dgprodim Posted September 15, 2009 Posted September 15, 2009 Hello, I have the drawing of a room as a solid object and I can measure the total volume. My problem is that I want to indicate a specific height of this room,let's say that it's 3,42 m high and I indicate a point at 2,33 m.How can I measure the volume at 2,33 m? Thank you in advance for any help or comment! Quote
Danny Posted September 15, 2009 Posted September 15, 2009 dgprodim said: Hello, I have the drawing of a room as a solid object and I can measure the total volume. My problem is that I want to indicate a specific height of this room,let's say that it's 3,42 m high and I indicate a point at 2,33 m.How can I measure the volume at 2,33 m? Thank you in advance for any help or comment! length x breadth() x height : this will give you the volume of your room. (I am assuming this room is relitivitive to a cube) Quote
mechaTurq Posted September 16, 2009 Posted September 16, 2009 dgprodim said: Hello, I have the drawing of a room as a solid object and I can measure the total volume. My problem is that I want to indicate a specific height of this room,let's say that it's 3,42 m high and I indicate a point at 2,33 m.How can I measure the volume at 2,33 m? Thank you in advance for any help or comment! You could use BooleanIntersect if you have all your objects solid. * First create a box upto height you wanna measure * Use BooleanIntersection and select box and your room to trim upper part * Use Volume command to measure Maybe this would help? Quote
dgprodim Posted September 16, 2009 Author Posted September 16, 2009 mechaTurq said: You could use BooleanIntersect if you have all your objects solid. * First create a box upto height you wanna measure * Use BooleanIntersection and select box and your room to trim upper part * Use Volume command to measure Maybe this would help? Yes,this was what I was looking for.Thank you very very very much!!! Quote
Glen Smith Posted September 16, 2009 Posted September 16, 2009 Or you could use the area and (manually) multiply by your height. Quote
dgprodim Posted September 16, 2009 Author Posted September 16, 2009 Glen Smith said: Or you could use the area and (manually) multiply by your height. The walls of the room usually have an inclination which means that the bottom area is not the same in two meters height.Imagine that usually I want to measure the volume of a storage room of a cargo ship where the walls do not have a normal shape. The idea with the booleanintersection funtion seems to work fine in the drawings that I used it. Thanx anyway! Quote
Glen Smith Posted September 16, 2009 Posted September 16, 2009 Thats what I get for thinking inside the box! Glad you solved your problem. Quote
SEANT Posted September 16, 2009 Posted September 16, 2009 Glen Smith said: Thats what I get for thinking inside the box! Glad you solved your problem. That's quite amusing. With regard to the original question, Rhino's Hydrostatics command has options to also make those calculations. Quote
