alanjt Posted October 4, 2009 Posted October 4, 2009 I'll try it asap. Hope tomorrow I find the time. Thanks a lot meanwhile. Nope you can make something work. Quote
JeepMaster Posted October 5, 2009 Posted October 5, 2009 The biggest thing that puzzles me is why people don't use the number key row. ~ = qleader 1 = layer current 2 = layer set 3 = layer off 4 = layer freeze 5 = mleader 6 = civilpointmodlist (old LDD command, need to update since I use C3D now) 7 = list 8 = layerp 9 = extrim 0 = math (commandline calculator) - = layer nuke = = never defined, but could be used Hey, thanks for that idea. I will try it out. Quote
alanjt Posted October 5, 2009 Posted October 5, 2009 Hey, thanks for that idea. I will try it out. Made my life a lot easier. Quote
Randolph Posted October 5, 2009 Author Posted October 5, 2009 How about: ^1 top view ^2 side view, ucs world (to stop the annoying rotation of the ucs) ^3 front view, ucs world ... ^6 iso ... and so on Quote
alanjt Posted October 5, 2009 Posted October 5, 2009 How about: ^1 top view ^2 side view, ucs world (to stop the annoying rotation of the ucs) ^3 front view, ucs world ... ^6 iso ... and so on Whatever tickles your fancy. It's really what makes life easier for the specific user. What I like, isn't the best for someone else. Quote
Randolph Posted October 8, 2009 Author Posted October 8, 2009 So, I tried it out now: To load a contradicting lisp works. acad-ralph.lsp (DEFUN C:S ()(COMMAND "_SLICE")) acad-martin.lsp (DEFUN C:S ()(COMMAND "_MOVE")) Whatever lsp I appload, the command changes. BUT if I change the profiles (options > profiles > acad-ralph / acad-martin), the corresponding lsp does NOT load. I did the following: Set profile acad-ralph, appload and put acad-ralph to the START GROUP. Change profile to acad-martin, remove acad-ralph.lsp from the start group and add acad-martin.lsp. But when I changed back to profile acad-ralph, this did not change back. Now I will try the above routine. Quote
Randolph Posted October 8, 2009 Author Posted October 8, 2009 This I wrote into my lisp: (DEFUN C:CSW (/ ProfileLoad #Choice) (vl-load-com) (defun ProfileLoad (#ProfileName / #Profiles) (setq #Profiles (vla-get-profiles (vla-get-preferences (vlax-get-acad-object))) ) ;_ setq (or (eq #ProfileName (vla-get-activeprofile #Profiles)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-activeprofile (list #Profiles #ProfileName) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ not ) ;_ or ) ;_ defun (initget 0 "Ralph Martin Dismiss") (and (setq #Choice (getkword "\nUser customization options to load [Ralph/Martin] <Dismiss>: " ) ;_ getkword ) ;_ setq (cond ((eq #Choice "Ralph") ;; do stuff (ProfileLoad "AutoCAD - Ralph") (and (findfile "acad-ralph.lsp") (load "acad-ralph.lsp")) ) ((eq #Choice "Martin") ;; do stuff (ProfileLoad "AutoCAD - Martin") (and (findfile "acad-martin.lsp") (load "acad-[color=red]martin[/color].lsp")) ) ) ;_ cond ) ;_ and (prin ) ;_ defun ) But it does NOT load the lisp. Mybe it doesn't find the file? If I appload acad-martin.lsp and then acad-ralph.lsp manualy afterwards, everthing works. Should I enter a path instead of "findfile"? Quote
Randolph Posted October 8, 2009 Author Posted October 8, 2009 Furthermore Befehl: csw User customization options to load [Ralph/Martin] <Dismiss>: m Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: ACAD Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: CUSTOM Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: MARTIN Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: ACROBAT_COMMENT Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: ADOBE_PDF Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: EXPRESS [color=red]; Fehler: no function definition: PRIN[/color] Befehl: Befehl means command. Fehler means error. It doesn't state that it loaded acad-martin.lsp. Quote
alanjt Posted October 8, 2009 Posted October 8, 2009 Furthermore Befehl: csw User customization options to load [Ralph/Martin] <Dismiss>: m Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: ACAD Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: CUSTOM Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: MARTIN Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: ACROBAT_COMMENT Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: ADOBE_PDF Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: EXPRESS [color=red]; Fehler: no function definition: PRIN[/color] Befehl: Befehl means command. Fehler means error. It doesn't state that it loaded acad-martin.lsp. Look at the last lines of the code: ) ;_ and ([color=Red]prin[/color] ) ;_ defun ) As far as it not loading, the files must be in a support path or the path must be specified. Just add the directory to your support paths. Quote
Randolph Posted October 8, 2009 Author Posted October 8, 2009 negative: the problem was that somehow your code ) ;_ cond ) ;_ and (princ) ) ;_ defun was mutilated to ) ;_ cond ) ;_ and [color=red](prin [/color]) ;_ defun BUT it still does not APPLOAD. This is what I get now: Befehl: csw User customization options to load [Ralph/Martin] <Dismiss>: m Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: ACAD Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: CUSTOM Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: MARTIN Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: ACROBAT_COMMENT Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: ADOBE_PDF Anpassungsdatei erfolgreich geladen. Anpassungsgruppe: EXPRESS Befehl: If I do the CSW command and APPLOAD the matching LISP, everything is fine. Why does CSW not appload? I'm not able to find the error. Quote
Randolph Posted October 8, 2009 Author Posted October 8, 2009 I got it: (DEFUN C:CSW (/ ProfileLoad #Choice) (vl-load-com) (defun ProfileLoad (#ProfileName / #Profiles) (setq #Profiles (vla-get-profiles (vla-get-preferences (vlax-get-acad-object))) ) ;_ setq (or (eq #ProfileName (vla-get-activeprofile #Profiles)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-activeprofile (list #Profiles #ProfileName) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ not ) ;_ or ) ;_ defun (initget 0 "Ralph Martin Dismiss") (and (setq #Choice (getkword "\nUser customization options to load [Ralph/Martin] <Dismiss>: " ) ;_ getkword ) ;_ setq (cond ((eq #Choice "Ralph") ;; do stuff (ProfileLoad "AutoCAD - Ralph") [b][color=seagreen](and (load "C:/Programme/ADT2007/LISP/acad-ralph.lsp"))[/color][/b] ) ((eq #Choice "Martin") ;; do stuff (ProfileLoad "AutoCAD - Martin") [b][color=seagreen](and (load "C:/Programme/ADT2007/LISP/acad-martin.lsp"))[/color][/b] ) ) ;_ cond ) ;_ and (princ) ) ;_ defun Thanks Alan! Quote
alanjt Posted October 8, 2009 Posted October 8, 2009 (DEFUN C:CSW (/ ProfileLoad #Choice) (vl-load-com) (defun ProfileLoad (#ProfileName / #Profiles) (setq #Profiles (vla-get-profiles (vla-get-preferences (vlax-get-acad-object))) ) ;_ setq (or (eq #ProfileName (vla-get-activeprofile #Profiles)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-activeprofile (list #Profiles #ProfileName) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ not ) ;_ or ) ;_ defun (initget 0 "Ralph Martin Dismiss") (and (setq #Choice (getkword "\nUser customization options to load [Ralph/Martin] <Dismiss>: " ) ;_ getkword ) ;_ setq (cond ((eq #Choice "Ralph") ;; do stuff (ProfileLoad "AutoCAD - Ralph") (and (findfile "acad-ralph.lsp") (load "acad-ralph.lsp")) ) ((eq #Choice "Martin") ;; do stuff (ProfileLoad "AutoCAD - Martin") (and (findfile "acad-martin.lsp") (load "acad-martin.lsp")) ) ) ;_ cond ) ;_ and (princ) ) ;_ defun You don't need to be using AppLoad (unless you want to use it for the above code CSW). the acad-martin.lsp, either needs to be in a support path, or specify the path in the above lisp. Without having acad-martin.lsp loaded, type (findfile "acad-martin.lsp"). Do you get nil or a directory string? Quote
alanjt Posted October 8, 2009 Posted October 8, 2009 I got it: (DEFUN C:CSW (/ ProfileLoad #Choice) (vl-load-com) (defun ProfileLoad (#ProfileName / #Profiles) (setq #Profiles (vla-get-profiles (vla-get-preferences (vlax-get-acad-object))) ) ;_ setq (or (eq #ProfileName (vla-get-activeprofile #Profiles)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-activeprofile (list #Profiles #ProfileName) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ not ) ;_ or ) ;_ defun (initget 0 "Ralph Martin Dismiss") (and (setq #Choice (getkword "\nUser customization options to load [Ralph/Martin] <Dismiss>: " ) ;_ getkword ) ;_ setq (cond ((eq #Choice "Ralph") ;; do stuff (ProfileLoad "AutoCAD - Ralph") [b][color=seagreen](and (load "C:/Programme/ADT2007/LISP/acad-ralph.lsp"))[/color][/b] ) ((eq #Choice "Martin") ;; do stuff (ProfileLoad "AutoCAD - Martin") [b][color=seagreen](and (load "C:/Programme/ADT2007/LISP/acad-martin.lsp"))[/color][/b] ) ) ;_ cond ) ;_ and (princ) ) ;_ defun Thanks Alan! If you are going just load it, you don't need the and statement. Quote
Randolph Posted October 9, 2009 Author Posted October 9, 2009 does the "and" hurt anybody, or is it for the beauty of programming? (which is still a good reason). one thing i'm thinking is to make 2 commands: um (umschalten=switch martin) and ur. would be even faster. Quote
alanjt Posted October 9, 2009 Posted October 9, 2009 does the "and" hurt anybody, or is it for the beauty of programming? (which is still a good reason). one thing i'm thinking is to make 2 commands: um (umschalten=switch martin) and ur. would be even faster. It doesn't hurt anything, but it's superfluous since you removed the findfile check. (and (findfile "blah") (load "blah") ) I would fill the additional parameter to the load function. Right now, if it can't find the file, it errors. Instead use (load "blah.lsp" "blah.lsp did not load") or just (load "blah.lsp" nil) would be better. That way it will load if finds and nil if not. I could have also used if, but I didn't have an if this, then this, if not, then this situation, so I used and. Truthfully, (load "blah.lsp" nil) would have been the best and quickest solution. No reason to check if it exists if the loading function can handle not finding the file. Quote
Randolph Posted November 11, 2009 Author Posted November 11, 2009 I just tried to make this to be 2 commands. 1 command UMM (Switch to profile Martin) and 1 command UMR (switch to profile Ralph). I also tried to remove the "and" statement. I ended up with AutoCAD stating "wrong type of argument" This is what I tried: DEFUN C:UMR (/ ProfileLoad #Choice) (vl-load-com) (defun ProfileLoad (#ProfileName / #Profiles) (setq #Profiles (vla-get-profiles (vla-get-preferences (vlax-get-acad-object))) ) ;_ setq (or (eq #ProfileName (vla-get-activeprofile #Profiles)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-activeprofile (list #Profiles #ProfileName) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ not ) ;_ or ) ;_ defun (ProfileLoad "AutoCAD - Ralph") (load "C:/Programme/ADT2007/LISP/acad-ralph.lsp") ) ;_ cond ) ;_ and (princ) ) ;_ defun To be quite honest, I don't understand the (/ ProfileLoad #Choice) part. Quote
alanjt Posted November 11, 2009 Posted November 11, 2009 I just tried to make this to be 2 commands. 1 command UMM (Switch to profile Martin) and 1 command UMR (switch to profile Ralph). I also tried to remove the "and" statement. I ended up with AutoCAD stating "wrong type of argument" This is what I tried: DEFUN C:UMR (/ ProfileLoad #Choice) (vl-load-com) (defun ProfileLoad (#ProfileName / #Profiles) (setq #Profiles (vla-get-profiles (vla-get-preferences (vlax-get-acad-object))) ) ;_ setq (or (eq #ProfileName (vla-get-activeprofile #Profiles)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-activeprofile (list #Profiles #ProfileName) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ not ) ;_ or ) ;_ defun (ProfileLoad "AutoCAD - Ralph") (load "C:/Programme/ADT2007/LISP/acad-ralph.lsp") ) ;_ cond ) ;_ and (princ) ) ;_ defun To be quite honest, I don't understand the (/ ProfileLoad #Choice) part. LoL What a mess. Nah, you just missed the ( at the beginning and had too many parens at the end. Give this a try: (defun C:UMR (/ ProfileLoad) (vl-load-com) (defun ProfileLoad (#ProfileName / #Profiles) (setq #Profiles (vla-get-profiles (vla-get-preferences (vlax-get-acad-object))) ) ;_ setq (or (eq #ProfileName (vla-get-activeprofile #Profiles)) (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-activeprofile (list #Profiles #ProfileName) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ not ) ;_ or ) ;_ defun (ProfileLoad "AutoCAD - Ralph") (load "C:/Programme/ADT2007/LISP/acad-ralph.lsp" nil) (princ) ) ;_ defun (/ ProfileLoad #Choice) is there to localize the subroutine and the variable. I removed #Choice since you don't need it. Quote
