I found this lisp from another thread here and I'm using this as a subroutine for my other Bind lisp. This SaveIt.lsp will create a BOUND folder and then a dated folder (ie: A)and saves the drawing in there. The problem I have is when I already have the drawing in the dated folder(A) and I try saving the same drawing again, it will create another bound folder and dated folder (B) inside the dated folder (A). How can I fix this so it will just overwrite the existing drawing.:?
(defun c:SaveIt ( / )
(setq vDia (getvar "filedia")
      vEcho (getvar "cmdecho")
      vPrefix (getvar "dwgprefix")
      vName (getvar "dwgname")
      vDate (rtos (getvar "cdate") 2 6)
      vYear (substr vDate 1 4)
      vMonth (substr vDate 5 2)
      vDay (substr vDate 7 2)
      VLogin (getvar "loginname")
      vDateStr (strcat vYear "-" vMonth "-" vDay "_" vLogin )
(setvar "filedia" 0)
(setvar "cmdecho" 0)
(setq vDir (strcat vPrefix "Bound"))
(if (= (vl-file-directory-p vDir) nil)
  (vl-mkdir vDir)
  (vl-mkdir (strcat vDir "\\" vDateStr))
 (if (= (vl-file-directory-p (strcat vDir "\\" vDateStr)) nil)
(command ".saveas" "" (strcat vDir "\\" vDateStr "\\" vName))
(setvar "filedia" vDia)
(setvar "cmdecho" vEcho)
***Edit: The question beckons, Why use "save as" if you want it in the same place & same name?
Purhaps
(defun c:SaveIt ( / Bk_Echo vDir Str_FileName vDate vDateStr Str_NewDir Str_FileLoc Str_FileDir)
(vl-load-com)
(setq
 Bk_Echo (getvar "cmdecho")
 vDateStr (strcat (substr vDate 1 4) "-" (substr vDate 5 2) "-" (substr vDate 7 2) "_" (getvar "loginname"))
 Str_FileLoc (getvar "dwgprefix")
 Str_FileDir (substr Str_FileLoc 1 (vl-string-search "Bound" Str_FileLoc))
 vDir (strcat Str_FileDir "Bound")
 Str_NewDir (strcat vDir "\\" vDateStr)
 Str_FileName (strcat Str_NewDir "\\" (getvar "dwgname"))
(if (not (vl-file-directory-p vDir))(vl-mkdir vDir))
(if (not (vl-file-directory-p Str_NewDir))(vl-mkdir Str_NewDir))
(vl-cmdf ".saveas" "" Str_FileName)
(setvar "cmdecho" Bk_Echo)
  (princ "File Saved")
Sorry im in one of those stages
Just used this
(setqStr_FileDir (substr Str_FileLoc 1 (vl-string-search "Bound" Str_FileLoc))
to stop any bound\bound stuff
Thanks so much flowerrobot,
I got it to work now.:D
My only issue now is if the dwg is already there, it'll ask me if I want to overwrite existing file. What I did was add another command "Y" to the "saveas" command line.
(vl-cmdf ".saveas" "" Str_Filename "Y")
Which works fine. But it will show an "Unknown command "Y" " If the dwg is saved the first time around.:wink:
Give this a try:
(vl-cmdf ".saveas" "" Str_Filename)
(or (zerop (getvar "dbmod")))
 (vl-cmdf "_y")
 (vl-cmdf "_y")
 [color=Red])[/color]
Thanks Alan, but it doesn't seem to make any difference. I still get the "unknown command Y "
Where did the extra ")" come from?:?
 (vl-cmdf "_y")
Oops, got a little paren-happy. Try this:
   (vl-cmdf "_y")
Ahh i thought you wanted that
Anther way
(if (findfile Str_Filename)
(vl-cmdf "_qsave");!!!!
flowerrobot,
I don't think qsave will work because I'm saving from a different folder to a .../bound/date folder. I certainly don't want to save my "working" drawing because I'm using this as a subroutine after I bind my drawing(before saving). Eitherway, the one Alan wrote works fine. Thanks for your help.:)
flowerrobot,
Glad that helped. I had started writing it differently, but backed up. I guess I forgot to remove all my parens.
