OMEGA-ThundeR Posted September 14, 2009 Posted September 14, 2009 Hi, Anyone know the command how to turn on/off the layers in a filter? In our company we use standard layerfilters, so they should be the same name in every drawing (else its gonna be a good idea to do so). If i know the command on how to turn off of on layers who are set in a filter i can make a macro to do it for me, but i dunno if there is an way to turn of those layers with an command. Anyone? Quote
alanjt Posted September 14, 2009 Posted September 14, 2009 Hi, Anyone know the command how to turn on/off the layers in a filter? In our company we use standard layerfilters, so they should be the same name in every drawing (else its gonna be a good idea to do so). If i know the command on how to turn off of on layers who are set in a filter i can make a macro to do it for me, but i dunno if there is an way to turn of those layers with an command. Anyone? This can be accomplished from the Layer Manager. Right-click on a filter and you have all the on/off/freeze/thaw/isolate options. Quote
alanjt Posted September 14, 2009 Posted September 14, 2009 Insomnia is killing me! Give this a try: ;;; Layer Filter On/Off Toggle ;;; Turn on/off layers of specified Layer Filter ;;; Required Subroutines: AT:LayerFilterList AT:ListSelect ;;; Alan J. Thompson, 09.14.09 (defun c:LFT (/ #FilterList #FilterName #Choice #Filter #LayerList) (vl-load-com) (or *Acad* (setq *Acad* (vlax-get-acad-object))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument *Acad*)) ) ;_ or (if (setq #FilterList (AT:LayerFilterList)) (and (setq #FilterName (car (AT:ListSelect "LayerFilter On/Off" "Select layer filter:" "10" "10" "false" (vl-sort (mapcar 'car #FilterList) '<) ) ;_ AT:ListSelect ) ;_ car ) ;_ setq (not (initget 0 "oFf oN")) (or (setq #Choice (getkword "\nTurn layers in selected Layer Filter oFf or oN [oFf oN] <oFf>: " ) ;_ getkword ) ;_ setq (setq #Choice "oFf") ) ;_ or (setq #Filter (cdr (car (vl-remove-if-not '(lambda (x) (eq #FilterName (car x))) #FilterList ) ;_ vl-remove-if-not ) ;_ car ) ;_ cdr ) ;_ setq (cond ((eq #Choice "oFf") (vlax-for x (vla-get-layers *AcadDoc*) (and (wcmatch (strcase (vla-get-name x)) (strcase #Filter)) (setq #LayerList (cons (vla-get-name x) #LayerList)) (vl-catch-all-apply 'vla-put-layeron (list x :vlax-false)) ) ;_ and ) ;_ vlax-for (print (vl-sort #LayerList '<)) (princ (strcat "\nAll " (itoa (length #LayerList)) " layers in filter \"" #FilterName "\" have been turned off!" ) ;_ strcat ) ;_ princ ) ((eq #Choice "oN") (vlax-for x (vla-get-layers *AcadDoc*) (and (wcmatch (strcase (vla-get-name x)) (strcase #Filter)) (setq #LayerList (cons (vla-get-name x) #LayerList)) (vl-catch-all-apply 'vla-put-layeron (list x :vlax-true)) ) ;_ and ) ;_ vlax-for (print (vl-sort #LayerList '<)) (princ (strcat "\nAll " (itoa (length #LayerList)) " layers in filter \"" #FilterName "\" have been turned on!" ) ;_ strcat ) ;_ princ ) ) ;_ cond ) ;_ and (princ "\nNo Layer Filters Exist in Drawing!") ) ;_ if (princ) ) ;_ defun You will need these subroutines: ;;; Get list of Layer Filters (Name & Actual Filter Codes) ;;; Return: List of dotted pairs (("Name" . "*Filter*")) ;;; Alan J. Thompson, 09.14.09 (defun AT:LayerFilterList (/ #Filters #List) (or *Acad* (setq *Acad* (vlax-get-acad-object))) (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument *Acad*)) ) ;_ or (foreach x (entget (setq #Filters (vlax-vla-object->ename (vla-item (vla-getextensiondictionary (vla-get-layers *AcadDoc* ) ;_ vla-get-layers ) ;_ vla-getextensiondictionary "ACAD_LAYERFILTERS" ) ;_ vla-item ) ;_ vlax-vla-object->ename ) ;_ setq ) ;_ entget (if (eq 3 (car x)) (setq #List (cons (cons (cdr x) (cdr (nth 10 (dictsearch #Filters (cdr x)))) ) ;_ cons #List ) ;_ cons ) ;_ setq ) ;_ if ) ;_ foreach #List ) ;_ defun and ;list select dialog ;create a temp DCL multi-select list dialog from provided list ;value is returned in list form, DCL file is deleted when finished ;example: (setq the_list (AT:listselect "This is my list title" "Select items to make a list" "25" "30" "true" (list "object 1" "object 2" "object 3")) ;if mytitle is longer than defined width, the width will be ignored and it will fit to title string ;if mylabel is longer than defined width, mylabel will be truncated ;myheight and mywidth must be strings, not numbers ;mymultiselect must either be "true" or "false" (true for multi, false for single) ;created by: alan thompson, 9.23.08 ;some coding borrowed from http://www.jefferypsanders.com (thanks for the DCL examples) (defun AT:ListSelect ( mytitle ;title for dialog box mylabel ;label right above list box myheight ;height of dialog box !!*MUST BE STRING*!! mywidth ;width of dialog box !!*MUST BE STRING*!! mymultiselect ;"true" for multiselect, "false" for single select mylist ;list to display in list box / retlist readlist count item savevars fn fo valuestr dcl_id ) (defun saveVars(/ readlist count item) (setq retList(list)) (setq readlist(get_tile "mylist")) (setq count 1) (while (setq item (read readlist)) (setq retlist(append retList (list (nth item myList)))) (while (and (/= " " (substr readlist count 1)) (/= "" (substr readlist count 1)) ) (setq count (1+ count)) ) (setq readlist (substr readlist count)) ) );defun (setq fn (vl-filename-mktemp "" "" ".dcl")) (setq fo (open fn "w")) (setq valuestr (strcat "value = \"" mytitle "\";")) (write-line (strcat "list_select : dialog { label = \"" mytitle "\";") fo) (write-line (strcat " : column { : row { : boxed_column { : list_box { label =\"" mylabel "\"; key = \"mylist\"; allow_accept = true; height = " myheight "; width = " mywidth "; multiple_select = " mymultiselect "; fixed_width_font = false; value = \"0\"; } } } : row { : boxed_row { : button { key = \"accept\"; label = \" Okay \"; is_default = true; } : button { key = \"cancel\"; label = \" Cancel \"; is_default = false; is_cancel = true; } } } } }") fo) (close fo) (setq dcl_id (load_dialog fn)) (new_dialog "list_select" dcl_id) (start_list "mylist" 3) (mapcar 'add_list myList) (end_list) (action_tile "cancel" "(setq ddiag 1)(done_dialog)") (action_tile "accept" "(setq ddiag 2)(saveVars)(done_dialog)") (start_dialog) (if (= ddiag 1) (setq retlist nil) ) (unload_dialog dcl_id) (vl-file-delete fn) retlist );defun 1 Quote
OMEGA-ThundeR Posted September 14, 2009 Author Posted September 14, 2009 hmmm, ok. And how do i make that work? It doesn't look like an macro. I am lazy i don't want to use manual input (like typing in which filter i want to turn on/off layers) but just with an button. Isn't there an command to do that or has it to be done in the layermanager only ? Quote
alanjt Posted September 14, 2009 Posted September 14, 2009 ...... hmmm, ok. And how do i make that work? It doesn't look like an macro. I am lazy i don't want to use manual input (like typing in which filter i want to turn on/off layers) but just with an button. Isn't there an command to do that or has it to be done in the layermanager only ? WOW Quote
mattsibum Posted November 3, 2011 Posted November 3, 2011 Hi alanjt, Great lisp, just wondering if there is a way to change this coding to freeze and thaw instead of turning on / off. Cheers Quote
Steve in Alaska Posted November 16, 2020 Posted November 16, 2020 I know this is an old topic, but just in case someone else comes across it looking for answers here are the commands to add for freeze/thaw. Find this line and add after it; (vl-catch-all-apply 'vla-put-layeron (list x :vlax-false)) ;;;==================================================================== (vl-catch-all-apply 'vla-put-FREEZE (list x :vlax-TRUE)) ;;;==================================================================== Find this line and add after it; (vl-catch-all-apply 'vla-put-layeron (list x :vlax-true)) ;;;==================================================================== (vl-catch-all-apply 'vla-put-FREEZE (list x :vlax-FALSE)) ;;;==================================================================== Quote
BigAl65 Posted June 9, 2023 Posted June 9, 2023 Came across this lisp routine and I'm trying to invoke it but getting errors. Appreciate the original post was a long time ago.......can anyone offer me some assistance. I've created the lisp routines from the code above. 3 seperate routines. Typing "LFT" gives me an error. Thanks in advance. Quote
