alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;join multiple lines/arcs ;created: alan thompson, 4.23.08 ;modified: alan thompson, 5.13.08 (localized variables to stop being so sloppy) (defun c:mj(/ lines) (princ "\nSelect lines & arcs to JOIN: ") (setq lines (ssget ":L" '((0 . "LINE,*POLYLINE,ARC")))) (if lines (progn (if (equal (getvar 'peditaccept) 1) (vl-cmdf "_.pedit" "_m" lines "" "_j" "" "") (vl-cmdf "_.pedit" "_m" lines "" "_y" "_j" "" "") );if );progn (alert (strcat "\nHey " (getvar "loginname") " it helps if you actually select something to work with!")) );if (princ) );defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;rotate selected objects 180° ;Alan J. Thompson (defun c:RR ( / obj pnt ) (if (and (princ "\nSelect object(s) to rotate 180°: ") (setq obj (ssget ":L")) (setq pnt (getpoint "\nPick rotation base point: ")) );and (progn (command "_.rotate" obj "" "_non" pnt "180") (princ (strcat "\n " (rtos (sslength obj) 2 0) " object(s) have been rotated 180°")) );progn (princ "\nMissed, try again.") );if (princ) );defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;turn on and thaw all layers (defun c:SEE () (command "-layer" "thaw" "*" "on" "*" "" ) (princ (strcat "\nALL LAYERS HAVE BEEN THAWED AND TURNED ON.")) (princ)) Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;text & leader delete ;only selects text, mtext & leaders to erase ;created: alan thompson - 4.17.08 (defun c:TX (/ ss) (prompt "\nSelect text & leaders to erase: ") (setq ss (ssget '((0 . "TEXT,MTEXT,LEADER")))) (if ss (progn (command "erase" ss "" ) (princ (strcat "\n " (rtos (sslength ss)) " Text and/or Leader objects have been deleted.")) );progn (princ "\nNo text selected, try again.") );if (princ) ) Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;zoom to specific scale (mapcar '(lambda (f z) (eval (list 'defun f nil (list 'command "_.zoom" (strcat "1/" (itoa z) "xp")) (list 'princ (strcat "\nZoomed Scale: 1\" = " (itoa z) "'") ) '(princ) ) ) ) '(c:10 c:20 c:30 c:40 c:50 c:60 c:100 c:200 c:300 c:400 c:500 c:600 c:1000 c:2000 c:3000 c:4000 c:5000 c:6000) '(10 20 30 40 50 60 100 200 300 400 500 600 1000 2000 3000 4000 5000 6000) ) Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 23, 2009 Author Share Posted September 23, 2009 ; Current Layer Set and/or Reset ; created by: alan thompson, 2.24.09 (defun c:LRS ( / ) (if (setq $LRS=Clayer$ (getvar "clayer")) (princ (strcat "\n \"" $LRS=Clayer$ "\" is the stored revert layer.")) );if (princ) );defun (defun c:LR ( / ) (if (and $LRS=Clayer$ (tblsearch "layer" $LRS=Clayer$) );and ;t, let's set it as our current layer (progn (vl-cmdf "_.layer" "_t" $LRS=Clayer$ "_s" $LRS=Clayer$ "") (princ (strcat "\n \"" $LRS=Clayer$ "\" is the current layer.")) );progn ;nil, let's store a different layer (run c:LRS) (progn (princ "\nStored layer nil, resetting...") (if c:LRS (c:LRS) (alert "Command \"c:LRS\" is not loaded.") ); );progn );if (princ) );defun Quote Link to comment Share on other sites More sharing options...
flowerrobot Posted September 23, 2009 Share Posted September 23, 2009 Mate nice work.. Purhaps a Zip file following would be grand aswell, Saves the hole copy & pasting them Flower Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 23, 2009 Author Share Posted September 23, 2009 Mate nice work.. Purhaps a Zip file following would be grand aswell, Saves the hole copy & pasting them Flower Ehh, then how would I fluff my post count.:wink: It's just a bunch of random stuff, I figured people could read through them (if they wanted) and take what they like. Judging by the response, they're of no use anyway. Oh well, not why I posted them. Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted September 23, 2009 Share Posted September 23, 2009 Ehh, then how would I fluff my post count.:wink: Look like counter get stuck... Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted September 23, 2009 Share Posted September 23, 2009 Ehh, then how would I fluff my post count.:wink:It's just a bunch of random stuff, I figured people could read through them (if they wanted) and take what they like. Judging by the response, they're of no use anyway. Oh well, not why I posted them. Alan, It looks like a Lisp Clearence Sale. Everything Must Go! Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 23, 2009 Author Share Posted September 23, 2009 Alan, It looks like a Lisp Clearence Sale. Everything Must Go! LoL I just thought I'd post some randoms. No sense in them sitting in my LSP folder, only being used by me. If someone else can benefit from it, why not share it. I wrote them because I felt they were a useful addition to AutoCAD, someone out there might feel the same. 1 Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 23, 2009 Author Share Posted September 23, 2009 ;toggle toolpalettes on/off state (defun c:TP() (if (equal (getvar 'tpstate) 0) (command "'toolpalettes") (command "'toolpalettesclose") );if (princ)) ;toggles properties menu on/off state (defun c:MO() (if (equal (getvar 'opmstate) 2) (princ "\nNo toggle for you!") (progn (if (equal (getvar 'opmstate) 0) (command "'properties") (command "'propertiesclose") );if );progn );if (princ)) ;toggle layer properties manager on/off state (defun c:LY() (if (equal (getvar 'layermanagerstate) 0) (progn (initdia) (command "'layer") );progn (command "layerclose") );if (princ)) ;toggle sheet set manager on/off state (defun c:SSM () (if (equal (getvar 'ssmstate) 0) (command "sheetset") (command "'sheetsethide") );if (princ)) Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 23, 2009 Author Share Posted September 23, 2009 ;toggle between ucs world and previous ucs (if "A" exists, it will be set as current) (defun c:UT() (if (equal (getvar 'worlducs) 1) (progn (if (tblsearch "ucs" "a") (command "ucs" "r" "a") (command "ucs" "p") );if );progn (command "ucs" "world") );if (princ)) ;toggle between tilemodes/spaces (paper/model) (defun c:TI (/) (setvar 'tilemode (abs (1- (getvar 'tilemode)))) (princ) ) Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 23, 2009 Author Share Posted September 23, 2009 ;toggle on/off state of the current layer ;created by: alan thompson 6.13.08 (defun c:tg (/ layer_info layer_color) (setq layer_info (entget (tblobjname "LAYER" (getvar 'clayer)))) (setq layer_color (assoc 62 layer_info)) (entmod (subst (cons 62 (- (cdr layer_color))) layer_color layer_info)) (princ (strcat "\nLayer * " (getvar "clayer") " * has been turned " (if (< (cdr layer_color) 0 ) "on!" "off!" );if );strcat );princ (princ)) Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 23, 2009 Author Share Posted September 23, 2009 ;rotate objects (created for rotating lines) to match a rotation of another line based on the 2 end points ;created by: alan thompson, 2.14.08 (Valentine's Day) (defun c:RF ( / obj base_pnt obj_pnt ) (princ "\nSelect object(s) to rotate: ") (if (and (setq obj (ssget ":L")) (setq base_pnt (getpoint "\nSpecify base point: ")) (setq obj_pnt (getpoint base_pnt "\nPick point of object to rotate: ")) );and (command "_.rotate" obj "" "_non" base_pnt "_r" "_non" base_pnt "_non" obj_pnt) (princ "\nMissed, try again.") );if (princ) );defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 23, 2009 Author Share Posted September 23, 2009 ;;; Check if 2 lines are parallel ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 09.08.09 (defun c:PL (/ #Line1 #Line2 #Angle1 #Angle2) (cond ((and (setq #Line1 (AT:Entsel T "\nSpecify first line: " '((0 . "LINE")) nil ) ;_ AT:Entsel ) ;_ setq (setq #Line2 (AT:Entsel T "\nSpecify second line: " '((0 . "LINE")) nil ) ;_ AT:Entsel ) ;_ setq ) ;_ and (setq #Line1 (entget (car #Line1)) #Line2 (entget (car #Line2)) #Angle1 (angle (cdr (assoc 10 #Line1)) (cdr (assoc 11 #Line1))) #Angle2 (angle (cdr (assoc 10 #Line2)) (cdr (assoc 11 #Line2))) ) ;_ setq (princ (strcat "\nSelected lines" (if (or (equal #Angle1 #Angle2 0.000001) (equal #Angle1 (+ pi #Angle2) 0.000001) (equal (+ pi #Angle1) #Angle2 0.000001) ) ;_ or " ARE " " are NOT " ) ;_ if "parallel!" ) ;_ strcat ) ;_ princ ) ) ;_ cond (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 23, 2009 Author Share Posted September 23, 2009 ;;; Change color of selected objects' layer ;;; Required Subroutines: AT:SS->List ;;; Alan J. Thompson, 07.23.09 (defun c:CLC (/ #SSList #Color) (and (setq #SSList (AT:SS->List (ssget) T)) (setq #Color (acad_colordlg 1)) (foreach x #SSList (vla-put-color (vlax-ename->vla-object (tblobjname "layer" (vla-get-layer x) ) ;_ tblobjname ) ;_ vlax-ename->vla-object #Color ) ;_ vla-put-color ) ;_ foreach ) ;_ and (princ) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
flowerrobot Posted September 24, 2009 Share Posted September 24, 2009 I figured people could read through them (if they wanted) and take what they like.Judging by the response, they're of no use anyway. Oh well, not why I posted them. Not sure if people do take use of things and not say they did, Or People dont.. There was a couple that would save some time, But there were some good snickets that would be usefull Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 24, 2009 Author Share Posted September 24, 2009 Not sure if people do take use of things and not say they did, Or People dont.. There was a couple that would save some time, But there were some good snickets that would be usefull Oh I know. My purpose in posting these was not for a response. Like I said, I use them and I thought they might benefit someone else. Quote Link to comment Share on other sites More sharing options...
flowerrobot Posted September 24, 2009 Share Posted September 24, 2009 might benefit someone else. Might benefit the lasy who dont have the time to copy them, With a zip file Quote Link to comment Share on other sites More sharing options...
