One-click Break and create gap
rcmob
Hi all, let's see if someone can figure this out...
I am in need for a LISP routine that will allow me to click once on an object (line, circle, etc) and it will break that object AND create a gap of one unit between the two ends.
Basically it breaks the object and then it trims 1/2 unit from either side of the point selected.
How can this be done?
rcmob
  • Replies 28
  • Lee Mac
    10
  • alanjt
    9
  • rcmob
    6
  • chelsea1307
    4
Posted Images
might something along the line of this help
;; This lisp breaks a two lines which cross each other
(defun c:bc ()
(setq scl (getvar "dimscale" ))
(setq dis (* scl 0.052))
(if
(= "WASTE" name)
(setq dist (* dis 1.5))
(if
(= "DUCT" name)
(if
(= "DUCT-RA" name)
(setq lne (entsel "\nPick line to break:")) (terpri)
(setq pnt (getpoint "\nPick break point:" )) (terpri)
(setq pick (entget (car lne)))
(setq pt1 (cdr (assoc 10 pick)))
(setq pt2 (cdr (assoc 11 pick)))
(setq a (angle pt1 pt2))
(setq ang ( * a 57.3))
(setq bpt1 (polar pnt a dis))
(setq bpt2 (polar pnt (- a pi) dis))
(command "break" lne "f" bpt1 bpt2 )
what's the 'name' variable?
(defun c:bc ()
(if
(= "WASTE" name)
(if
(= "DUCT" name)
(if
(= "DUCT-RA" name)
honestly not exactly sure, i didnt write this one, not sure who wrote it its in our company standards with no name on as to who wrote it. Looks like it has something to do with how big the break is depending on what layer its on, but ive used it on layers not listed and it worked fine
it doesn't check layers and the name check if the first thing performed. how odd. what returns if you type !name?
Hi, Thanks for the code, however I am looking for a lisp that breaks a line and creates a gap where I click, not where it crosses another line or anything like that.
Any suggestions?
rcmob
Any suggestions?
rcmob
did you even try chelsea's posted code?
Hey dude,
Here's a quicky and dirty option for ya :)
(defun c:qBrk (/ off pt ent ang)
 (vl-load-com)
 (initget 7)
 (setq off (getdist "\nSpecify Break Distance: "))
 (while (and (setq pt (getpoint "\nSelect Point to Break: "))
             (setq ent (car (nentselp pt))))
   (setq ang (angle '(0 0 0)
               (vlax-curve-getFirstDeriv ent
                 (vlax-curve-getParamatPoint ent
                   (setq pt (vlax-curve-getClosestPointto ent pt))))))
   (command "_.break" (list ent pt) "_F" "_non"
            (polar pt ang (/ off 2.)) "_non" (polar pt (+ pi ang) (/ off 2.))))
 (princ))
Here it is a little cleaned up took the name stuff out and it didnt seem to effect it at all, right now the size of the space is based on dimscale (i think please someone correct me if im wrong) This is most likely changeable if you have a set size to make it each time.
(defun c:bc ()
An extended version of my previous post:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:qBrk [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] *error* doc vl ov pt ent ang[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] *error* [b][color=RED]([/color][/b]lee[b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]vla-EndUndoMark[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] ov [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]setvar[/color][/b] vl ov[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]wcmatch[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcase[/color][/b] lee[b][color=RED])[/color][/b] [b][color=#ff00ff]"*BREAK,*CANCEL*,*EXIT*"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\n** Error: "[/color][/b] lee [b][color=#ff00ff]" **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       vl [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"CMDECHO"[/color][/b] [b][color=#ff00ff]"OSMODE"[/color][/b][b][color=RED])[/color][/b] ov [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]getvar[/color][/b] vl[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"CMDECHO"[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]or[/color][/b] *Mac [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] *Mac [b][color=#009999]10.0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]initget[/color][/b] [b][color=#009900]4[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]getdist[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b] [b][color=#ff00ff]"\nSpecify Break Distance <"[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]vl-princ-to-string[/color][/b] *Mac[b][color=RED])[/color][/b] [b][color=#ff00ff]"> : "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]*Mac[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b] [b][color=#ff00ff]"\nSelect Point to Break: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]nentselp[/color][/b] pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]vl-catch-all-error-p[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]vl-catch-all-apply[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-curve-getEndParam[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] ent[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n** Cannot Break that Object **"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
         [b][color=RED]([/color][color=Blue]t[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]vla-StartUndoMark[/color][/b] doc[b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ang [b][color=RED]([/color][/b][b][color=BLUE]angle[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getFirstDeriv[/color][/b] ent
                        [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getParamatPoint[/color][/b] ent
                          [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]vlax-curve-getClosestPointto[/color][/b] ent pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"OSMODE"[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]command[/color][/b] [b][color=#ff00ff]"_.break"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] ent pt[b][color=RED])[/color][/b] [b][color=#ff00ff]"_F"[/color][/b]
            [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] pt ang [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] *Mac [b][color=#009999]2.[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]+[/color][/b] [b][color=BLUE]pi[/color][/b] ang[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] *Mac [b][color=#009999]2.[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]vla-EndUndoMark[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Ok, I have been using it for a few days now and it works great but it has one bug...
If I try to use it on a circle, instead of creating a gap at the point I select, it actually leaves an arc of the selected length and deletes the rest of the circle...Basically it does the exact opposite than it does on a line...
Any clue what is going on?
rcmob
