alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Display directional arrow ;;; #Location - arrow placement point ;;; #Angle - arrow directional angle ;;; Alan J. Thompson, 04.28.09 (defun AT:Arrow (#Location #Angle / #Size #Point1 #Point2 #Point3) (setq #Size (* (getvar "viewsize") 0.02) #Point1 (polar #Location #Angle #Size) #Point2 (polar #Location (+ #Angle (* pi 0.85)) #Size) #Point3 (polar #Location (+ #Angle (* pi 1.15)) #Size) ) ;_ setq (grvecs (list 4 #Point1 #Point2 #Point2 #Point3 #Point3 #Point1) ) ;_ grvecs ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Egg Timer for calculating run time in milliseconds ;;; Alan J. Thompson, 03.22.09 ;;; Argument: #StartStop - 1 for begin, 0 for end (defun AT:EggTimer (#StartStop) (cond ((eq 1 #StartStop) (setq *EggTimer* (getvar "millisecs"))) ((eq 0 #StartStop) (if *EggTimer* (progn (alert (strcat "Process Time: " (rtos (- (getvar "millisecs") *EggTimer*)) " Milliseconds" ) ;_ strcat ) ;_ alert (setq *EggTimer* nil) ) ;_ progn ) ;_ if ) ) ;_ cond ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Draw a square with an "X" in the middle (grdraw) ;;; Alan J. Thompson, 04.07.09 (defun AT:Square (#Point / #Dist) (setq #Dist (* (getvar "VIEWSIZE") 0.1)) ;; RIGHT (grdraw (trans (polar #Point (* 0.25 pi) #Dist) 0 1) (trans (polar #Point (* 1.75 pi) #Dist) 0 1) 1 ) ;_ grdraw ;; BOTTOM (grdraw (trans (polar #Point (* 1.75 pi) #Dist) 0 1) (trans (polar #Point (* 1.25 pi) #Dist) 0 1) 2 ) ;_ grdraw ;; LEFT (grdraw (trans (polar #Point (* 1.25 pi) #Dist) 0 1) (trans (polar #Point (* 0.75 pi) #Dist) 0 1) 3 ) ;_ grdraw ;; TOP (grdraw (trans (polar #Point (* 0.75 pi) #Dist) 0 1) (trans (polar #Point (* 0.25 pi) #Dist) 0 1) 4 ) ;_ grdraw ;; X IN MIDDLE (TR->BL) (grdraw (trans (polar #Point (* 0.25 pi) #Dist) 0 1) (trans (polar #Point (* 1.25 pi) #Dist) 0 1) 7 ) ;_ grdraw ;; X IN MIDDLE (TL->BR) (grdraw (trans (polar #Point (* 0.75 pi) #Dist) 0 1) (trans (polar #Point (* 1.75 pi) #Dist) 0 1) 7 ) ;_ grdraw ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Convert color number to string and give ;;; color name if number is between 1 and 7 ;;; #ColorNumber - color number to process ;;; Alan J. Thompson, 06.16.09 (defun AT:ColorFix (#ColorNumber) (if (numberp #ColorNumber) (cond ((eq 1 #ColorNumber) "Red") ((eq 2 #ColorNumber) "Yellow") ((eq 3 #ColorNumber) "Green") ((eq 4 #ColorNumber) "Cyan") ((eq 5 #ColorNumber) "Blue") ((eq 6 #ColorNumber) "Magenta") ((eq 7 #ColorNumber) "White") (T (itoa #ColorNumber)) ) ;_ cond ) ;_ if ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; VLA entsel replacement (returns entsel or ENAME as VLA-OBJECT) ;;; #EntityOrMessage - nil: entsel-style selection ;;; "string": will display selection message with entsel-style selection ;;; Selection: convert to VLA-OBJECT ;;; Alan J. Thompson, 08.11.09 (defun AT:VlaSel (#EntityOrMessage / #EntityOrMessage #VlaObject) (or #EntityOrMessage (setq #EntityOrMessage "\nSelect object: ") ) ;_ or (cond ((vl-consp #EntityOrMessage) (setq #VlaObject (vlax-ename->vla-object (car #EntityOrMessage))) ) ((eq (type #EntityOrMessage) 'STR) (setvar "errno" 0) (if (while (and (not #VlaObject) (/= 52 (getvar "errno")) ) ;_ and (setq #VlaObject (entsel #EntityOrMessage)) ) ;_ while (setq #VlaObject (vlax-ename->vla-object (car #VlaObject))) ) ;_ if ) ((eq (type #EntityOrMessage) 'ENAME) (setq #VlaObject (vlax-ename->vla-object #EntityOrMessage)) ) ) ;_ cond ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Entsel or NEntsel with options ;;; #Nested - Entsel or Nentsel (T for Nentsel, nil for Entsel) ;;; #Message - Selection message (if nil, "\nSelect object: " is used) ;;; #FilterList - DXF ssget style filtering (nil if not required) ;;; "V" as first item in list to convert object to VLA-OBJECT (must be in list if no DXF filtering) ;;; "L" as first item in list to ignore locked layers (must be in list if no DXF filtering) ;;; #Keywords - Keywords to match instead of object selection (nil if not required) ;;; Example: (AT:Entsel nil "\nSelect MText not on 0 layer [settings]: " '("LV" (0 . "MTEXT")(8 . "~0")) "Settings") ;;; Example: (AT:Entsel T "\nSelect object [settings]: " '("LV") "Settings") ;;; Alan J. Thompson, 04.16.09 ;;; Updated: Alan J. Thompson, 06.04.09 (changed filter coding to work as ssget style dxf filtering) ;;; Updated: Alan J. Thompson, 09.07.09 (added option to ignore locked layers and convert object to VLA-OBJECT ;;; Updated: Alan J. Thompson, 09.18.09 (fixed 'missed pick' alert) (defun AT:Entsel (#Nested #Message #FilterList #Keywords / #Count #Message #Choice #Ent #VLA&Locked #FilterList ) (vl-load-com) (setvar "errno" 0) (setq #Count 0) ;; fix message (or #Message (setq #Message "\nSelect object: ")) ;; set entsel/nentsel (if #Nested (setq #Choice nentsel) (setq #Choice entsel) ) ;_ if ;; check if option to convert to vla-object or ignore locked layers in #FilterList variable (and (vl-consp #FilterList) (eq (type (car #FilterList)) 'STR) (setq #VLA&Locked (car #FilterList) #FilterList (cdr #FilterList) ) ;_ setq ) ;_ and ;; select object (while (and (not #Ent) (/= (getvar "errno") 52)) ;; if keywords (and #Keywords (initget #Keywords)) (cond ((setq #Ent (#Choice #Message)) ;; if ignore locked layers (and #VLA&Locked (vl-consp #Ent) (wcmatch (strcase #VLA&Locked) "*L*") (not (zerop (cdr (assoc 70 (entget (tblobjname "layer" (cdr (assoc 8 (entget (car #Ent)))) ) ;_ tblobjname ) ;_ entget ) ;_ assoc ) ;_ cdr ) ;_ zerop ) ;_ not (setq #Ent nil #Flag T ) ;_ setq ) ;_ and ;; #FilterList check (if (and #FilterList (vl-consp #Ent)) ;; process filtering from #FilterList (or (not (member nil (mapcar '(lambda (x) (wcmatch (strcase (vl-princ-to-string (cdr (assoc (car x) (entget (car #Ent)))) ) ;_ vl-princ-to-string ) ;_ strcase (strcase (vl-princ-to-string (cdr x))) ) ;_ wcmatch ) ;_ lambda #FilterList ) ;_ mapcar ) ;_ member ) ;_ not (setq #Ent nil #Flag T ) ;_ setq ) ;_ or ) ;_ if ) ) ;_ cond (and (or (= (getvar "errno") 7) #Flag) (/= (getvar "errno") 52) (not #Ent) (setq #Count (1+ #Count)) (prompt (strcat "\nNope, keep trying! " (itoa #Count) " missed pick(s)." ) ;_ strcat ) ;_ prompt ) ;_ and ) ;_ while (if (and (vl-consp #Ent) #VLA&Locked (wcmatch (strcase #VLA&Locked) "*V*") ) ;_ and (vlax-ename->vla-object (car #Ent)) #Ent ) ;_ if ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Convert selection set to list of ename or vla objects ;;; #Selection - SSGET selection set ;;; #VLAList - T for vla objects, nil for ename ;;; Alan J. Thompson, 04.20.09 (defun AT:SS->List (#Selection #VlaList / #List) (and #Selection (setq #List (vl-remove-if 'listp (mapcar 'cadr (ssnamex #Selection)) ) ;_ vl-remove-if ) ;_ setq #VlaList (setq #List (mapcar 'vlax-ename->vla-object #List)) ) ;_ and #List ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Convert list of vla or ename objects to 1 selection set ;;; #SelectionList - list of vla or ename selections ;;; Alan J. Thompson, 05.07.09 (defun AT:List->SS (#SelectionList / #SSAdd) (setq #SSAdd (ssadd)) (mapcar '(lambda (x) (if (eq (type x) 'VLA-OBJECT) (ssadd (vlax-vla-object->ename x) #SSAdd) (ssadd x #SSAdd) ) ;_ if ) ;_ lambda #SelectionList ) ;_ mapcar #SSAdd ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Tab filter for ssget selection filtering ;;; Alan J. Thompson, 06.05.09 (defun AT:TabFilter (/) (if (eq 2 (getvar "cvport")) (cons 410 "Model") (cons 410 (getvar "ctab")) ) ;_ if ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Remove all spaces from string ;;; Alan J. Thompson, 03.20.09 (defun AT:NoSpaces (#String / #String) (while (vl-string-search " " #String) (setq #String (vl-string-subst "" " " #String)) ) ;_ while ) ;_ defun ;;; Remove all extra spaces from string ;;; Alan J. Thompson, 03.20.09 (defun AT:NoExtraSpaces (#String / #String) (vl-string-trim " " (while (vl-string-search " " #String) (setq #String (vl-string-subst "" " " #String)) ) ;_ while ) ;_ vl-string-trim ) ;_ defun ;;; Remove/Add Carriage Returns From String ;;; #String - The string. ;;; #Alternate: Replacement for or to be replaced with carriage return ;;; Alan J. Thompson, 03.20.09 (defun AT:CarriageToggle (#String #Alternate / #Find #Replace #String) (if (vl-string-search "\\P" #String) (setq #Find "\\P" #Replace #Alternate ) ;_ setq (setq #Find #Alternate #Replace "\\P" ) ;_ setq ) ;_ if (while (or (vl-string-search #Find #String) (vl-string-search (strcat #Replace #Replace) #String) ) ;_ and (setq #String (vl-string-subst #Replace (strcat #Replace #Replace) (vl-string-subst #Replace #Find #String) ) ;_ vl-string-subst ) ;_ setq ) ;_ while ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; List of Multileader Style VLA-Objects in drawing ;;; Alan J. Thompson, 06.15.09 (defun AT:MLeaderStyleObjList (/) (vl-remove-if 'null (mapcar '(lambda (x) (if (eq 350 (car x)) (vlax-ename->vla-object (cdr x)) ) ;_ if ) ;_ lambda (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE") ) ;_ mapcar ) ;_ vl-remove-if ) ;_ defun ;;; List of dimension styles in drawing (with or w/o child styles) ;;; #ChildStyles - T for child styles, nil to ignore ;;; Alan J. Thompson, 06.18.09 (defun AT:DimStyleObjList (#ChildStyles / #List) (vlax-for x (vla-get-dimstyles (vla-get-activedocument (vlax-get-acad-object) ) ;_ vla-get-activedocument ) ;_ vla-get-dimstyles (setq #List (cons x #List)) ) ;_ vlax-for (if #ChildStyles #List (vl-remove-if '(lambda (x) (wcmatch (vla-get-name x) "*$*")) #List ) ;_ vl-remove-if ) ;_ if ) ;_ defun ;;; Convert existing dimstyle to VLA-Object ;;; #DimStyleName - name of dimension style ;;; Alan J. Thompson, 06.18.09 (defun AT:DimStyleObj (#DimStyleName / #Obj) (and (tblsearch "dimstyle" #DimStyleName) (setq #Obj (vla-item (vla-get-dimstyles (vla-get-activedocument (vlax-get-acad-object) ) ;_ vla-get-activedocument ) ;_ vla-get-dimstyles #DimStyleName ) ;_ vla-item ) ;_ setq ) ;_ and #Obj ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Retreive current UCS angle ;;; Alan J. Thompson, 03.09.09 (defun AT:UCSAngle (/ xdir) (setq xdir (getvar "ucsxdir")) (atan (cadr xdir) (car xdir)) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 LoL :twisted::twisted: Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Release object (VLA) ;;; Alan J. Thompson, 04.23.09 (defun AT:Release (#Object) (and (eq (type #Object) 'VLA-OBJECT) (vl-catch-all-apply 'vlax-release-object (list #Object)) ) ;_ and ) ;_ defun ;;; Send string to commandline ;;; #String - String to send ;;; Alan J. Thompson, 04.28.09 (defun AT:Send (#String) (if (eq (type #String) 'STR) (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object) ) ;_ vla-get-activedocument #String ) ;_ vla-sendcommand ) ;_ if ) ;_ defun ;;; Regenerate active view ;;; Alan J. Thompson, 04.28.09 (defun AT:Regen (/) (vla-Regen (vla-get-ActiveDocument (vlax-get-Acad-Object)) acActiveViewport ) ;_ vla-Regen ) ;_ defun ;;; Save active drawing ;;; Alan J. Thompson, 05.26.09 (defun AT:Save (/) (vla-save (vla-get-activedocument (vlax-get-acad-object) ) ;_ vla-get-activedocument ) ;_ vla-save ) ;_ defun ;;; Zoom Window a specified area ;;; #Point1 - 1st corner of window ;;; #Point2 - 2nd corner of window ;;; Alan J. Thompson, 06.04.09 (defun AT:ZoomWindow (#Point1 #Point2) (and (vl-consp #Point1) (vl-consp #Point2) (vla-zoomwindow (vlax-get-acad-object) (vlax-3d-point #Point1) (vlax-3d-point #Point2) ) ;_ vla-zoomwindow ) ;_ and ) ;_ defun ;;; Zoom Extents ;;; Alan J. Thompson, 06.04.09 (defun AT:ZoomExtents (/) (vla-zoomextents (vlax-get-acad-object)) ) ;_ defun ;;; Zoom Previous ;;; Alan J. Thompson, 06.04.09 (defun AT:ZoomPrevious (/) (vla-zoomprevious (vlax-get-acad-object)) ) ;_ defun ;;; Switch to model-paperspace (mspace replacement) ;;; Alan J. Thompson, 06.04.09 (defun AT:MSpace (/) (and (zerop (getvar "tilemode")) (vla-put-mspace (vla-get-activedocument (vlax-get-acad-object)) :vlax-true ) ;_ vla-put-mspace ) ;_ and ) ;_ defun ;;; Switch to paperspace (pspace replacement) ;;; Alan J. Thompson, 06.04.09 (defun AT:PSpace (/) (and (zerop (getvar "tilemode")) (vla-put-mspace (vla-get-activedocument (vlax-get-acad-object)) :vlax-false ) ;_ vla-put-mspace ) ;_ and ) ;_ defun ;;; Dump VLA info of specified object ;;; #Object - VLA-Object ;;; Alan J. Thompson, 09.07.09 (defun AT:Dump (#Object) (if #Object (vl-catch-all-apply 'vlax-dump-object (list #Object)) (vl-catch-all-apply '(lambda () (vlax-dump-object (vlax-ename->vla-object (car (entsel "\nSelect object to dump: ")) ) ;_ vlax-ename->vla-object ) ;_ vlax-dump-object ) ;_ lambda ) ;_ vl-catch-all-apply ) ;_ if (textscr) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Xref bound name fix (replace "$0$" with desired text) ;;; #Replace - text string to replace "$0$" with ;;; Alan J. Thompson, 09.16.09 (defun AT:XrefBindNameFix (#Replace) (and (snvalid #Replace) (vlax-for x (vla-get-layers (vla-get-activedocument (vlax-get-acad-object) ) ;_ vla-get-activedocument ) ;_ vla-get-layers (and (vl-string-search "$0$" (vla-get-name x)) (vl-catch-all-apply 'vla-put-name (list x (vl-string-subst #Replace "$0$" (vla-get-name x))) ) ;_ vl-catch-all-apply ) ;_ and ) ;_ vlax-for ) ;_ and ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Purge Multileader Styles (since vla-purgeall ignores them) ;;; Alan J. Thompson, 08.24.09 (defun AT:MleaderStylePurge (/) (vl-remove-if 'null (mapcar '(lambda (x) (and (eq 350 (car x)) (not (eq 330 (car (nth 5 (entget (cdr x)))))) (not (eq (getvar "cmleaderstyle") (vla-get-name (vlax-ename->vla-object (cdr x))) ) ;_ eq ) ;_ not (entdel (cdr x)) ) ;_ and ) ;_ lambda (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE") ) ;_ mapcar ) ;_ vl-remove-if ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Test if item is specifed type (T=Yes, nil=No) ;;; #Item - Item to compare ;;; #Type - Type to compare with ;;; Alan J. Thompson, 08.28.09 (defun AT:IsType (#Item #Type) (eq (type #Item) #Type ) ;_ eq ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; Check if Current Coordinate System is "World" ;;; Return: T = Yes, nil = No ;;; Alan J. Thompson, 08.28.09 (defun WCS? (/) (not (zerop (getvar "worlducs"))) ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 22, 2009 Author Share Posted September 22, 2009 ;;; List of TextStyle Objects ;;; Alan J. Thompson, 09.02.09 (defun AT:TextStyleObjList (/ #List) (vlax-for x (vla-get-textstyles (vla-get-activedocument (vlax-get-acad-object)) ) ;_ vla-get-textstyles (setq #List (cons x #List)) ) ;_ vlax-for #List ) ;_ defun ;;; List of Xref Objects ;;; Alan J. Thompson, 09.02.09 (defun AT:XrefObjList (/ #List) (vlax-for x (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)) ) ;_ vla-get-blocks (and (eq (vla-get-isxref x) :vlax-true) (setq #List (cons x #List)) ) ;_ and ) ;_ vlax-for #List ) ;_ defun Quote Link to comment Share on other sites More sharing options...
alanjt Posted October 27, 2009 Author Share Posted October 27, 2009 ;;; Add MText to drawing ;;; #InsertionPoint - MText insertion point ;;; #String - String to place in created MText object ;;; #Width - Width of MText object (if nil, will be 0 width) ;;; #Layer - Layer to place Mtext object on (nil for current) ;;; #Justification - Justification # for Mtext object ;;; 1 or nil= TopLeft ;;; 2= TopCenter ;;; 3= TopRight ;;; 4= MiddleLeft ;;; 5= MiddleCenter ;;; 6= MiddleRight ;;; 7= BottomLeft ;;; 8= BottomCenter ;;; 9= BottomRight ;;; Alan J. Thompson, 05.23.09 (defun AT:MText (#InsertionPoint #String #Width #Layer #Justification / #Width #Space #Insertion #Object ) (or #Width (setq #Width 0)) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))) ) ;_ or (setq #Space (if (or (eq acmodelspace (vla-get-activespace *AcadDoc*) ) ;_ eq (eq :vlax-true (vla-get-mspace *AcadDoc*)) ) ;_ or (vla-get-modelspace *AcadDoc*) (vla-get-paperspace *AcadDoc*) ) ;_ if #Insertion (cond ((vl-consp #InsertionPoint) (vlax-3d-point #InsertionPoint)) ((eq (type #InsertionPoint) 'variant) #InsertionPoint) (T nil) ) ;_ cond ) ;_ setq ;; create MText object (setq #Object (vla-addmtext #Space #Insertion #Width #String)) ;; change layer, if applicable (and #Layer (tblsearch "layer" #Layer) (vla-put-layer #Object #Layer) ) ;_ and ;; change justification & match insertion point with new justification (cond ((member #Justification (list 1 2 3 4 5 6 7 8 9)) (vla-put-attachmentpoint #Object #Justification) (vla-move #Object (vla-get-InsertionPoint #Object) #Insertion ) ;_ vla-move ) ) ;_ cond #Object ) ;_ defun Quote Link to comment Share on other sites More sharing options...
