs(/(distance pt1 pt2) 2(sin(/(* 4(atan(abs(last vert))))2)))) aCen(vlax-curve-GetPointAtParam vlaPl(+ 0.5 lCnt)) fDr(vlax-curve-getFirstDeriv vlaPl (vlax-curve-getParamAtPoint vlaPl aCen)) pCen(trans (polar aCen(-(if(minusp(last vert)) pi(* 2 pi)) (atan(/(car fDr)(cadr fDr))))cRad)0 1) tLst(append tLst(list (list r 0 "center") (list r 1(rtos(car pCen)2 cAcu)) (list r 2(rtos(cadr pCen)2 cAcu)) (list r 3(rtos cRad 2 cAcu)))) ); end setq ); end if (setq r(1+ r) lCnt(1+ lCnt)) ); end foreach (setq vlaTab(vla-AddTable mSp (vlax-3D-point '(0 0 0)) (+ 1(/(length tLst)4)) 4 (* 3 tHt)w2)) (foreach i tLst (vl-catch-all-apply 'vla-SetText(cons vlaTab i)) (vla-SetCellTextHeight vlaTab(car i)(cadr i)tHt) (vla-SetCellAlignment vlaTab(car i)(cadr i)acMiddleCenter) ); end foreach (if(or isPer isAre) (progn (vla-InsertRows vlaTab r(* 0.05 tHt)1) (vla-SetCellTextHeight vlaTab r 0(* 0.05 tHt)) (setq r(1+ r)) ); end progn ); end if (if isPer (progn (if(= :vlax-true(vla-get-Closed vlaPl)) (setq lWrt "Perimeter") (setq lWrt "Length") ); end if (vla-InsertRows vlaTab r tHt 1) (vla-SetText vlaTab r 0 lWrt) (vla-SetText vlaTab r 1 (rtos(*(vla-get-Length vlaPl)pMul)2 cAcu)) (vla-SetCellTextHeight vlaTab r 0 tHt) (vla-SetCellTextHeight vlaTab r 1 tHt) (setq r(1+ r)) ); end progn ); end if (if isAre (progn (if(= :vlax-true(vla-get-Closed vlaPl)) (setq aVal (rtos(*(vla-get-Area vlaPl)aMul)2 cAcu)) (setq aVal "Not closed contour") ); end if (vla-InsertRows vlaTab r tHt 1) (vla-SetText vlaTab r 0 "Area") (vla-SetText vlaTab r 1 aVal) (vla-SetCellTextHeight vlaTab r 0 tHt) (vla-SetCellTextHeight vlaTab r 1 tHt) (setq r(1+ r)) ); end progn ); end if (if(= :vlax-true(vla-get-Closed vlaPl)) (progn (setq nPl(vla-Copy vlaPl)) (command "_.region" (entlast) "") (setq cCen(vlax-get(setq cReg (vlax-ename->vla-object(entlast)))'Centroid)) (vla-Delete cReg) (setq clFlg T) ); end progn ); end if (if isAre (progn (if cCen (setq xVal(rtos(car cCen)2 cAcu) yVal (rtos(cadr cCen)2 cAcu)) (setq xVal "-" yVal "-") ); end if (vla-InsertRows vlaTab r tHt 1) (vla-SetText vlaTab r 0 "Gravity Center") (vla-SetText vlaTab r 1 xVal) (vla-SetText vlaTab r 2 yVal) (vla-SetCellTextHeight vlaTab r 0 tHt) (vla-SetCellTextHeight vlaTab r 1 tHt) (vla-SetCellTextHeight vlaTab r 2 tHt) (setq r(1+ r)) ); end progn ); end if (vla-put-VertCellMargin vlaTab (* 0.75 tHt)) (vla-SetColumnWidth vlaTab 0 w1) (vla-SetColumnWidth vlaTab 3 w3) (if(vlax-property-available-p vlaTab 'RepeatTopLabels) (vla-put-RepeatTopLabels vlaTab :vlax-true) ); end if (if(vlax-property-available-p vlaTab 'BreakSpacing) (vla-put-BreakSpacing vlaTab (* 3 tHt)) ); end if (if dHead (vla-DeleteRows vlaTab 0 1) (progn (vla-SetText vlaTab 0 0 hStr) (vla-SetCellTextHeight vlaTab 0 0 hHt) ); end progn ); end if (vla-put-Height vlaTab(* 1.75(/(length tLst)4))) (princ "\n>> ") (command "_.copybase" (trans '(0 0 0)0 1)(entlast) "") (command "_.erase" (entlast) "") (command "_.pasteclip" pause) (setq lCnt 0) (foreach v vLst (if clFlg (setq cAng(angle cCen(trans v 0 1)) iPt(polar v cAng (* 2 mHt))) (setq tPt1(vlax-curve-GetPointAtParam vlaPl (- lCnt 0.0000001)) tPt2(vlax-curve-GetPointAtParam vlaPl (+ lCnt 0.0000001)) iPt(polar v(+(* pi 0.5)(if(minusp (setq cAng(angle tPt1(if tPt2 tPt2 (polar tPt1(* 0.5 pi)0.0000001))))) cAng(- cAng)))(* 2 mHt)) ); end setq ); end if (setvar "OSMODE" 0) (setq cTxt(vla-AddText mSp (if mType(itoa(1+ lCnt))(Alph_Num lCnt)) (vlax-3d-point iPt) mHt) tiPt(vla-get-InsertionPoint cTxt) lCnt(1+ lCnt) ); end setq (vla-put-Alignment cTxt 10) (vla-put-TextAlignmentPoint cTxt tiPt) (setq oldCol(getvar "CECOLOR")) (setvar "CECOLOR" "1") (command "_.circle"(trans v 0 1) (/ mHt 4)) (setvar "CECOLOR" oldCol) ); end foreach (setvar "DIMZIN" oZin) (setvar "OSMODE" oSnp) (setvar "CMDECHO" 1) (vla-EndUndoMark actDoc) ); end progn (princ "\n It isn't LwPolyline! Quit. ") ); end if ); end progn (princ "\n This program works in AutoCAD 2005+ only! " ) );end if (gc) (princ) ); end of c:tabcord (princ "\n[info] [info]") (princ "\n[info] Type TABCORD to fill table of LwPolyline coordinates [info]") Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 2, 2010 Share Posted June 2, 2010 There is an adjustment section as noted. Quote Link to comment Share on other sites More sharing options...
Nardino Posted June 2, 2010 Share Posted June 2, 2010 would anybody know how to add a Z walue to the table? Quote Link to comment Share on other sites More sharing options...
Nardino Posted June 2, 2010 Share Posted June 2, 2010 oops, i meant VALUE Quote Link to comment Share on other sites More sharing options...
asmolen Posted June 3, 2010 Share Posted June 3, 2010 Hello Lee Mac, i have seen the adjustmens section that i need to change the (setq cAcu 4) value but i couldnt decide which parameter need to change exactly.. cos i dont know the language of this code... and i dont know how to change the radius to distance.. cos i need distance value between points at my topographic plans.. thank you Quote Link to comment Share on other sites More sharing options...
