arliejan Posted September 14, 2009 Share Posted September 14, 2009 I am rephrasing my original question - can I open a VP inside another VP and have it print? The one I tried won't print although I can see it on screen and it shows up in print preview... Thanks Arlie Quote Link to comment Share on other sites More sharing options...
chulse Posted September 14, 2009 Share Posted September 14, 2009 Is this what you are looking to do? http://www.cadtutor.net/forum/showthread.php?t=7798&highlight=hole+circle+viewport+region Quote Link to comment Share on other sites More sharing options...
arliejan Posted September 14, 2009 Author Share Posted September 14, 2009 Yes, thank you CHULSE. I reworded the solution from RIGA here: To get such a viewport, start from scratch. (Can replace circle with rectangle in this instruction) In paperspace layout, draw a rectangle (not yet a VP) of the dimension of the main viewport that is needed and then a circle positioned where you want to create a "hole". Then transform the rectangle and the circle into 2 separate regions (do command _REGION two times) > At this point with the command _SUBTRACT, subtract the circle from the rectangle (select rectangle 1st, cir 2nd) to obtain a single region which is your rectangle with a "hole" and now you only need to transform this rectangle into a viewport: _-vports > Object > select the region > done! Now when needed you can place a circular viewport in the "hole". To do this from the drop down menu: View > Viewports > Polygonal Viewport > then use Arc to draw a circle - using the same point to begin and close into a circle. Quote Link to comment Share on other sites More sharing options...
