kevynm Posted February 18, 2010 Share Posted February 18, 2010 Sorry Alan. I added (vl-load-com) to the top of the code, ran the command independently. still get the same error message. Thx for the quick response Kevin Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 18, 2010 Author Share Posted February 18, 2010 Sorry Alan. I added (vl-load-com) to the top of the code, ran the command independently. still get the same error message.Thx for the quick response Kevin So odd. Replace the error handler with this: ;;; error handler (defun *error* (#Message) (vl-bt) (AT:Undo "V" "E") (and #Message (not (wcmatch (strcase #Message) "*BREAK*,*CANCEL*,*QUIT*")) (princ (strcat "\nError: " #Message)) ) ;_ and ) ;_ defun Once you execute the command, copy what it prints to the command line and paste here. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted February 18, 2010 Share Posted February 18, 2010 Kevynm, I notice that you are using 2010. I found that I had to type (vl-load-com) directly at the command line before any VL functions were recognised. Subsequently, I put (vl-load-com) in my ACADDOC.lsp, but its worth a try. Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 18, 2010 Author Share Posted February 18, 2010 Kevynm, I notice that you are using 2010. I found that I had to type (vl-load-com) directly at the command line before any VL functions were recognised. Subsequently, I put (vl-load-com) in my ACADDOC.lsp, but its worth a try. That's what I was originally trying to get him to do. http://www.cadtutor.net/forum/showpost.php?p=304171&postcount=17 Again, please try typing it in before you execute the command. Quote Link to comment Share on other sites More sharing options...
kevynm Posted February 18, 2010 Share Posted February 18, 2010 Hey Guys sorry to be a bother but it still does'nt work Command: (vl-load-com) Command: ct Backtrace: [0.59] (VL-BT) [1.55] (*ERROR* "no function definition: VLAX-GET-ACAD-OBJECT") [2.50] (_call-err-hook # "no function definition: VLAX-GET-ACAD-OBJECT") [3.44] (sys-error "no function definition: VLAX-GET-ACAD-OBJECT") :ERROR-BREAK.39 nil [4.36] (#) [5.33] (VLAX-GET-ACAD-OBJECT) [6.29] (AT:UNDO "V" "B") [7.23] (C:COPYTEXT) [8.19] (C:CT) [9.15] (#) [10.12] (# "(C:CT)" T #) :CALLBACK-ENTRY.6 (:CALLBACK-ENTRY) :ARQ-SUBR-CALLBACK.3 (nil 0) ; error: An error has occurred inside the *error* functionno function definition: VLAX-GET-ACAD-OBJECT that's what i get after running the routine Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 18, 2010 Author Share Posted February 18, 2010 What happens if you just type this at the command line? (vlax-get-acad-object) Quote Link to comment Share on other sites More sharing options...
kevynm Posted February 19, 2010 Share Posted February 19, 2010 This is what i get Command: (vlax-get-acad-object) ; error: no function definition: VLAX-GET-ACAD-OBJECT hey Alan, thx for all the help man, really appreciate it. Kev Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 19, 2010 Author Share Posted February 19, 2010 This is what i getCommand: (vlax-get-acad-object) ; error: no function definition: VLAX-GET-ACAD-OBJECT hey Alan, thx for all the help man, really appreciate it. Kev Very strange. Just to cover the bases, paste this to the command line. (vl-load-com) (vlax-get-acad-object) Quote Link to comment Share on other sites More sharing options...
kevynm Posted February 19, 2010 Share Posted February 19, 2010 OK HERE GOES Command: (vl-load-com) ; error: COM exception: Library not registered. Command: (vlax-get-acad-object) ; error: no function definition: VLAX-GET-ACAD-OBJECT Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 19, 2010 Author Share Posted February 19, 2010 OK HERE GOES Command: (vl-load-com) ; error: COM exception: Library not registered. Command: (vlax-get-acad-object) ; error: no function definition: VLAX-GET-ACAD-OBJECT Now we're getting somewhere. Just to clarify, you are using Autocad 2010, correct? You may need to do a repair on you install, these files should be readily available and load upon typing (vl-load-com). Paste this to the commandline: (findfile "vl.arx") If you get a file, type (arxload (findfile "vl.arx")) and let's see what happens. Quote Link to comment Share on other sites More sharing options...
kevynm Posted February 19, 2010 Share Posted February 19, 2010 yay!! Rock'n'roll time.... I'm in and the routine works. Thank you thank you thank you. Cheers kev Quote Link to comment Share on other sites More sharing options...
kevynm Posted February 19, 2010 Share Posted February 19, 2010 but.... on running the routine and picking my 1st text object.. Command: ct Select source text object for copying or [Type]: Backtrace: [0.63] (VL-BT) [1.59] (*ERROR* "no function definition: VLAX-ENAME->VLA-OBJECT") [2.54] (_call-err-hook # "no function definition: VLAX-ENAME->VLA-OBJECT") [3.48] (sys-error "no function definition: VLAX-ENAME->VLA-OBJECT") :ERROR-BREAK.43 nil [4.40] (# ) [5.36] (VLAX-ENAME->VLA-OBJECT ) [6.31] (AT:ENTSEL T "\nSelect source text object for copying or [Type]: " ("LV" (0 . "MTEXT,TEXT,MULTILEADER,ATTDEF,ATTRIB")) "Type") [7.23] (C:COPYTEXT) [8.19] (C:CT) [9.15] (#) [10.12] (# "(C:CT)" T #) :CALLBACK-ENTRY.6 (:CALLBACK-ENTRY) :ARQ-SUBR-CALLBACK.3 (nil 0) Error: no function definition: VLAX-ENAME->VLA-OBJECT and so my sad story continues...:-( Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 19, 2010 Author Share Posted February 19, 2010 but....on running the routine and picking my 1st text object.. Command: ct Select source text object for copying or [Type]: Backtrace: [0.63] (VL-BT) [1.59] (*ERROR* "no function definition: VLAX-ENAME->VLA-OBJECT") [2.54] (_call-err-hook # "no function definition: VLAX-ENAME->VLA-OBJECT") [3.48] (sys-error "no function definition: VLAX-ENAME->VLA-OBJECT") :ERROR-BREAK.43 nil [4.40] (# ) [5.36] (VLAX-ENAME->VLA-OBJECT ) [6.31] (AT:ENTSEL T "\nSelect source text object for copying or [Type]: " ("LV" (0 . "MTEXT,TEXT,MULTILEADER,ATTDEF,ATTRIB")) "Type") [7.23] (C:COPYTEXT) [8.19] (C:CT) [9.15] (#) [10.12] (# "(C:CT)" T #) :CALLBACK-ENTRY.6 (:CALLBACK-ENTRY) :ARQ-SUBR-CALLBACK.3 (nil 0) Error: no function definition: VLAX-ENAME->VLA-OBJECT and so my sad story continues...:-( I'm at a complete loss. These are commands from the Visual Lisp arx that's been included with Autocad since v2000. I feel you need to repair your install. You could try and get the vl.arx file from someone else (running the same version of Autocad as you) and replace yours with it. Quote Link to comment Share on other sites More sharing options...
kevynm Posted February 19, 2010 Share Posted February 19, 2010 OK Alan, you have been a great help. I will do a reload on the weekend. Thanks again for all you help. Kev Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 19, 2010 Author Share Posted February 19, 2010 OK Alan,you have been a great help. I will do a reload on the weekend. Thanks again for all you help. Kev Keep me posted. It's so strange that you are having this issue. Quote Link to comment Share on other sites More sharing options...
kevynm Posted February 19, 2010 Share Posted February 19, 2010 Alan, you're right My Autocad which I d/l and installed from the AutpCAD site is corrupt. when i run the express tool 'Breakline symbol' this is what i get Command: breakline no function definition: VLAX-PRODUCT-KEY thx again kev Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 19, 2010 Author Share Posted February 19, 2010 Alan,you're right My Autocad which I d/l and installed from the AutpCAD site is corrupt. when i run the express tool 'Breakline symbol' this is what i get Command: breakline no function definition: VLAX-PRODUCT-KEY thx again kev Start>Settings>Control Panel>Add/Remove Programs>Autocad>Repair Installation Quote Link to comment Share on other sites More sharing options...
guitarguy1685 Posted February 26, 2010 Share Posted February 26, 2010 awesome lisp sir. I was making something similiar but it only worked for attribute text. This one is even better than mine. Quote Link to comment Share on other sites More sharing options...
alanjt Posted February 26, 2010 Author Share Posted February 26, 2010 awesome lisp sir. I was making something similiar but it only worked for attribute text. This one is even better than mine. Thanks and enjoy. Quote Link to comment Share on other sites More sharing options...
kevynm Posted March 8, 2010 Share Posted March 8, 2010 Ok not only reloaded AutoCAd but Vista too. Now your prg works like a dream. Thks man Quote Link to comment Share on other sites More sharing options...
