63alfred Posted October 31, 2017 Posted October 31, 2017 My error the code for the above should be: (defun c:profiles5ft (/ ent1 ent2 i len pt p1 ptlst1 ptlst2 ptlst3 ptlst4) (vl-load-com) (set'one 5) (if (and (setq ent1 (car (entsel "\nSelect First Polyline: "))) (wcmatch (cdr (assoc 0 (entget ent1))) "*POLYLINE")) (if (and (setq ent2 (car (entsel "\nSelect Second Polyline: "))) (wcmatch (cdr (assoc 0 (entget ent2))) "*POLYLINE")) (progn (setq i -1 len (/ (vla-get-Length (vlax-ename->vla-object ent1)) 100.)) (while (setq pt (vlax-curve-getPointatDist ent1 (* (setq i (1+ i)) len))) (setq p1 (vlax-curve-getClosestPointto ent2 pt t) ptlst1 (cons (polar pt (angle pt p1) (/ (distance pt p1) one.)) ptlst1))) (setq ptlst1 (apply 'append (mapcar (function (lambda (x) (list (car x) (cadr x)))) ptlst1))) (vla-AddLightWeightPolyline (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-VBDouble (cons 0 (1- (length ptlst1)))) ptlst1)))))) (set'two 2.5) (if (and (setq ent1 (car (entsel "\nSelect First Polyline: "))) (wcmatch (cdr (assoc 0 (entget ent1))) "*POLYLINE")) (if (and (setq ent2 (car (entsel "\nSelect Second Polyline: "))) (wcmatch (cdr (assoc 0 (entget ent2))) "*POLYLINE")) (progn (setq i -1 len (/ (vla-get-Length (vlax-ename->vla-object ent1)) 100.)) (while (setq pt (vlax-curve-getPointatDist ent1 (* (setq i (1+ i)) len))) (setq p1 (vlax-curve-getClosestPointto ent2 pt t) ptlst2 (cons (polar pt (angle pt p1) (/ (distance pt p1) two.)) ptlst2))) (setq ptlst2 (apply 'append (mapcar (function (lambda (x) (list (car x) (cadr x)))) ptlst2))) (vla-AddLightWeightPolyline (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-VBDouble (cons 0 (1- (length ptlst2)))) ptlst2)))))) (set'three 1.66) (if (and (setq ent1 (car (entsel "\nSelect First Polyline: "))) (wcmatch (cdr (assoc 0 (entget ent1))) "*POLYLINE")) (if (and (setq ent2 (car (entsel "\nSelect Second Polyline: "))) (wcmatch (cdr (assoc 0 (entget ent2))) "*POLYLINE")) (progn (setq i -1 len (/ (vla-get-Length (vlax-ename->vla-object ent1)) 100.)) (while (setq pt (vlax-curve-getPointatDist ent1 (* (setq i (1+ i)) len))) (setq p1 (vlax-curve-getClosestPointto ent2 pt t) ptlst3 (cons (polar pt (angle pt p1) (/ (distance pt p1) three.)) ptlst3))) (setq ptlst3 (apply 'append (mapcar (function (lambda (x) (list (car x) (cadr x)))) ptlst3))) (vla-AddLightWeightPolyline (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-VBDouble (cons 0 (1- (length ptlst3)))) ptlst3)))))) (set'four 1.25) (if (and (setq ent1 (car (entsel "\nSelect First Polyline: "))) (wcmatch (cdr (assoc 0 (entget ent1))) "*POLYLINE")) (if (and (setq ent2 (car (entsel "\nSelect Second Polyline: "))) (wcmatch (cdr (assoc 0 (entget ent2))) "*POLYLINE")) (progn (setq i -1 len (/ (vla-get-Length (vlax-ename->vla-object ent1)) 100.)) (while (setq pt (vlax-curve-getPointatDist ent1 (* (setq i (1+ i)) len))) (setq p1 (vlax-curve-getClosestPointto ent2 pt t) ptlst4 (cons (polar pt (angle pt p1) (/ (distance pt p1) four.)) ptlst4))) (setq ptlst4 (apply 'append (mapcar (function (lambda (x) (list (car x) (cadr x)))) ptlst4))) (vla-AddLightWeightPolyline (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))) (vlax-make-variant (vlax-safearray-fill (vlax-make-safearray vlax-VBDouble (cons 0 (1- (length ptlst4)))) ptlst4)))))) (princ)) Quote
nicolecita Posted May 21, 2020 Posted May 21, 2020 Hi, is there a CPoly equivalent for Autocad for Mac? Thank you! Quote
Ilir Posted July 21, 2022 Posted July 21, 2022 Lee, can you create a LISP for me: polyline, .040 thick, dashed, 4 cliks, layer 0, green color. I will use it as AVB membrane. Thanks Quote
