alanjt Posted February 23, 2010 Author Share Posted February 23, 2010 Bitte lassen Sie wie es ist ich finde es super.Danke Please leave as it is, I think it's great. Thanks It will only change if a Mod. changes it or I get pissed one day and delete everything. Thanks. Hope you found something useful. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 23, 2010 Share Posted February 23, 2010 I find this really useful, am I'm not even a draftsman... (defun c:cr (/ OldCopy ss) (and (setq OldCopy (getvar 'COPYMODE)) (setvar "COPYMODE" 1)) (if (setq ss (ssget "_:L")) (command "_.copy" ss "" '(0 0 0) '(0 0 0) "_.rotate" ss "" pause pause)) (and OldCopy (setvar 'COPYMODE OldCopy)) (princ)) Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 23, 2010 Author Share Posted February 23, 2010 I find this really useful, am I'm not even a draftsman... (defun c:cr (/ OldCopy ss) (and (setq OldCopy (getvar 'COPYMODE)) (setvar "COPYMODE" 1)) (if (setq ss (ssget "_:L")) (command "_.copy" ss "" '(0 0 0) '(0 0 0) "_.rotate" ss "" pause pause)) (and OldCopy (setvar 'COPYMODE OldCopy)) (princ)) http://www.cadtutor.net/forum/showpost.php?p=271421&postcount=8 Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 26, 2010 Author Share Posted February 26, 2010 ;;; Tab Incriment ;;; Rename layout tabs with number, based on location ;;; Prefix and Suffix optional ;;; Alan J. Thompson, 02.25.09 (complete rewrite from my original) (defun c:TabInc (/ #Prefix #Suffix) (and (setq #Prefix (getstring T "\nPrefix: ")) (setq #Suffix (getstring T "\nSuffix: ")) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vlax-for x (vla-get-layouts *AcadDoc*) (vl-catch-all-apply 'vla-put-name (list x (strcat #Prefix (itoa (vla-get-taborder x)) #Suffix)) ) ;_ vl-catch-all-apply ) ;_ vlax-for ) ;_ and (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted March 3, 2010 Share Posted March 3, 2010 Have you seen these subfunctions?... It's nothing really amazing.. just more stuff to add to this great thread... http://www18.ocn.ne.jp/~haru_h/sub10.htm Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 15, 2010 Author Share Posted March 15, 2010 ;;; Rename Selected Block ;;; Required Subroutines: AT:Entsel, AT:Getstring ;;; Alan J. Thompson, 03.10.10 (defun c:RenB (/ *error* #Obj #Layer #New) (setq *error* (lambda (x) (and *AcadDoc* (vla-endundomark *AcadDoc*)))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vla-startundomark *AcadDoc*) (and (setq #Obj (AT:Entsel nil "\nSelect block to rename: " '("V" (0 . "INSERT")) nil)) (setq #Block (vla-get-effectivename #Obj)) (not (vl-position (setq #New (AT:Getstring "Specify new block name:" #Block)) (list #Block "" nil) ) ;_ vl-position ) ;_ not (cond ((tblsearch "block" #New) (alert (strcat "\"" #New "\" already exists!"))) ((not (snvalid #New)) (alert (strcat "\"" #New "\" is an invalid name!"))) ((and (snvalid #New) (not (tblsearch "block" #New))) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-name (list (vla-item (vla-get-blocks *AcadDoc*) #Block) #New) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p (alert (strcat "Block: " #Block " could not be renamed to: " #New)) (alert (strcat "Block: " #Block " renamed to: " #New)) ) ;_ if ) ) ;_ cond ) ;_ and (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 15, 2010 Author Share Posted March 15, 2010 ;;; Measure objects along line/arc ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 03.10.10 (defun c:MAC (/ *error* #SS #Pnt #Obj #Seg #Dist #Len) (setq *error* (lambda (x) (and #SS (vl-catch-all-apply 'vla-delete (list #SS))) (and *AcadDoc* (vla-endundomark *AcadDoc*)) ) ;_ lambda ) ;_ setq (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vla-startundomark *AcadDoc*) (and (princ "\nSelect object(s) to measure along curve: ") (setq #SS (ssget "_:L")) (setq #Pnt (getpoint "\nBase point for objects: ")) (setq #Obj (AT:Entsel T "\nSelect curve to divide: " '("V" (0 . "LINE,*POLYLINE,ARC")) nil)) (not (initget 6)) (setq #Seg (getdist #Pnt "\nSpecify length of segment: ")) (setq #Pnt (vlax-3d-point (trans #Pnt 1 0))) (or (not (vl-catch-all-error-p (setq #Len (vl-catch-all-apply 'vla-get-length (list #Obj))))) (not (vl-catch-all-error-p (setq #Len (vl-catch-all-apply 'vla-get-arclength (list #Obj))))) ) ;_ or (setq #Dist 0.) (while (<= #Dist (- #Len #Seg)) (setq #Dist (+ #Dist #Seg)) (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (vla-move (vla-copy x) #Pnt (vlax-3d-point (vlax-curve-getpointatdist #Obj #Dist))) ) ;_ vlax-for ) ;_ while ) ;_ and (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 15, 2010 Author Share Posted March 15, 2010 ;;; Divide objects along line/arc ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 11.10.09 (defun c:DAC (/ *error* #SS #Pnt #Obj #Num #Dist #Len) (setq *error* (lambda (x) (and *AcadDoc* (vla-endundomark *AcadDoc*)) (and #SS (vl-catch-all-apply 'vla-delete (list #SS))) ) ;_ lambda ) ;_ setq (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vla-startundomark *AcadDoc*) (and (princ "\nSelect object(s) to divide along curve: ") (setq #SS (ssget "_:L")) (setq #Pnt (getpoint "\nBase point for objects: ")) (setq #Pnt (vlax-3d-point (trans #Pnt 1 0))) (setq #Obj (AT:Entsel T "\nSelect curve to divide: " '("V" (0 . "LINE,*POLYLINE,ARC")) nil)) (not (initget 6)) (setq #Num (getint "\nNumber of objects: ")) (setq #Dist 0.) (or (not (vl-catch-all-error-p (setq #Len (vl-catch-all-apply 'vla-get-length (list #Obj))))) (not (vl-catch-all-error-p (setq #Len (vl-catch-all-apply 'vla-get-arclength (list #Obj))))) ) ;_ or (while (<= #Dist (- #Len (/ #Len #Num))) (setq #Dist (+ #Dist (/ #Len #Num))) (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (vla-move (vla-copy x) #Pnt (vlax-3d-point (vlax-curve-getpointatdist #Obj #Dist))) ) ;_ vlax-for ) ;_ while ) ;_ and (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 15, 2010 Author Share Posted March 15, 2010 ;;; Remove LWPolyline Segment ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson (defun c:Rem (/ e) (while (setq e (AT:Entsel nil "\nSelect LWPolyline: " '("L" (0 . "*POLYLINE")) nil)) (vl-cmdf "_.trim" e "" e "") ) ;_ while (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 15, 2010 Author Share Posted March 15, 2010 ;;; Total Area of Selected Polylines ;;; Alan J. Thompson, 03.15.10 (defun c:TA (/ *error* #Dimzin #SS #Area #Len) (setq *error* (lambda (x) (and #Dimzin (setvar 'dimzin #Dimzin)))) (cond ((setq #SS (ssget '((0 . "LWPOLYLINE,POLYLINE")))) (setq #Dimzin (getvar 'dimzin)) (setvar 'dimzin 0) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (setq #Area 0. #Len 0. ) ;_ setq (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (setq #Area (+ #Area (vla-get-area x)) #Len (+ #Len (vla-get-length x)) ) ;_ setq ) ;_ vlax-for (vla-delete #SS) (textscr) (princ (strcat "\nTotal area:" "\n-----------------\n" (rtos #Area 2 2) " SF\n" (rtos (/ #Area 9.) 2 2) " SY\n" (rtos (/ #Area 43560.) 2 2) " AC.±\n" (rtos #Len 2 2) " LF" ) ;_ strcat ) ;_ princ ) ) ;_ cond (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 15, 2010 Author Share Posted March 15, 2010 ;;; Total Area of Selected Hatch Object(s) ;;; Alan J. Thompson, 03.15.10 (defun c:HA (/ *error* #Dimzin #SS #Area) (setq *error* (lambda (x) (and #Dimzin (setvar 'dimzin #Dimzin)))) (cond ((setq #SS (ssget '((0 . "HATCH")))) (setq #Dimzin (getvar 'dimzin)) (setvar 'dimzin 0) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (setq #Area 0.) (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (setq #Area (+ #Area (vla-get-area x))) ) ;_ vlax-for (vla-delete #SS) (textscr) (princ (strcat "\nTotal area:" "\n-----------------\n" (rtos #Area 2 2) " SF\n" (rtos (/ #Area 9.) 2 2) " SY\n" (rtos (/ #Area 43560.) 2 2) " AC.±" ) ;_ strcat ) ;_ princ ) ) ;_ cond (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted March 17, 2010 Share Posted March 17, 2010 ;;; Total Area of Selected Hatch Object(s) ;;; Alan J. Thompson, 03.15.10 (defun c:HA (/ *error* #Dimzin #SS #Area) (setq *error* (lambda (x) (and #Dimzin (setvar 'dimzin #Dimzin)))) (cond ((setq #SS (ssget '((0 . "HATCH")))) (setq #Dimzin (getvar 'dimzin)) (setvar 'dimzin 0) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (setq #Area 0.) (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (setq #Area (+ #Area (vla-get-area x))) ) ;_ vlax-for (vla-delete #SS) (textscr) (princ (strcat "\nTotal area:" "\n-----------------\n" (rtos #Area 2 2) " SF\n" (rtos (/ #Area 9.) 2 2) " SY\n" (rtos (/ #Area 43560.) 2 2) " AC.±" ) ;_ strcat ) ;_ princ ) ) ;_ cond (*error* nil) (princ) ) ;_ defun Alan, I just ran this routine on several hatched objects. I do not get an error, But I also do not get any area either. What could I be doing wrong? This is what I get at the command prompt. Command: HA Select objects: 1 found Select objects: 1 found, 2 total Select objects: 1 found, 3 total Select objects: Command: Buzzard Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 17, 2010 Share Posted March 17, 2010 The code's error handler does not print error messages, so you wouldn't know if you were receiving an error. Just for diagnostics, try this and see what you get: Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted March 17, 2010 Share Posted March 17, 2010 I get this message now. Select objects: Specify opposite corner: 6 found 3 were filtered out. Select objects: ActiveX Server returned the error: unknown name: Area Command: Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 17, 2010 Share Posted March 17, 2010 The easiest solution would probably be to use a vl-catch-all-apply in there - but this may cause the function to be rendered inaccurate as users would be expecting to receiving areas of more objects than is reported. I'll let Alan deal with the code before I modify it anymore Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 17, 2010 Author Share Posted March 17, 2010 Alan, I just ran this routine on several hatched objects. I do not get an error, But I also do not get any area either. What could I be doing wrong? This is what I get at the command prompt. Command: HA Select objects: 1 found Select objects: 1 found, 2 total Select objects: 1 found, 3 total Select objects: Command: Buzzard I get this message now. Select objects: Specify opposite corner: 6 found 3 were filtered out. Select objects: ActiveX Server returned the error: unknown name: Area Command: That's really strange. Hatch objects have an Area value. Could you post an example of the hatch? Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 17, 2010 Author Share Posted March 17, 2010 The code's error handler does not print error messages, so you wouldn't know if you were receiving an error. Lee, I know you are just trying to help, but would you mind removing your posted code? I just don't want 2 of the same thing in here. Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted March 17, 2010 Share Posted March 17, 2010 That's really strange. Hatch objects have an Area value. Could you post an example of the hatch? Lee, I know you are just trying to help, but would you mind removing your posted code? I just don't want 2 of the same thing in here. This is just three hatches with rectangles. Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 17, 2010 Author Share Posted March 17, 2010 This is just three hatches with rectangles. Works fine for me. Paste the following code into ACad, select one of the hatch objects, copy and paste the return here. (vlax-dump-object (vlax-ename->vla-object (car (entsel))) T) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 17, 2010 Share Posted March 17, 2010 Works fine for me. Me too. Quote Link to comment Share on other sites More sharing options...
