dwilcox13 Posted October 9, 2009 Share Posted October 9, 2009 I have a user that is opening a dwg in AMEP 2008. (OS in use is Microsoft XP) The dwg contains links to multiple Excel files (panel schedules). When she opens the dwg, it updates the links like normal but it actually opens the Excel program. It is not opening the worksheets that are linked it just opens the Excel program with no worksheets open or hidden. It only happens on her PC and noone else's in the office. Is there a way to stop this? Is there some obscure system variable to control this? Here's the background info on the drawing and what we've tried. The links were put in by copying information from Excel and using the Paste Special feature under Edit and choosing the Paste as Link option. The links are fine, not broken, and pointing to the correct worksheets. We've made sure that the worksheets are not in use, not Hidden or locked in Excel and not marked as Read Only. Quote Link to comment Share on other sites More sharing options...
whitehaint Posted October 10, 2009 Share Posted October 10, 2009 Sounds like at some point excel was picked as the default program to open that file type. Quote Link to comment Share on other sites More sharing options...
dwilcox13 Posted October 12, 2009 Author Share Posted October 12, 2009 I double checked your idea whitehaint but it didn't solve it. I had the user right click on a dwg file, choose open with AutoCAD MEP and check the box for Always open this type of file with this program. But still opens Excel. Let me clarify, the dwg opens in AMEP like it should but while its still loading up and refreshing the Excel links it will open an empty Excel program. Any other ideas out there? Quote Link to comment Share on other sites More sharing options...
wreese007 Posted October 20, 2009 Share Posted October 20, 2009 I am having the same problem. I haved search the net for an answer for 2 hours. No one seems to know how to stop excel from opening when you open your drawing with the link. Did you ever find an answer? Quote Link to comment Share on other sites More sharing options...
dwilcox13 Posted October 21, 2009 Author Share Posted October 21, 2009 Wreese007 ~ No. Still haven't found a solution to this problem. Anybody have any more suggestions on this?? Quote Link to comment Share on other sites More sharing options...
wreese007 Posted October 21, 2009 Share Posted October 21, 2009 I am working on the problem right now - searching the net and asking the question in different ways. I tried using diferent settings for the DXEVAL system variable. That did not stop the spreadsheet from opening. It does seem to be an autocad 2008 problem. 2008 has a "bi-directional" function in it. So i am looking into stopping or turning off that "bi-directional feature. I will let you know what i find. Keep your email notification set to on for your account. I really need to fix this problem. If i can not, it will effect a very large project i am working on, in a bad way. Quote Link to comment Share on other sites More sharing options...
wreese007 Posted October 21, 2009 Share Posted October 21, 2009 I tried setting regenauto to '0' and regenmode to '0'. Had no effect on the spread sheet update Quote Link to comment Share on other sites More sharing options...
wreese007 Posted November 3, 2009 Share Posted November 3, 2009 This is a way to stop excel from opening automatically every time you open your AutoCAD drawing. In AutoCAD version 2008 there is a bi-directional feature that I believe is the culprit. The way to stop this has to do with the way you insert or paste you excel table into AutoCAD. Do-Not use “paste special”. Not necessary with the bi-directional feature. Just copy and paste your table into AutoCAD. When you paste this way, you see an “OLE Text Size” screen pop up. Just select OK to finish the insert. Now when you open AutoCAD, it will not open excel. And you still get the link feature you wanted to begin with. I also suggest when inserting similar size tables into multiple drawings you maximize your excel window before you cut and paste. I noticed a slight size difference occurring when I did not maximize my excel screen. Quirky? Yes But it seems to work for everything I am doing. Quote Link to comment Share on other sites More sharing options...
Andrew1234 Posted June 27 Share Posted June 27 On 11/3/2009 at 9:23 AM, wreese007 said: This is a way to stop excel from opening automatically every time you open your AutoCAD drawing. In AutoCAD version 2008 there is a bi-directional feature that I believe is the culprit. The way to stop this has to do with the way you insert or paste you excel table into AutoCAD. Do-Not use “paste special”. Not necessary with the bi-directional feature. Just copy and paste your table into AutoCAD. When you paste this way, you see an “OLE Text Size” screen pop up. Just select OK to finish the insert. Now when you open AutoCAD, it will not open excel. And you still get the link feature you wanted to begin with. I also suggest when inserting similar size tables into multiple drawings you maximize your excel window before you cut and paste. I noticed a slight size difference occurring when I did not maximize my excel screen. Quirky? Yes But it seems to work for everything I am doing. When I do this the autocad doesn't automatically update when I make changes to the excel. The point of paste special is that it updates my autocad drawings automatically. Quote Link to comment Share on other sites More sharing options...
