alanjt Posted November 2, 2009 Author Share Posted November 2, 2009 ;;; Return all all duplicates within list ;;; #List - List to process ;;; Alan J. Thompson, 11.01.09 (defun AT:ListDuplicates (#List) (vl-remove-if-not '(lambda (x) (member x (cdr (member x #List)))) #List ) ;_ vl-remove-if-not ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted November 3, 2009 Author Share Posted November 3, 2009 ;;; Insert block into drawing ;;; #Name - name of block ;;; #InsPt - insert point ;;; #XScale - block X scale ;;; #YScale - block Y scale ;;; #Rot - block rotation ;;; Alan J. Thompson, 04.21.09 (defun AT:InsertBlock (#Name #InsPt #XScale #YScale #Rot) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (if (or (tblsearch "block" #Name) (findfile #Name) ) ;_ or (vla-insertblock (if (or (eq acmodelspace (vla-get-activespace *AcadDoc*)) (eq :vlax-true (vla-get-mspace *AcadDoc*)) ) ;_ or (vla-get-modelspace *AcadDoc*) (vla-get-paperspace *AcadDoc*) ) ;_ if (if (vl-consp #InsPt) (vlax-3d-point #InsPt) #InsPt ) ;_ if #Name #XScale #YScale #XScale #Rot ) ;_ vla-insert-block ) ;_ if ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 8, 2009 Author Share Posted December 8, 2009 ;;; Offset selected object ;;; #Ent&Point - List of entity and point ;;; #Dist - Distance to offset object ;;; #Point - Point on side of object to offset ;;; Alan J. Thompson, 09.12.09 (defun AT:Offset (#Ent&Point #Dist #Point / #POC1 #POC2 #Obj #Dist #Check) ;; get first point on curve (setq #POC1 (vlax-curve-getClosestPointTo (setq #Obj (vlax-ename->vla-object (car #Ent&Point))) (trans (cadr #Ent&Point) 1 0) ) ;_ vlax-curve-getClosestPointTo ) ;_ setq ;; get another point on curve, 0.0001 away (setq #POC2 (vlax-curve-getPointAtDist #Obj (+ (vlax-curve-getDistAtPoint #Obj #POC1) 0.0001) ) ;_ vlax-curve-getPointAtDist ) ;_ setq ;; determine which side #Point is on and set distance for offset (if (minusp (- (* (- (car #POC2) (car #POC1)) (- (cadr (trans #Point 1 0)) (cadr #POC1)) ) ;_ * (* (- (cadr #POC2) (cadr #POC1)) (- (car (trans #Point 1 0)) (car #POC1)) ) ;_ * ) ;_ - ) ;_ minusp (if (member (vla-get-objectname #Obj) '("AcDbLine" "AcDbXline")) (setq #Dist (- (abs #Dist))) (setq #Dist (abs #Dist)) ) ;_ if (if (member (vla-get-objectname #Obj) '("AcDbLine" "AcDbXline")) (setq #Dist (abs #Dist)) (setq #Dist (- (abs #Dist))) ) ;_ if ) ;_ if ;; offset object (if (not (vl-catch-all-error-p (setq #Check (vl-catch-all-apply 'vla-offset (list #Obj #Dist) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ vl-catch-all-error-p ) ;_ not (car (vlax-safearray->list (vlax-variant-value #Check))) ) ;_ if ) ;_ defun Quote Link to comment Share on other sites More sharing options...
Least Posted December 8, 2009 Share Posted December 8, 2009 ;;; Extract all Attributes from Block or Multileader w/Block ;;; #Object - Block/Multileader to extract attributes ;;; Alan J. Thompson, 08.17.09 (defun AT:GetAttributes (#Object / #Object #Entget) (if #Object (progn ;; if list, strip out ename (and (vl-consp #Object) (setq #Object (car #Object))) (cond ;; if vla-object & multileader with block, convert to ename ((and (eq (type #Object) 'VLA-OBJECT) (vlax-property-available-p #Object 'ContentBlockName) ) ;_ and (setq #Object (vlax-vla-object->ename #Object)) ) ;; if ename & block, convert to vla-object ((and (eq (type #Object) 'ENAME) (eq "INSERT" (cdr (assoc 0 (entget #Object)))) ) ;_ and (setq #Object (vlax-ename->vla-object #Object)) ) ) ;_ cond ;; run through options (cond ;; vla-object & attributed block ((and (eq (type #Object) 'VLA-OBJECT) (eq "AcDbBlockReference" (vla-get-objectname #Object) ) ;_ eq (eq (vla-get-hasattributes #Object) :vlax-true) ) ;_ and (vlax-safearray->list (vlax-variant-value (vla-getattributes #Object) ) ;_ vlax-variant-value ) ;_ vlax-safearray->list ) ;; ename or entsel-style list ((or (eq (type #Object) 'ENAME) (vl-consp #Object) ) ;_ or (setq #Entget (entget #Object)) (vl-remove-if '(lambda (x) (or (not x) (not (eq "AcDbAttributeDefinition" (vla-get-objectname x) ) ;_ eq ) ;_ not ) ;_ or ) ;_ lambda (mapcar '(lambda (x) (if (eq 330 (car x)) (vlax-ename->vla-object (cdr x)) ) ;_ if ) ;_ lambda #Entget ) ;_ mapcar ) ;_ vl-remove-if ) ) ;_ cond ) ;_ progn ) ;_ if ) ;_ defun Hi Alan Thanks for making these lisps available. I tried to run this lisp, but wasn't quite sure what to do. The block I wish to export attributes from is called PT2. Does this lisp also export the X and Y coordinates of the block's insertion point? Cheers Pads Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 8, 2009 Share Posted December 8, 2009 Bear in mind that this is a Sub-Routine, and need to be fed arguments to process. Quote Link to comment Share on other sites More sharing options...
Least Posted December 8, 2009 Share Posted December 8, 2009 Ok thanks, I think I'll leave it. I need a lot more comments to be able to understand and then possibly make use of it. cheers P Quote Link to comment Share on other sites More sharing options...
alanjt Posted December 8, 2009 Author Share Posted December 8, 2009 Hi AlanThanks for making these lisps available. I tried to run this lisp, but wasn't quite sure what to do. The block I wish to export attributes from is called PT2. Does this lisp also export the X and Y coordinates of the block's insertion point? Cheers Pads You are welcome. This is my subroutine section and as Lee said, you have to feed it certain arguments. Exaple: (AT:GetAttributes (entsel)). In regards to extracting the X/Y, as prefaced in the code, it is for extracting attribute objects from attributed blocks and attributed block mleaders. Subroutines are written with specific purposes. Quote Link to comment Share on other sites More sharing options...
asos2000 Posted February 17, 2010 Share Posted February 17, 2010 Thanks alanjt whats deffirence between (setq #Dist (abs #Dist)) and (setq Dist (abs Dist)) or in other hand what is usage of adding # and * ? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 17, 2010 Share Posted February 17, 2010 or in other hand what is usage of adding # and * ? Nothing, just his dodgy coding style Quote Link to comment Share on other sites More sharing options...
asos2000 Posted February 17, 2010 Share Posted February 17, 2010 LOL MY dodgy coding is #* Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 17, 2010 Author Share Posted February 17, 2010 It's just my way of keeping organized; OCD. #Variable = local variable RN:#Variable = global variable pertaining to a specific routine (RN = RoutineName) *Variable* = global variable that can be used my multiple routines AT:Name = global or localized subroutine that I will use multiple times _Name = local subroutine (or sub-subroutine) specifically pertaining to a routine or subroutine. Quote Link to comment Share on other sites More sharing options...
asos2000 Posted February 18, 2010 Share Posted February 18, 2010 Thanks alanjt for your clarification Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 18, 2010 Author Share Posted February 18, 2010 Thanks alanjt for your clarification No problem. As you can see, I'm a little **** retentive. Quote Link to comment Share on other sites More sharing options...
asos2000 Posted February 18, 2010 Share Posted February 18, 2010 Same is here Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; List of layouts (VLA-Objects) in drawing (in correct order) ;;; Alan J. Thompson, 10.05.09 (defun AT:LayoutList (/ #Layouts) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object)))) (vlax-for x (vla-get-layouts *AcadDoc*) (or (eq (vla-get-name x) "Model") (setq #Layouts (cons x #Layouts))) ) ;_ vlax-for (vl-sort #Layouts '(lambda (x y) (< (vla-get-taborder x) (vla-get-taborder y)))) ) ;_ defun Just in case : (mapcar 'vla-get-name (AT:LayoutList)) Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; SSGet Replacement, with prompt ;;; #Msg - Display message ;;; #Type - Selection method (ie: "_X", "_:L"), nil if not ;;; #Filter - Selection filter, nil if not ;;; Alan J. Thompson, 10.31.09 (defun AT:SSGet (#Msg #Meth #Filter / *error* #SS) (setq *error* (lambda (x) (setvar "nomutt" 0))) (and #Msg (prompt #Msg)) (setvar "nomutt" 1) (if #Meth (setq #SS (ssget #Meth #Filter)) (setq #SS (ssget #Filter)) ) ;_ if (*error* nil) #SS ) ;_ defun ;;; Subtract matching enames from selection set ;;; ss1 - Selection set to evaluate ;;; ss2 - Selection set to compare with ;;; Alan J. Thompson, 11.25.09 (defun AT:SSRemove (ss1 ss2 / ss3 n) (setq n -1 ss3 ss1 ) ;_ setq (repeat (sslength ss2) (if (ssmemb (setq o (ssname ss2 (setq n (1+ n)))) ss3 ) ;_ ssmemb (ssdel o ss3) ) ;_ if ) ;_ repeat ss3 ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Retreive segment number and Start & End points ;;; #Obj&PntList - List with object & point ;;; Alan J. Thompson, 11.10.09 (defun AT:Segment (#Obj&PntList / #Seg #Temp #Pnts) (cond ((vl-consp #Obj&PntList) (setq #Seg (fix (vlax-curve-getparamatpoint (car #Obj&PntList) (vlax-curve-getclosestpointto (car #Obj&PntList) (trans (cadr #Obj&PntList) 1 0)) ) ;_ vlax-curve-getparamatpoint ) ;_ fix #Pnts (list (vlax-curve-getpointatparam (car #Obj&PntList) #Seg) (if (setq #Temp (vlax-curve-getpointatparam (car #Obj&PntList) (1+ #Seg))) #Temp (vlax-curve-getpointatparam (car #Obj&PntList) (1- #Seg)) ) ;_ if ) ;_ list ) ;_ setq (vl-remove null (list #Seg #Pnts)) ) ) ;_ cond ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Retrieve closest end point on object ;;; #Ent&PntList - List with object and point ;;; Alan J. Thompson, 11.10.09 (defun AT:ClosestEndPoint (#Ent&PntList / #Pnt) (and (vl-consp #Ent&PntList) (setq #Pnt (vlax-curve-getclosestpointto (car #Ent&PntList) (trans (cadr #Ent&PntList) 1 0))) (setq #Pnt (car (vl-sort (list (vlax-curve-getstartpoint (car #Ent&PntList)) (vlax-curve-getendpoint (car #Ent&PntList)) ) ;_ list '(lambda (a b) (< (distance #Pnt a) (distance #Pnt b))) ) ;_ vl-sort ) ;_ car ) ;_ setq ) ;_ and #Pnt ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Rename block definition ;;; #OldName - Name of block to rename ;;; #NewName - New name for block ;;; Alan J. Thompson, 10.07.09 (defun AT:BlockRename (#OldName #NewName) (and (tblsearch "block" #OldName) (not (tblsearch "block" #NewName)) (snvalid #NewName) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))) ) ;_ or (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-name (list (vla-item (vla-get-blocks *AcadDoc*) #OldName) #NewName) ) ;_ vl-catch-all-apply ) ;_ vl-catch-all-error-p ) ;_ not ) ;_ and ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 22, 2010 Author Share Posted February 22, 2010 ;;; Get name of block (works with Dynamic blocks) ;;; #Obj - Block (vla-object) of interest ;;; Alan J. Thompson, 10.13.09 (defun AT:BlockName (#Obj) (if (vlax-property-available-p #Obj 'EffectiveName) (vla-get-effectivename #Obj) (vla-get-name #Obj) ) ;_ if ) ;_ defun Quote Link to comment Share on other sites More sharing options...
