alanjt Posted September 22, 2009 Posted September 22, 2009 To compliment the subroutine thread: http://www.cadtutor.net/forum/showthread.php?t=40344 Some of these I wrote pretty early on. I wasn't very good (not that I'm much better), but they work (regardless of them being ugly), and I have better things to waste my time on than making old routines more ascetically pleasing. ;fillet with set radius ;Alan J. Thompson (mapcar '(lambda (f r) (eval (list 'defun f nil (list 'setvar "filletrad" r) (list 'princ (strcat "\nFillet radius set to: " (rtos r))) (list 'command "_.fillet") '(princ) ) ) ) '(c:FF c:F1 c:F15 c:F2 c:F3 c:F4 c:F45 c:F5 c:F6 c:F7 c:F8 c:F9) '(0 1 1.5 2 3 4 4.5 5 6 7 8 9) ) Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;fillet (windowed) objects (defun c:fc()(command "fillet" "c")(princ)) ;MAKE A LAYER (defun c:LM () (command "-layer" "make" ) (princ)) ;ALLOWS YOU TO FREEZE BY ENTERING IN LAYER NAMES (WILD CARDS ALLOWED) (defun c:LAZ () (command "-layer" "freeze" ) (princ)) ;ALLOWS YOU TO TURN OFF LAYERS BY ENTERING IN LAYER NAMES (WILD CARDS ALLOWED) (defun c:LAF () (command "-layer" "off" ) (princ)) ;LOCK LAYER(S) BY PICK OR BY NAME (WILD CARDS ALLOWED) (defun c:LK () (command "-layer" "lock" ) (princ)) ;UNLOCK LAYER(S) BY PICK OR BY NAME (WILD CARDS ALLOWED) (defun c:LU () (command "-layer" "unlock" ) (princ)) ;set vports to 1 (defun c:V1() (command "-vports" "si") (princ)) ;set vports to 2 (defun c:V2() (command "-vports" "2" "v") (princ)) ;zoom extents (defun C:ZX () (vla-ZoomExtents (vlax-get-acad-object) ) ;_ vla-ZoomExtents (prompt "\nZoom Extents") (princ) ) ;_ defun ;zoom previous (defun C:ZQ () (vla-ZoomPrevious (vlax-get-acad-object) ) ;_ vla-ZoomPrevious (prompt "\nZoom Previous") (princ) ) ;_ defun ;UNLOAD ALL XREFS (defun c:xu () (command "-xref" "UNLOAD" "*") (princ)) ;RELOAD ALL XREFS (defun c:XE () (command "-xref" "RELOAD" "*" ) (princ)) ;LENGTHEN (TOTAL) (defun c:LG() (princ "\nLengthen Total") (command "lengthen" "t") (princ)) ;LENGTHEN (DELTA) (defun c:DE () (princ "\nLengthen Delta") (command "lengthen" "de") (princ)) ;CHANGE MACRO (defun c:CH ( / ss_objects ) (princ "\nChange") (setq ss_objects (ssget ":L")) (if ss_objects (vl-cmdf "_.change" ss_objects "" "_p") (princ "\nNothing selected, try again.") );if (princ) );defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 Just as it says, creates quick Dummy layers. ;DUMMY LAYERS (CREATES AND/OR SETS AS CURRENT) (defun AT:DummyLayer (DL_Name DL_Color DL_Plot) (cond ((tblsearch "layer" DL_Name) (vl-cmdf "_.layer" "_t" DL_Name "_s" DL_Name "_p" DL_Plot DL_Name "") ;_ vl-cmdf (princ (strcat "\nLayer: \"" DL_Name "\" is the current layer.") ) ;_ princ ) (T (vl-cmdf "_.layer" "_m" DL_Name "_c" DL_Color DL_Name "_p" DL_Plot DL_Name "" ) ;_ vl-cmdf (princ (strcat "\nLayer: \"" DL_Name "\" has been created.") ) ;_ princ ) ) ;_ cond (princ) ) ;_ defun ;"ALAN" LAYER (defun c:ALAN (/) (AT:DummyLayer "ALAN" 2 "P") (princ)) Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;arc by 2 selected endpoints, then entering or selecting radius (defun c:AR ( / point_1 point_2 ) (if (and (setq point_1 (getpoint "\nPick 1st Point: ")) (setq point_2 (getpoint point_1 "\nPick 2nd Point: ")) );and (command "_.arc" "_non" point_1 "_e" "_non" point_2 "_r") (princ "\nMissed, try again.") );if (princ) );defun ;create section outline (defun c:SEC ( / sec_pnt ) (if (setq sec_pnt (getpoint "\nPick NW corner of section: ")) (command "_.pline" sec_pnt "@5280<n90de" "@5280<s0de" "@5280<n90dw" "@5280<n0dw" "") (princ "\nMissed, try again.") );if (princ) );defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;set selected objects to "ByLayer" (defun c:SBL ( / #ssget ) (if (setq #ssget (ssget ":L")) (vl-cmdf "_.setbylayer" #ssget "" "_y" "_y") (princ "\nMissed, try again.") );if (princ) );defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;mtext with 0 width (defun c:T (/ #GetPoint) (initdia) (command "_.mtext") (if (setq #GetPoint (getpoint "\nSpecify first corner: ")) (command #GetPoint "_w" 0) ) (princ) ) ;mtext center justified, 0 width (defun c:TY (/ #GetPoint) (initdia) (command "_.mtext") (if (setq #GetPoint (getpoint "\nSpecify first corner: ")) (command #GetPoint "_j" "_mc" "_w" 0) ) (princ) ) ;clipboard selected objects with basepoint of 0,0,0 (defun c:C0 ( / #ssget ) (if (setq #ssget (ssget ":L")) (progn (vl-cmdf "_.copybase" "0,0,0" #ssget "") (prompt (strcat "\n" (rtos (sslength #ssget) 2 0) " object(s) have been clipboarded at: 0,0,0")) );progn );if (princ) );defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;break object @ point ;alan thompson, 3.26.09 (defun c:BA (/ *error* #GetvarList #SetvarList #Entsel #Getpoint) (defun *error* (msg) (mapcar 'setvar #GetvarList #SetvarList) ) ;_ defun (setq #GetvarList (list "cmdecho" "osmode")) (setq #SetvarList (mapcar 'getvar #GetvarList)) (setvar "cmdecho" 0) (setvar "errno" 0) (if (while (and (not #Entsel) (not (eq (getvar "errno") 52)) ) ;and (setq #Entsel (entsel "\nSelect object to break: ")) ) ;while (progn (setq #Getpoint (getpoint "\nSelect point to break @ or <Selection Point>: ")) (setvar "osmode" 0) (if (not #GetPoint) (setq #GetPoint (osnap (cadr #Entsel) "_near")) ) ;_ if (vl-cmdf "_.break" #Entsel "_f" "_non" #Getpoint "_non" #Getpoint) ;_ vl-cmdf ) ;_ progn (princ "\nMissed, try again.") ) ;if (mapcar 'setvar #GetvarList #SetvarList) (princ) ) ;defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;rotate a copy of selected object(s) (defun c:RC ( / #SSGet #GetPoint ) (prompt "\nSelect objects of which to rotate a copy: ") (if (and (setq #SSGet (ssget ":L")) (setq #GetPoint (getpoint "\nSpecify base point: ")) ) (vl-cmdf "_.rotate" #SSGet "" "_non" #GetPoint "_c") (prompt "\nMissed, try again.") ) (princ) ) Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;;; Calculate Percent Slope ;;; Alan J. Thompson, 04.30.09 (defun c:Slope ( / #Elev1 #Elev2 #Dist #Calc) (cond ((and (setq #Elev1 (getreal "\nElevation 1: ")) (setq #Elev2 (getreal "\nElevation 2: ")) (setq #Dist (getdist "\nDistance: ")) ) (setq #Calc (strcat "\nElevation 1: " (rtos #Elev1 2 2) "\nElevation 2: " (rtos #Elev2 2 2) "\nDistance: " (rtos #Dist 2 2) "\n---------------------------" "\nSlope: " (rtos (* 100 (/ (- #Elev1 #Elev2) #Dist)) 2 2) "%" ) ) (prompt #Calc) (alert #Calc) ) ) (princ) ) ;;; Calculate grade of unknown point ;;; Alan J. Thompson, 05.11.09 (defun c:GRADE (/ #Dist #Elev #Grade #NewElev) (cond ((and (setq #Dist (getdist "\nDistance: ")) (setq #Elev (getreal "\nElevation of known point: ")) (setq #Grade (getreal "\nPercent grade (eg: 0.25 for 0.25%): ")) ) ;_ and (setq #NewElev (strcat "\nElevation: " (rtos (+ (* #Dist (/ #Grade 100)) #Elev) 2 3) ) ;_ strcat ) ;_ setq (princ #NewElev) (alert #NewElev) ) ) ;_ cond (princ) ) ;_ defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;;; Move all Text, Mtext, Multileader, Dimension objects to front ;;; Alan J. Thompson, 06.01.09 (defun c:TTF (/ #SSGet) (or (ssget "_I") (prompt "\nSelect Text, Multileader, Dimension objects to move to front: " ) ;_ prompt ) ;_ or (cond ((setq #SSGet (ssget ":L" '((0 . "MTEXT,TEXT,MULTILEADER,DIM*")))) (vl-cmdf "_.draworder" #SSGet "" "_f") (prompt (strcat (itoa (sslength #SSGet)) " Text, Multileader, Dimension objects moved to front." ) ;_ strcat ) ;_ prompt ) ) ;_ cond (princ) ) ;_ defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;;; Quick Hatch: hatch with all previously set hatch settings ;;; Only works if hatching by picked internal point (defun c:HH (/ #Point) (and (princ "\nQuick Hatch") (while (setq #Point (getpoint "\nSpecify internal point: ")) (vl-cmdf "_.-hatch" #Point "") ) ;_ while ) ;_ and (princ) ) ;_ defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;;; Quick Attribute Editor (edit selected attribute string) ;;; Subroutines Required: AT:Entsel AT:GetString ;;; Alan J. Thompson, 08.25.09 (defun c:AE (/ #Entsel #String) (and (setq #Entsel (AT:Entsel T "\nSelect attribute to edit: " '((0 . "ATTRIB")) nil ) ;_ AT:Entsel ) ;_ setq (setq #Entsel (vlax-ename->vla-object (car #Entsel))) (setq #String (AT:GetString "Edit Attribute" (vla-get-TextString #Entsel) ) ;_ AT:GetString ) ;_ setq (vla-put-TextString #Entsel #String) ) ;_ and (princ) ) ;_ defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 I forgot to mention, some of these will require subroutines. I should have posted them all in the Subroutine thread. The link is the first post of this thread. Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;;; Display and/or change width of selected Polyline or LWPolyline ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 08.27.09 (defun c:W (/ #Object #OldWidth #NewWidth #ExitFlag) (cond ((setq #Object (AT:Entsel nil "\nSelect Polyline: " '((0 . "POLYLINE,LWPOLYLINE")) nil ) ;_ AT:Entsel ) ;_ setq (setq #Object (vlax-ename->vla-object (car #Object)) #OldWidth (vla-get-constantwidth #Object) #PlineType (substr (vla-get-objectname #Object) 5) ) ;_ setq ;; pline selected & width extracted, time to prompt & set new width (while (and (not #ExitFlag) (not (initget 4 "Exit")) (setq #NewWidth (getreal (strcat "\nSelected " #PlineType " width: " (vl-princ-to-string #OldWidth) "\nSpecify new width or [Exit] <Exit>: " ) ;_ strcat ) ;_ getreal ) ;_ setq ) ;_ and (cond ;; new width specified ((numberp #NewWidth) (vla-put-constantwidth #Object #NewWidth) (setq #OldWidth #NewWidth) (prompt (strcat "\n* - * = * - * -> " #PlineType " width changed to: " (vl-princ-to-string #NewWidth) " <- * - * = * - *" ) ;_ strcat ) ;_ prompt ) ;; nil or user typed in "Exit" ((or (not #NewWidth) (eq #NewWidth "Exit") ) ;_ or (setq #ExitFlag T) ) ) ;_ cond ) ;_ while ) ) ;_ cond (princ) ) ;_ defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;;; Fillet with entered radius or radius of selected arc (option to delete selected arc) ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 09.03.09 (defun c:FR (/ #Radius #Object #Choice) (initget 4 "Select") (or (setq #Radius (getdist (strcat "\nSpecify fillet radius or select arc [select] <" (rtos (getvar "filletrad") 2 2) ">: " ) ;_ strcat ) ;_ getdist ) ;_ setq (setq #Radius (getvar "filletrad")) ) ;_ or (cond ((eq #Radius "Select") (and (setq #Object (AT:Entsel nil "\nSelect arc to extract radius: " '("VL" (0 . "ARC")) nil ) ;_ AT:Entsel ) ;_ setq (princ (strcat "\nFillet Radius: " (vl-princ-to-string (setvar "filletrad" (vla-get-radius #Object)) ) ;_ vl-princ-to-string ) ;_ strcat ) ;_ princ (not (initget 0 "Yes No Delete")) (if (and (or (setq #Choice (getkword "\nDelete selected arc? [Yes/No] <No>: " ) ;_ getkword ) ;_ setq (setq #Choice "No") ) ;_ or (member #Choice (list "Yes" "Delete")) ) ;_ and (not (vla-delete #Object)) T ) ;_ if (vl-cmdf "_.fillet") ) ;_ and ) ((numberp #Radius) (setvar "filletrad" #Radius) (vl-cmdf "_.fillet") ) ) ;_ cond (princ) ) ;_ defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;;; Offset selected object to current layer ;;; Required Subroutines: AT:Entsel ;;; Alan J. Thompson, 09.08.09 (defun c:OL (/ #Dist #Entsel #Point) (and (eq -1 (getvar "offsetdist")) (setvar "offsetdist" 1)) (initget 6) (and (or (setq #Dist (getdist (strcat "\nSpecify offset distance <" (rtos (getvar "offsetdist") 2 2) ">: " ) ;_ strcat ) ;_ getdist ) ;_ setq (setq #Dist (getvar "offsetdist")) ) ;_ or (while (and (setq #Entsel (AT:Entsel nil "\nSelect object to offset to current layer: " '("L" (0 . "LINE,*POLYLINE,ARC,CIRCLE,ELLIPSE,SPLINE") ) nil ) ;_ AT:Entsel ) ;_ setq (setq #Point (getpoint "\nSpecify point on side to offset: ")) ) ;_ and (vl-cmdf "_.offset" #Dist #Entsel #Point "") (vla-put-layer (vlax-ename->vla-object (entlast)) (getvar "clayer") ) ;_ vla-put-layer ) ;_ while ) ;_ and (princ) ) ;_ defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 Couple C3D macros: ;line by bearing & distance (defun c:BL ( / begin_point ) (setq begin_point (getpoint "\nPick starting point: ")) (if (not begin_point) (setq begin_point (getvar "lastpoint")) );if (vl-cmdf "_.line" "_non" begin_point "'BD") (princ) );defun ;delete selected segment labels (defun c:NL (/ ss) (prompt "\nSelect C3D Segment Labels to erase: ") (setq ss (ssget '((0 . "AECC_GENERAL_SEGMENT_LABEL")))) (if ss (progn (command "erase" ss "" ) (princ (strcat "\n " (rtos (sslength ss) 2 0) " C3D Segment Label(s) have been deleted.")) );progn (princ "\nMissed, try again.") );if (princ) );defun ;;; set object layer for segment & note label ;;; Alan J. Thompson, 05.18.09 (defun c:LAS (/) (cond ((and AT:SetObjectLayer) (AT:SetObjectLayer 'GeneralNoteLabelLayer (getvar "clayer")) (AT:SetObjectLayer 'GeneralSegmentLabelLayer (getvar "clayer") ) ;_ AT:SetObjectLayer (prompt "\nObject layer for 'GeneralNoteLabel' & 'GeneralSegment'\n are set to the current layer!" ) ;_ prompt ) ) ;_ cond (princ) ) ;_ defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 Conversion reference ;just some converstion factors ;alan thompson, 1.29.09 (defun c:conv ( / ) (alert (strcat " **** Useful Conversions ***** " "\n1 Acre = 43,560 square feet" "\n1 Acre = 10 square chains" "\n1 Acre = 4047 square meters" "\n1 Acre = is about 208 3/4 feet square" "\n" "\n1 Centimeter = .3937 inches" "\n1 Centimeter = .032808 feet" "\n" "\n1 Chain = 66 feet" "\n1 Chain = 100 links" "\n1 Chain = 20.1168 meters" "\n" "\n1 Foot = 0.3048006 meter" "\n" "\n1 Inch = .0254 meter" "\n" "\n1 Link = 7.92 inches" "\n1 Link = .66 feet" "\n1 Link = .2017 meter" "\n" "\n1 Meter = 3.280833 feet" "\n1 Meter = 39.37 inches" "\n1 Meter Square = 10.764 square feet" "\n" "\n1 Mile = 5,280 feet" "\n1 Mile = 80 chains" "\n1 Mile = 1.60935 kilometers" "\n1 Mile = 320 perches" "\n1 Mile = 320 poles" "\n1 Mile = 8000 links" "\n1 Mile = 1,609.2655 meters" "\n1 Mile Square = a regular Section of land" "\n1 Mile Square = 27,878,400 square feet" "\n1 Mile Square = 640 acres" "\n" "\n1 Section = 1 mile long, by 1 mile wide" "\n1 Section = 640 acres" "\n" "\n1 Township = 6 miles long, by 6 miles wide" "\n1 Township = 36 sections" "\n1 Township = 36 square miles" "\n" "\n1 Yard = 36 inches" "\n1 Yard = 3 feet" "\n1 Yard Square = 9 square feet" );strcat );princ (princ) );defun Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;open Windows Explorer In The Directory Of The Active Drawing File. (defun C:dirr (/) (startapp "explorer" (getvar "dwgprefix")) (princ) ) Quote
alanjt Posted September 22, 2009 Author Posted September 22, 2009 ;;;justification macros (center, left, right) ;;;created by: alan thompson, 3.21.08 ;;;updated by: alan thompson, 3.6.09 (fixed ssget to ignore objects on locked layers) ;;;updated by: alan thompson, 3.16.09 (added Top & Bottom Center) ;;; Justify Text "MIDDLE CENTER" (defun c:JC (/ ss) (princ "\nSelect Text to Middle Center Justify: ") (if (setq ss (ssget ":L" '((0 . "*TEXT,ATTDEF")))) (vl-cmdf "_.justifytext" ss "" "_mc") (princ "\nMissed, try again.") ) ;_ if (princ) ) ;_ defun ;;; Justify Text "MIDDLE LEFT" (defun c:JL (/ ss) (princ "\nSelect Text to Middle Left Justify: ") (if (setq ss (ssget ":L" '((0 . "*TEXT,ATTDEF")))) (vl-cmdf "_.justifytext" ss "" "_ml") (princ "\nMissed, try again.") ) ;_ if (princ) ) ;_ defun ;;; Justify Text "MIDDLE RIGHT" (defun c:JR (/ ss) (princ "\nSelect Text to Middle Right Justify: ") (if (setq ss (ssget ":L" '((0 . "*TEXT,ATTDEF")))) (vl-cmdf "_.justifytext" ss "" "_mr") (princ "\nMissed, try again.") ) ;_ if (princ) ) ;_ defun ;;; Justify Text "BOTTOM CENTER" (defun c:BC (/ ss) (princ "\nSelect Text to Bottom Center Justify: ") (if (setq ss (ssget ":L" '((0 . "*TEXT,ATTDEF")))) (vl-cmdf "_.justifytext" ss "" "_bc") (princ "\nMissed, try again.") ) ;_ if (princ) ) ;_ defun ;;; Justify Text "TOP CENTER" (defun c:TC (/ ss) (princ "\nSelect Text to Top Center Justify: ") (if (setq ss (ssget ":L" '((0 . "*TEXT,ATTDEF")))) (vl-cmdf "_.justifytext" ss "" "_tc") (princ "\nMissed, try again.") ) ;_ if (princ) ) ;_ defun Quote
