alanjt Posted September 24, 2009 Author Share Posted September 24, 2009 Might benefit the lasy who dont have the time to copy them, With a zip file If they are too lazy to read through them, post by post, they are going to be too lazy to look through them if zipped. Quote Link to comment Share on other sites More sharing options...
flowerrobot Posted September 24, 2009 Share Posted September 24, 2009 I looked threw all of them , But was to lasy to copy them, I spose there not going any where? Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 24, 2009 Author Share Posted September 24, 2009 I looked threw all of them , But was to lasy to copy them, I spose there not going any where? That's what you think. Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted September 24, 2009 Share Posted September 24, 2009 Ehh, then how would I fluff my post count.:wink:It's just a bunch of random stuff, I figured people could read through them (if they wanted) and take what they like. Judging by the response, they're of no use anyway. Oh well, not why I posted them. } This is actually what I did... some of them will help me to come up with new stuff in my standards... Very nice post. Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 24, 2009 Author Share Posted September 24, 2009 } This is actually what I did... some of them will help me to come up with new stuff in my standards... Very nice post. Hope something helps. Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 22, 2009 Author Share Posted October 22, 2009 Needed something like this today so I rolled my own, real quick. It's silly, but saved me a lot of time not having to open lots of text objects. ;;; Text Stack/Compress Contents ;;; Alan J. Thompson, 10.21.09 (defun c:TSC (/ #Choice #SS #String #Find #Replace) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (initget 0 "Compress Stack") (cond ((and (or (setq #Choice (getkword "\nText content change options [Compress/Stack] <Compress>: ")) (setq #Choice "Compress") ) ;_ or (setq #SS (ssget "_:L" '((0 . "MTEXT,TEXT,MULTILEADER")))) ) ;_ and (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (setq #String (vla-get-TextString x)) (if (eq #Choice "Compress") (setq #Find "\\P" #Replace " " ) ;_ setq (setq #Find " " #Replace "\\P" ) ;_ setq ) ;_ if (while (vl-string-search #Find #String) (setq #String (vl-string-subst #Replace #Find #String)) ) ;_ while (vla-put-TextString x #String) ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 27, 2009 Author Share Posted October 27, 2009 Drawing in a city aerial map today and all centerline intersections were given in coordinates. I didn't feel like typing in Easting,Northing, mostly because I kept flipping them. It's nothing special, but it kept my head on straight and I thought I'd share. ;;; Paste Point Info. To Commandline (intended for transparent execution) ;;; Alan J. Thompson, 10.27.09 (defun c:PP (/ #North #East #Elev #Val) (and (setq #North (getreal "\nNorthing: ")) (setq #East (getreal "\nEasting: ")) (or (setq #Elev (getreal "\nElevation <0.0>: ")) (setq #Elev 0.0)) (setq #Val (mapcar '(lambda (x) (rtos x (getvar 'lunits) 4)) (list #North #East #Elev))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vla-sendcommand *AcadDoc* (strcat "_non " (cadr #Val) "," (car #Val) "," (last #Val) " ")) ) ;_ and (princ) ) ;_ defun Example of it being called within line command: Command: L LINE Specify first point: 'PP Northing: 1991653 Easting: 12710.9 Elevation <0.0>: Specify first point: Specify first point: _non 12710.9,1991653,0 Specify next point or [undo]: Specify next point or [undo]: Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Quick Area, based on picked point inside closed area ;;; Alan J. Thompson, 10.29.09 (defun c:QA (/ #Entlast #Pnt #Ent #Area) (and (or *Acad* (setq *Acad* (vlax-get-acad-object))) (or (setq #Entlast (entlast)) (setq #Entlast T)) (setq #Pnt (getpoint "\nSpecify internal point: ")) (not (vla-zoomextents *Acad*)) (vl-cmdf "_.-boundary" "_a" "_i" "_n" "" "" #Pnt "") (not (vla-zoomprevious *Acad*)) (not (eq #Entlast (setq #Ent (entlast)))) (setq #Area (vla-get-area (vlax-ename->vla-object #Ent))) (entdel #Ent) (princ (strcat "\nSq. Ft.: " (rtos #Area 2 3) "\nAcres: " (rtos (/ #Area 43560.) 2 3) ) ;_ strcat ) ;_ princ ) ;_ and (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Filtered Selection (Block Name, Entity Type, Layer) ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 11.03.09 (defun c:FT (/ #Choice #Num #Ent #Filter #SS) (initget 0 "Block Entity Layer") (and (or (setq #Choice (getkword "\nFilter by (B)lock Name, (E)ntity Type or (L)ayer? [block/Entity/<Layer>]: " ) ;_ getkword ) ;_ setq (setq #Choice "Layer") ) ;_ or (cond ((eq #Choice "Block") (setq #Num 2) (if (setq #Ent (AT:Entsel nil "\nSelect block for name: " '((0 . "INSERT")) nil)) (princ (strcat "\nBlock: \"" (setq #Filter (cdr (assoc 2 (entget (car #Ent))))) "\" selected.") ) ;_ princ ) ;_ if ) ((eq #Choice "Entity") (setq #Num 0) (if (setq #Ent (AT:Entsel nil "\nSelect object for entity type: " nil nil)) (princ (strcat "\n\"" (setq #Filter (cdr (assoc 0 (entget (car #Ent))))) "\" selected.")) ) ;_ if ) ((eq #Choice "Layer") (setq #Num (if (setq #Ent (AT:Entsel nil "\nSelect object for layer: " nil nil)) (princ (strcat "\nObject on layer: \"" (setq #Filter (cdr (assoc 8 (entget (car #Ent))))) "\" selected." ) ;_ strcat ) ;_ princ ) ;_ if ) ) ;_ cond (setq #SS (ssget (list (cons #Num #Filter)))) (sssetfirst nil #SS) (princ (strcat "\n" (itoa (sslength #SS)) " object(s) selected.")) ) ;_ and (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Change width of selected MText and MultiLeader objects ;;; Alan J. Thompson, 11.05.09 (defun c:WD (/ #SS #Width) (cond ((and (setq #SS (ssget "_:L" '((0 . "MTEXT,MULTILEADER")))) (not (initget 4)) (or (setq #Width (getdist "\nWidth <0.0>: ")) (setq #Width 0.)) ) ;_ and (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (cond ((eq (vla-get-objectname x) "AcDbMText") (vl-catch-all-apply 'vla-put-width (list x #Width)) ) ((eq (vla-get-objectname x) "AcDbMLeader") (vl-catch-all-apply 'vla-put-textwidth (list x #Width)) ) ) ;_ cond ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Restack bearing (toggle between " " & "\\P") ;;; Alan J. Thompson, 11.10.09 (defun c:RS (/ #SS #Str) (cond ((setq #SS (ssget "_:L" '((0 . "MTEXT,MULTILEADER")))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vlax-for x (setq #SS (vla-get-activeselectionset *AcadDoc*)) (setq #Str (vla-get-textstring x)) (cond ((vl-string-search " " #Str) (setq #Str (vl-string-subst "\\P" " " #Str))) ((vl-string-search "\\P" #Str) (setq #Str (vl-string-subst " " "\\P" #Str))) ) ;_ cond (vla-put-textstring x #Str) ) ;_ vlax-for (vl-catch-all-apply 'vla-delete (list #SS)) ) ) ;_ cond (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Draw Parallel Line, based on selected *line segment ;;; Required Subroutines: AT:Entsel, AT:Segment ;;; Alan J. Thompson, 11.10.09 (defun c:Par (/ #Ent #Pnt #Ang) (and (setq #Ent (AT:Entsel T "\nSelect object for angle: " '((0 . "*POLYLINE,LINE,AECC_PARCEL_SEGMENT")) nil)) (setq #Pnt (getpoint "\nSpecify starting point: ")) (setq #Ang (* 180. (/ (apply 'angle (mapcar '(lambda (x) (trans x 0 1)) (cadr (AT:Segment #Ent)))) pi) ) ;_ * ) ;_ setq (vl-cmdf "_.line" "_non" #Pnt (strcat "<" (rtos #Ang 2 16)) PAUSE) ) ;_ and (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 Cadtutor went down while I was posting all of this today. I hope I wasn't the culprit. ;;; Draw Perpendicular Line, based on selected *line segment ;;; Required Subroutines: AT:Entsel, AT:Segment, AT:ClosestEndPoint (AT:DrawX optional) ;;; Alan J. Thompson, 11.10.09 (defun c:Per (/ #Ent #Pnt #Ang) (and (setq #Ent (AT:Entsel T "\nSelect object for angle: " '((0 . "*POLYLINE,LINE,AECC_PARCEL_SEGMENT")) nil)) (not (initget 0 "End Selection")) (or (setq #Pnt (getpoint "\nSpecify starting point [End/<Selection>]: ")) (setq #Pnt "Selection") ) ;_ or (cond ((vl-consp #Pnt) T) ((eq #Pnt "Selection") (setq #Pnt (trans (vlax-curve-GetClosestPointTo (car #Ent) (trans (cadr #Ent) 1 0)) 0 1)) ) ((eq #Pnt "End") (setq #Pnt (trans (AT:ClosestEndPoint #Ent) 0 1))) ) ;_ cond (setq #Ang (+ 90. (* 180. (/ (apply 'angle (mapcar '(lambda (x) (trans x 0 1)) (cadr (AT:Segment #Ent)))) pi) ) ;_ * ) ;_ + ) ;_ setq (if AT:DrawX (AT:DrawX #Pnt 1) T) (vl-cmdf "_.line" "_non" #Pnt (strcat "<" (rtos #Ang 2 16)) PAUSE) ) ;_ and (redraw) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Divide objects along line/arc ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 11.10.09 (defun c:DAC (/ *error* #Flag #SS #Pnt #Obj #Num #Dist #Len) (setq *error* (lambda (x) (and #Flag (vl-cmdf "_.ucs" "_p")) (and *AcadDoc* (vla-endundomark *AcadDoc*)) ) ;_ lambda ) ;_ setq (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vla-startundomark *AcadDoc*) (and (zerop (getvar 'worlducs)) (setq #Flag (vl-cmdf "_.ucs" ""))) (and (princ "\nSelect object(s) to divide along curve: ") (setq #SS (ssget "_:L")) (setq #Pnt (getpoint "\nBase point for objects: ")) (setq #Obj (AT:Entsel T "\nSelect curve to divide: " '("V" (0 . "LINE,*POLYLINE,ARC")) nil)) (not (initget 6)) (setq #Num (getint "\nNumber of objects: ")) (setq #Dist 0.) (or (not (vl-catch-all-error-p (setq #Len (vl-catch-all-apply 'vla-get-length (list #Obj))))) (not (vl-catch-all-error-p (setq #Len (vl-catch-all-apply 'vla-get-arclength (list #Obj))))) ) ;_ or (while (<= #Dist (- #Len (/ #Len #Num))) (vl-cmdf "_.copy" #SS "" "_non" #Pnt "_non" (vlax-curve-getpointatdist #Obj (setq #Dist (+ #Dist (/ #Len #Num)))) ) ;_ vl-cmdf ) ;_ while ) ;_ and (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Line Match Draw ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 11.18.09 (defun c:LMD (/ *error* #Clayer #Obj) (setq *error* (lambda (x) (and #Clayer (setvar 'clayer #Clayer)) (setvar 'celtype "BYLAYER"))) (setq #Clayer (getvar 'clayer)) (or (setq #Obj (ssget "_I" '((0 . "ARC,CIRCLE,LINE,*POLYLINE")))) T) (and (or (and #Obj (setq #Obj (vlax-ename->vla-object (ssname #Obj 0)))) (setq #Obj (AT:Entsel nil nil '("V" (0 . "ARC,CIRCLE,LINE,*POLYLINE")) nil)) ) ;_ or (setvar 'clayer (vla-get-layer #Obj)) (vl-catch-all-apply 'setvar (list 'celtype (vla-get-linetype #Obj))) (vl-cmdf "_.line") (while (> (getvar 'cmdactive) 0) (princ "\nSpecify point: ") (vl-cmdf PAUSE) ) ;_ while ) ;_ and (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Draw line perpendicular from selected curve ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 09.29.09 (defun c:LPer (/ *error* #Ent #Obj #Point) (setq *error* (lambda (x) (and #Obj (vl-catch-all-apply 'vla-highlight (list #Obj :vlax-false))))) (and (setq #Ent (AT:Entsel nil "\nSelect curve: " '((0 . "*POLYLINE,ARC,LINE,CIRCLE,ELLIPSE")) nil)) (setq #Obj (vlax-ename->vla-object (car #Ent))) (not (vla-highlight #Obj :vlax-true)) (while (setq #Point (getpoint "\nSpecify point for line: ")) (entmake (list '(0 . "LINE") (cons 10 (vlax-curve-getclosestpointtoprojection (car #Ent) (trans #Point 1 0) '(0 0 1))) (cons 11 (trans #Point 1 0)) ) ;_ list ) ;_ entmake ) ;_ while ) ;_ and (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; LayerObjectSelect ;;; Select all objects on selected layers, in current layout ;;; Required Subroutines: AT:ListSelect, AT:TabFilter ;;; Alan J. Thompson, 11.05.09 (defun c:LOS (/ _Layers #List #Filter #SS) (setq _Layers (lambda (/ d n l) (while (setq d (tblnext "layer" (null d))) (and (not (wcmatch (setq n (cdr (assoc 2 d))) "*|*")) (setq l (cons n l)) ) ;_ and ) ;_ while (vl-sort l '<) ) ;_ lambda ) ;_ setq (cond ((if dos_multilist (setq #List (dos_multilist "Select all objects on Layers" "Select layers:" (_Layers))) (setq #List (AT:ListSelect "Select all objects on Layers" "Select layers:" "30" "15" "true" (_Layers) ) ;_ AT:ListSelect ) ;_ setq ) ;_ if (setq #Filter "") (foreach x #List (setq #Filter (strcat #Filter x ","))) (and (setq #SS (ssget "_X" (list (AT:TabFilter) (cons 8 #Filter)))) (sssetfirst nil #SS) (print #List) ) ;_ and ) ) ;_ cond (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Draw single orthogonal line segment ;;; Alan J. Thompson, 11.24.09 (defun c:UL (/ *error* #Pnt) (setq *error* (lambda (x) (setvar 'orthomode 0))) (while (setq #Pnt (getpoint "\nSpecify first point: ")) (princ "\nSpecify next point: ") (setvar 'orthomode 1) (vl-cmdf "_.line" "_non" #Pnt PAUSE "") ) ;_ and (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Extended Trim (Trim select objects to imaginary drawn line) ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 11.24.09 (defun c:TRX (/ *error* #Pt1 #Pt2 #Line #Ent) (setq *error* (lambda (x) (and #Line (vl-catch-all-apply 'entdel (list #Line))))) (and (setq #Pt1 (getpoint "\nSpecify first point: ")) (setq #Pt2 (getpoint #Pt1 "\nSpecify next point: ")) (setq #Line (entmakex (list '(0 . "LINE") (cons 10 (trans #Pt1 1 0)) (cons 11 (trans #Pt2 1 0)))) ) ;_ setq (while (setq #Ent (AT:Entsel nil "\nSelect object to trim: " '(":L" (0 . "LINE,*POLYLINE,ARC,CIRCLE,ELLIPSE,HATCH,DIMENSION")) nil ) ;_ AT:Entsel ) ;_ setq (vl-cmdf "_.trim" #Line "" #Ent "") ) ;_ while ) ;_ and (*error* nil) (princ) ) ;_ defun Oops, forgot to post the extend one... ;;; Extended Extend (Extend select objects to imaginary drawn line) ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 10.21.09 (defun c:EXX (/ *error* #Pt1 #Pt2 #Line #Ent) (setq *error* (lambda (x) (and #Line (vl-catch-all-apply 'entdel (list #Line))))) (and (setq #Pt1 (getpoint "\nSpecify first point: ")) (setq #Pt2 (getpoint #Pt1 "\nSpecify next point: ")) (setq #Line (entmakex (list '(0 . "LINE") (cons 10 (trans #Pt1 1 0)) (cons 11 (trans #Pt2 1 0)))) ) ;_ setq (while (setq #Ent (AT:Entsel nil "\nSelect object to extend: " '(":L" (0 . "LINE,*POLYLINE,ARC,DIMENSION")) nil ) ;_ AT:Entsel ) ;_ setq (vl-cmdf "_.extend" #Line "" #Ent "") ) ;_ while ) ;_ and (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Layout Zoom Window (zoom to same window in all layouts) ;;; Alan J. Thompson, 11.10.09 (defun c:LZW (/ *error* #Ctab #Pnt #Cor #Pnts) (setq *error* (lambda (x) (and #Ctab (setvar 'ctab #Ctab)))) (or *Acad* (setq *Acad* (vlax-get-acad-object))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument *Acad*))) (cond ((zerop (getvar 'tilemode)) (vla-put-mspace *AcadDoc* :vlax-false) (setq #Ctab (getvar 'ctab)) (cond ((and (setq #Pnt (getpoint "\nSpecify first corner: ")) (setq #Cor (getcorner #Pnt "\nSpecify opposite corner: ")) ) ;_ and (setq #Pnts (mapcar 'vlax-3D-point (list #Pnt #Cor))) (foreach x (layoutlist) (setvar 'ctab x) (vla-put-mspace *AcadDoc* :vlax-false) (vla-zoomwindow *Acad* (car #Pnts) (cadr #Pnts)) ) ;_ foreach ) ) ;_ cond ) (T (alert "Sorry, command not allowed in Model Tab.")) ) ;_ cond (*error* nil) (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
