ML0940 Posted July 7, 2008 Posted July 7, 2008 For x = 0 To Drawing.Layouts.Count - 1 Hi Karl, that looks good! That should do it The alternative would be to declare a variable for an acad layout, then loop straight through the layouts in paper space. Now, you don't have to worry about filtering out Model Space when you plot. Dim layout as AcadLayout For Each layout in ThisDrawing.PaperSpace Layout.RefreshPlotDeviceInfo Layout.ConfigName = Plotter ' CALL PLOTTER Layout.PlotType = acExtents Layout.PlotRotation = ROT ' CALL ROTATION Layout.StyleSheet = CTB ' CALL CTB FILE Layout.PlotWithPlotStyles = True Layout.PlotViewportBorders = False Layout.PlotViewportsFirst = True Layout.CanonicalMediaName = SIZE ' CALL SIZE Layout.PaperUnits = acInches Layout.StandardScale = PSCALE ' CALL PSCALE Layout.ShowPlotStyles = False Layout.ScaleLineweights = True Layout.CenterPlot = True Drawing.Plot.NumberOfCopies = 1 Drawing.Regen acAllViewports Drawing.Plot.PlotToDevice Next layout Set Layout = Nothing Just a thought ML Quote
ML0940 Posted July 9, 2008 Posted July 9, 2008 With the code you used, you could also say: For x = 0 To Drawing.Layouts.Count - 1 Msgbox (x & "layouts have been successfully created") Quote
veranco Posted January 12, 2010 Posted January 12, 2010 this should get you started. Are you wanting to hard code your paper size or pass it as an argument? Public Sub SetupAndPlot(ByRef Plotter As String, CTB As String, SIZE As String, PSCALE As String, ROT As String) Dim Layout As AcadLayout On Error GoTo Err_Control Set Layout = ThisDrawing.ActiveLayout Layout.RefreshPlotDeviceInfo Layout.ConfigName = Plotter ' CALL PLOTTER Layout.PlotType = acExtents Layout.PlotRotation = ROT ' CALL ROTATION Layout.StyleSheet = CTB ' CALL CTB FILE Layout.PlotWithPlotStyles = True Layout.PlotViewportBorders = False Layout.PlotViewportsFirst = True Layout.CanonicalMediaName = SIZE ' CALL SIZE Layout.PaperUnits = acInches Layout.StandardScale = PSCALE 'CALL PSCALE Layout.ShowPlotStyles = False ThisDrawing.Plot.NumberOfCopies = 1 Layout.CenterPlot = True If SIZE = "ARCH_expand_C_(24.00_x_18.00_Inches)" Then Layout.ScaleLineweights = True End If ThisDrawing.Regen acAllViewports ZoomExtents Set Layout = Nothing ThisDrawing.Save Exit_Here: Exit Sub Err_Control: Select Case Err.Number Case "-2145320861" MsgBox "Unable to Save Drawing- " & Err.Description Case "-2145386493" MsgBox "Drawing is setup for Named Plot Styles." & (Chr(13)) & (Chr(13)) & "Run CONVERTPSTYLES command", vbCritical, "Change Plot Style" Case Else MsgBox "Unknown Error " & Err.Number End Select End Sub Dear members Currently I'm trying to use this code to implement PDFCreator to print automaticly the used viewports as pdf-files. I encountered some difficulties but I keep on having two problems: I can't find a way to print it without the error of the named plotstyles, I always use a ctb file for my plotstyles, and that always results in an error. Second problem is not so specific: I would want to replace the print function with te one I just made, so that every viewport, when printed, creates a pdf file as well. The double function required to do that already exists, the problem is how can I override the print/plot function (the OK-button in the plot-window). Thanks in advance! Quote
