arliejan Posted September 11, 2009 Share Posted September 11, 2009 Hi, I am new to this forum, have searched for answer but found nothing. Can someone tell me how to get my small viewport that I put into paper space to print? It shows in preview. I have an xref for title block and the original viewport for the main view. Am using v2004. Must be something to activate or tweak that I've forgotten - been awhile. thanks, arliejan ps need to mention that I had put a small VP inside the main VP - is that not possible? (As a workaround I have created a polygon VP for my main view and left the small VP on the corner, so that is equiv of 2 VP side by side.) Still want to know how to put one VP inside another...? Quote Link to comment Share on other sites More sharing options...
HAD Posted June 9, 2010 Share Posted June 9, 2010 Hi, Putting a small viewport inside a larger viewport is fine. The contents will overlap, though so your solution with a polygonal viewport is usually better. I can't help you out with the contents not plotting as I am having the same problem. Quote Link to comment Share on other sites More sharing options...
Cadax Posted June 10, 2010 Share Posted June 10, 2010 Hi,Putting a small viewport inside a larger viewport is fine. The contents will overlap, though so your solution with a polygonal viewport is usually better. I can't help you out with the contents not plotting as I am having the same problem. The contents that are not plotting are drawn in paper space or xref'd in? If they're xref'd in make sure the xref isn't on a no plot layer. Some drafters in the office I work in love to do that. Quote Link to comment Share on other sites More sharing options...
